C6S-11.0592-18-3030-CT 数据手册
Ltr
RoHS Compliant
Pb - Lead Free
Appr
Date
Revisions
Electrical Specifications:
Frequency Range
Fundamental
Third Overtone
Standard
Mode of Oscillation
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
7.372 to 133.000
7.372 to 52.000
40.000 to 133.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10*
-10 to +70
-40 to +85
-55 to +125
±3
10 to 32 and Series Resonance
7.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
MHZ
PPM Max
PPM Max
ºC
PPM Max/Year
pF
Ohms
uW Typ
M Ohms
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
7.372 to 7.999
100
Fundamental
40.000 to 51.999
100
3rd Overtone
8.000 to 9.999
70
Fundamental
52.000 to 79.999
80
3rd Overtone
10.000 to 11.999
50
Fundamental
80.000 to 133.000
70
3rd Overtone
12.000 to 19.999
30
Fundamental
20.000 to 24.999
25
Fundamental
25.000 to 52.000
Fundamental
ESR Ohm Max Mode of Operation
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Dec 1, 2018
Microprocessor Crystal Unit
Low Profile
6.0 x 3.5 millimeter Surface Mount - 4 Pad
General Product Specification
Part Number:
C6S Series
www.aker-usa.com
Mechanical Outline:
Ceramic Base
6.0 ± 0.15
3.5 ± 0.15
Metal Lid
#4
#3
AKER
#1
#2
1.1 Max.
3.0
4.4
#2
#4
#3
1.35
#2:GND #4:GND
1.3
0.85
1.5
2.4
#1
1.8
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C6S Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
6.35
12.0
AKER
AKER
AKER
AKER
A
5.5
B
A
B
1.5
8.0
1.8
3.85
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C6S Series
How to build a Part Number:
Series
Package
Frequency
Load Capacitance
Standard
Frequency Tolerance
Option
Standard
Frequency Stability
Option
Mode of Oscillation
Standard
Temperature Range
Extended
Packaging
C
6S
7.372 to 133.000
10
12
16
18
S
30
25
15
10
50
30
25
15
10
See Notes
3
See Notes
X
M
R
Parameter
6.0 x 3.5 mm - 4 Pad
MHz
10 pF
12pF
16 pF
18 pF
20 pF
32 pF
Series
±30 PPM
±25 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±15 PPM
±10 PPM*
Fundamental
Third Overtone
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
Part Number Example:
C6S-80.000-S-3030-3-R
C6S: 3.5 x 6.0 mm SMD Seam Seal Package - 4 Pad
80.000 MHz Nominal Frequency
S: Series Resonance
3030: ±30 PPM Frequency Tolerance and ±30 PPM Frequency Stability
3: Third Overtone Mode
-10 to +70° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Fundamental mode does not need to be included in Part Number description.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces.
4- Quantities less than 1000 are shipped bulk in ESD pouches.
5- Specification subject to change without notice.
Page:
4/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C6S Series
C6S-11.0592-18-3030-CT 价格&库存
很抱歉,暂时无法提供与“C6S-11.0592-18-3030-CT”相匹配的价格&库存,您可以联系我们找货
