SIT5157AI-FK-28VT-100.000000
    SITIME(赛特时脉)
    SMD5032_10P
    有源晶振 2.8V 100MHz SMD-10 ±500ppb
SIT5157AI-FK-28VT-100.000000 数据手册
SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Description Features The SiT5157 is a ±0.5 ppm to ±2.5 ppm MEMS Super-TCXO ◼ that is engineered for best dynamic performance. It is ideal for high reliability telecom, wireless and networking, industrial, precision GNSS and audio/video applications. ◼ Leveraging SiTime’s unique DualMEMS™ temperature sensing and TurboCompensation™ technologies, the SiT5157 delivers the best dynamic performance for timing stability in the presence of environmental stressors such as air flow, temperature perturbation, vibration, shock, and electromagnetic interference. This device also integrates multiple on-chip regulators to filter power supply noise, eliminating the need for a dedicated external LDO. The SiT5157 offers three device configurations that can be ordered using Ordering Codes for: ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Output 60–189 MHz, and 208–220 MHz, in 1 Hz steps Factory programmable options for short lead time Best dynamic stability under airflow, thermal shock ▪ ±0.5 ppm stability across temperature ▪ ±15 ppb/°C typical frequency slope (ΔF/ΔT) -40°C to +105°C operating temperature No activity dips or micro jumps Resistant to shock, vibration and board bending On-chip regulators eliminate the need for external LDOs Digital frequency pulling (DCTCXO) via I 2C ▪ Digital control of output frequency and pull range ▪ Up to ±3200 ppm pull range ▪ Frequency pull resolution down to 5 ppt 2.5 V, 2.8 V, 3.0 V and 3.3 V supply voltage LVCMOS output RoHS and REACH compliant, Pb-free, Halogen-free, Antimony-free Applications ◼ ◼ The SiT5157 can be factory programmed for any combination of frequency, stability, voltage, and pull range. Programmability enables designers to optimize clock configurations while eliminating long lead times and customization costs associated with quartz devices where each frequency is custom built. ◼ ◼ ◼ ◼ Precision GNSS systems Microwave backhaul Network routers and switches Professional audio and video equipment Storage and servers Test and measurement Refer to Manufacturing Guideline for proper reflow profile and PCB cleaning recommendations for best performance. Block Diagram 5.0 mm x 3.2 mm Package Pinout SDA / NC OE / VC / NC 1 SCL / NC 9 VDD 2 8 NC NC 3 7 NC GND 4 6 CLK 10 5 A0 / NC Figure 1. SiT5157 Block Diagram Rev 1.06 Figure 2. Pin Assignments (Top view) (Refer to Table 11 for Pin Descriptions) November 4, 2021 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Ordering Information The part number guide illustrated below is for reference only, in which boxes identify order codes having more than one option. To customize and build an exact part number, use the SiTime Part Number Generator. To validate the part number, use the SiTime Part Number Decoder. Package Size "F": 5.0 mm x 3.2 mm Pin 1 Function – TCXO mode only Output Waveform "-" : LVCMOS[1] "E": Output Enable "N": No Connect Silicon Revision Letter Part Family TCXO VCTCXO DCTCXO SiT5157AC - FK - 33 E 0 - 98.123456 T SiT5157AC - FK - 33 V T - 98.123456 T SiT5157AC - FKG33 J R - 98.123456 T "I": Industrial, -40 to 85°C "C": Extended Commercial, -20 to 70°C "E": Extended Industrial, -40 to 105°C Packaging "T": 12 mm Tape & Reel, 3 ku reel "Y": 12 mm Tape & Reel, 1 ku reel “X”: 12 mm Tape & Reel, 250 u reel (blank): bulk[2] Frequency Stability Frequency "K": for ±0.5 ppm "A": for ±1.0 ppm "D": for ±2.5 ppm 60.000001 MHz to 189.000000 MHz 208.000000 MHz to 220.000000 MHz Temperature Range Pull Range – DCTCXO mode only I2C Address Mode – DCTCXO mode only "T": ±6.25 ppm "R": ±10 ppm "Q": ±12.5 ppm "M": ±25 ppm "B": ±50 ppm "C": ±80 ppm "E": ±100 ppm "F": ±125 ppm “0”, “1”, “2”, “3”, “4”, “5”, “6”, “7”, “8”, “9”, “A”, “B”, “C”, “D”, “E”, “F”: Order code representing hex value of I2C address. When the I2C address is factory programmed using this code, pin A0 is no connect (NC). “G”: I2C pin addressable mode. Address is set by the logic on A0 pin. "G": "H": "X": "L": "Y": "S": "Z": "U": ±150 ppm ±200 ppm ±400 ppm ±600 ppm ±800 ppm ±1200 ppm ±1600 ppm ±3200 ppm Pin 1 Function – DCTCXO mode only Supply Voltage "I": Output Enable "J": No Connect, software OE control "25": 2.5 V ±10% "28": 2.8 V ±10% "30": 3.0 V ±10% "33": 3.3 V ±10% Notes: 1. “-“ corresponds to the default rise/fall time for LVCMOS output as specified in Table 1 (Electrical Characteristics). Contact SiTime for other rise/fall time options for best EMI or driving multiple loads. For differential outputs, contact SiTime. 2. Bulk is available for sampling only. Rev 1.06 Page 2 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO TABLE OF CONTENTS Description........................................................................................................................................................................... 1 Features .............................................................................................................................................................................. 1 Applications ......................................................................................................................................................................... 1 Block Diagram ..................................................................................................................................................................... 1 5.0 mm x 3.2 mm Package Pinout ........................................................................................................................................ 1 Ordering Information ............................................................................................................................................................ 2 Electrical Characteristics ...................................................................................................................................................... 