C2E-40.000-12-50100-X1-CT 数据手册
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Ltr
Revisions
Appr
Date
Electrical Specifications:
Frequency Range
12.000 to 60.000
Fundamental
12.000 to 60.000
±50
±100
-40 to +125
-55 to +125
±3
7 to 32 and Series Resonance
3.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
Mode of Oscillation
Frequency Tolerance at 25°C
Frequency Stability over Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging per Year
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
12.000 to 13.999
14.000 to 15.999
16.000 to 19.999
20.000 to 23.999
24.000 to 24.999
25.000 to 44.999
45.000 to 60.000
200
150
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
Fundamental
90
70
60
50
40
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: May 1, 2017
Microprocessor Crystal Unit
Automotive Temperature Range
2.5 x 2.0 millimeter Surface Mount
General Product Specification
Part Number:
C2E X1 Series
www.aker-usa.com
MHz
PPM Max
ºC
PPM Max
pF
Ohms
uW Typ
M Ohms
Mechanical Outline:
2.5 ± 0.15
2.0 ± 0.15
#4
Ceramic Base
Metal Lid
#3
AKER
#1
#2
0.65 Max.
0.9
1.65
#4
#3
0.575
0.7
#2:GND
0.9
#2
0.65
#1
1.225
1.0
#4:GND
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: May 1, 2017
P/N:
www.aker-usa.com
C2E X1 Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
AKER
AKER
AKER
AKER
AKER
AKER
AKER
AKER
A
3.4
Pin #1
A
8.0
3.5
B
B
1.0
4.0
1.4
2.7
Dimensions
millimeters.
A-Aare
SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: May 1, 2017
P/N:
www.aker-usa.com
C2E X1 Series
How to build a Part Number:
Series
Package
C
2E
Frequency
12.000 to 60.000
Load Capacitance
7
10
12
16
18
S
Frequency Tolerance
Frequency Stability
50
100
Temperature Range
X1
Packaging
M
R
R3
Parameter
2.5 x 2.0 mm
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±50 PPM
±100 PPM
-40 to +125 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C2E-50.000-18-50100-X1-R
C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit
50.000 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
X1: -40 to +125° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape.
4- Specification subject to change without notice.
Page:
4/4
Date: May 1, 2017
P/N:
www.aker-usa.com
C2E X1 Series
C2E-40.000-12-50100-X1-CT 价格&库存
很抱歉,暂时无法提供与“C2E-40.000-12-50100-X1-CT”相匹配的价格&库存,您可以联系我们找货
