C3E-28.63636-8-50100-X1-M 数据手册
Ltr
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Date
Revisions
Appr
Electrical Specifications:
Frequency Range
Fundamental
Mode of Oscillation
Thrid Overtone
Frequency Tolerance at 25°C
Frequency Stability over Temperature Range
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
10.000 to 150.000
10.000 to 54.000
54.000 to 150.000
±50
±100
-40 to +125
-55 to +125
±3
7 to 32 and Series Resonance
3.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
PPM Max
ºC
PPM Max/Year
pF
Ohms
uW Typ
M Ohms
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
ESR Ohm Max
Mode of Operation
10.000 to 11.999
150
Fundamental
54.000 to 99.999
150
3rd Overtone
12.000 to 15.999
80
Fundamental
100.000 to 124.999
100
3rd Overtone
16.000 to 19.999
60
Fundamental
125.000 to 150.000
80
3rd Overtone
20.000 to 24.999
50
Fundamental
25.000 to 53.999
40
Fundamental
54.000 to 64.000
30
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Dec. 9, 2013
Microprocessor Crystal Unit
Automotive Temperature Range
Low Profile
3.2 x 2.5 millimeter Surface Mount
General Product Specification
Part Number:
C3E X1 Series
www.aker-usa.com
Mechanical Outline:
3.2 ± 0.15
Metal Lid
#3
#4
2.5 ± 0.15
Ceramic Base
AKER
#2
#1
0.75 Max.
2.2
1.2
#2
#4
#3
1.2
0.8
1.7
0.7
#1
0.9
#2:GND #4:GND
1.4
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Dec. 9, 2013
P/N:
C3E X1 Series
www.aker-usa.com
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Dec. 9, 2013
P/N:
C3E X1 Series
www.aker-usa.com
How to build a Part Number:
Series
Package
C
3E
Frequency
Load Capacitance
Frequency Tolerance
Frequency Stability
Mode of Oscillation
Temperature Range
Packaging
10.000 to 150.000
7
10
12
16
18
S
50
100
See Notes
3
X1
M
R
R3
Parameter
3.2 x 2.5 mm
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±50 PPM
±100 PPM
Fundamental
Third Overtone
-40 to +125 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C3E-25.000-18-50100-X1-R
C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit
25.000 MHz Nominal Frequency
18 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
X1: -40 to +125° C Temperature Range
R: Tape and Reel Packaging - 1000pcs
Notes:.
1- Product is shipped in Tape and Reel configuration.
2- Quantities less than 250pcs are shipped in tape.
3- Specification subject to change without notice.
4- Fundamental mode does not need to be included in Part Number description.
Page:
4/4
Date: Dec. 9, 2013
P/N:
www.aker-usa.com
C3E X1 Series
C3E-28.63636-8-50100-X1-M 价格&库存
很抱歉,暂时无法提供与“C3E-28.63636-8-50100-X1-M”相匹配的价格&库存,您可以联系我们找货