4 Device Configurations and Pin-outs ...................................................................................................................................... 8 Pin-out Top Views ......................................................................................................................................................... 8 Test Circuit Diagrams for LVCMOS Outputs .......................................................................................................................... 9 Waveforms ........................................................................................................................................................................ 10 Timing Diagrams ................................................................................................................................................................ 10 Typical Performance Plots .................................................................................................................................................. 11 Architecture Overview ........................................................................................................................................................ 12 Frequency Stability .......................................................................................................................................................12 Output Frequency and Format ......................................................................................................................................12 Output Frequency Tuning .............................................................................................................................................12 Pin 1 Configuration (OE, VC, or NC) .............................................................................................................................13 Device Configurations ........................................................................................................................................................ 13 TCXO Configuration .....................................................................................................................................................13 VCTCXO Configuration ................................................................................................................................................14 DCTCXO Configuration ................................................................................................................................................15 VCTCXO-Specific Design Considerations ........................................................................................................................... 16 Linearity .......................................................................................................................................................................16 Control Voltage Bandwidth ...........................................................................................................................................16 FV Characteristic Slope KV ...........................................................................................................................................16 Pull Range, Absolute Pull Range ..................................................................................................................................17 DCTCXO-Specific Design Considerations ........................................................................................................................... 18 Pull Range and Absolute Pull Range.............................................................................................................................18 Output Frequency.........................................................................................................................................................19 I2C Control Registers ....................................................................................................................................................21 Register Descriptions ...................................................................................................................................................21 Register Address: 0x00. Digital Frequency Control Least Significant Word (LSW) ..........................................................21 Register Address: 0x01. OE Control, Digital Frequency Control Most Significant Word (MSW) ........................................22 Register Address: 0x02. DIGITAL PULL RANGE CONTROL[15] .....................................................................................23 Serial Interface Configuration Description......................................................................................................................24 Serial Signal Format .....................................................................................................................................................24 Parallel Signal Format ..................................................................................................................................................25 Parallel Data Format.....................................................................................................................................................25 I2C Timing Specification................................................................................................................................................27 I2C Device Address Modes ...........................................................................................................................................28 Schematic Example ......................................................................................................................................................29 Dimensions and Patterns.................................................................................................................................................... 30 Layout Guidelines .............................................................................................................................................................. 31 Manufacturing Guidelines ................................................................................................................................................... 31 Additional Information......................................................................................................................................................... 32 Revision History ................................................................................................................................................................. 33 Rev 1.06 Page 3 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and 3.3 V Vdd. Table 1. Output Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Frequency Coverage Nominal Output Frequency Range F_nom 60.000001 – 189 MHz 208 – 220 MHz Temperature Range Operating Temperature Range T_use -20 – +70 °C -40 – +85 °C Industrial, ambient temperature -40 – +105 °C Extended Industrial, ambient temperature Extended Commercial, ambient temperature Frequency Stability Frequency Stability over Temperature F_stab – – ±0.5 ppm – – ±1.0 ppm Referenced to (max frequency + min frequency)/2 over the rated temperature range. Vc=Vdd/2 for VCTCXO – – ±2.5 ppm Initial Tolerance F_init – – ±1 ppm Initial frequency at 25°C at 48 hours after 2 reflows Supply Voltage Sensitivity F_Vdd – ±11.0 ±26.0 ppb ±0.5 ppm F_stab, Vdd ±5% – ±18.3 ±52 ppb ±1.0 ppm F_stab, Vdd ±5% – ±43.9 ±104.0 ppb ±2.5 ppm F_stab, Vdd ±5% – ±3.1 ±10.5 ppb ±0.5 ppm F_stab. LVCMOS output, 15 pF ±10% – ±5.08 ±21.0 ppb ±1.0 ppm F_stab. LVCMOS output, 15 pF ±10% – ±12.2 ±42.0 ppb ±2.5 ppm F_stab. LVCMOS output, 15 pF ±10% – ±15 ±25 ppb/°C ±0.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C – ±25 ±50 ppb/°C ±1.0 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C – ±60 ±100 ppb/°C ±2.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C – ±0.13 ±0.21 ppb/s ±0.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C – ±0.21 ±0.42 ppb/s ±1.0 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C – ±0.50 ±0.83 ppb/s ±2.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C Output Load Sensitivity Frequency vs. Temperature Slope Dynamic Frequency Change during Temperature Ramp F_load ΔF/ΔT F_dynamic One-Year Aging F_1y – ±1 – ppm At 25°C, after 2-days of continued operation. Aging is measured with respect to day 3 20-Year Aging F_20y – ±2 – ppm At 25°C, after 2-days of continued operation. Aging is measured with respect to day 3 DC 45 – 55 % 60 to 150 MHz 42 – 55 % 150 to 189 MHz, 208 to 220 MHz 10% - 90% Vdd LVCMOS Output Characteristics Duty Cycle Rise/Fall Time Tr, Tf 0.8 1.2 1.9 ns Output Voltage High VOH 90% – – Vdd Output Voltage Low VOL – – 10% Vdd Z_out_c – 17 – Ohms Impedance looking into output buffer, Vdd = 3.3 V – 17 – Ohms Impedance looking into output buffer, Vdd = 3.0 V – 18 – Ohms Impedance looking into output buffer, Vdd = 2.8 V – 19 – Ohms Impedance looking into output buffer, Vdd = 2.5 V Output Impedance IOH = +3 mA IOL = -3 mA Start-up Characteristics Start-up Time Output Enable Time Time to Rated Frequency Stability Rev 1.06 T_start – 2.5 3.5 T_oe – – T_stability – 5 ms Time to first pulse, measured from the time Vdd reaches 90% of its final value. Vdd ramp time = 100 µs from 0 V to Vdd 285 ns See Timing Diagrams section below. 45 ms Time to first accurate pulse within rated stability, measured from the time Vdd reaches 90% of its final value. Vdd ramp time = 100 µs Page 4 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Table 2. DC Characteristics Parameters Symbol Min. Typ. Max. Unit Condition Supply Voltage Supply Voltage Vdd 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V Contact SiTime for 2.25 V to 3.63 V continuous supply voltage support Current Consumption Current Consumption OE Disable Current Idd I_od – 48 62 mA F_nom = 100 MHz, No Load, TCXO and DCTCXO modes – 52 66 mA F_nom = 100 MHz, No Load, VCTCXO mode – 45 52 mA OE = GND, output weakly pulled down. TCXO, DCTCXO – 49 56 mA OE = GND, output weakly pulled down. VCTCXO mode Typ. Max. Unit Table 3. Input Characteristics Parameters Symbol Min. Condition Input Characteristics – OE Pin Input Impedance Z_in 75 – – kΩ Input High Voltage VIH 70% – – Vdd Input Low Voltage VIL – – 30% Vdd Internal pull up to Vdd Frequency Tuning Range – Voltage Control or I2C mode Pull Range Absolute Pull Range[3] PR APR ±6.25 – – ppm VCTCXO mode; contact SiTime for ±12.5 and ±25 ppm ±6.25 ±10 ±12.5 ±25 ±50 ±80 ±100 ±125 ±150 ±200 ±400 ±600 ±800 ±1200 ±1600 ±3200 – – ppm DCTCXO mode ±2.75 – – ppm ±0.5 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm ±2.25 – – ppm ±1.0 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm ±0.75 – – ppm ±2.5 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm Upper Control Voltage VC_U 90% – – Vdd VCTCXO mode Lower Control Voltage VC_L – – 10% Vdd VCTCXO mode Control Voltage Input Impedance VC_z 8 – – MΩ VCTCXO mode Control Voltage Input Bandwidth VC_bw – 10 – kHz VCTCXO mode; contact SiTime for other bandwidth options 1.0 % Frequency Control Polarity F_pol Pull Range Linearity PR_lin Positive – 0.5 VCTCXO mode VCTCXO mode I2C Interface Characteristics, 200 Ohm, 550 pF (Max I2C Bus Load) Bus Speed F_I2C ≤ 400 kHz -40 to 105°C ≤ 1000 kHz -40 to 85°C Input Voltage Low VIL_I2C – – 30% Vdd DCTCXO mode Input Voltage High VIH_I2C 70% – – Vdd DCTCXO mode Output Voltage Low VOL_I2C – – 0.4 V DCTCXO mode IL 0.5 – 24 µA 0.1 VDD< VOUT < 0.9 VDD. Includes typical leakage current from 200 kΩ pull resister to VDD; DCTCXO mode CIN – – 5 pF DCTCXO mode Input Leakage current Input Capacitance Note: 3. APR = PR – initial tolerance – 20-year aging – frequency stability over temperature. Refer to Table 14 for APR with respect to other pull range options. Rev 1.06 Page 5 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Table 4. Jitter & Phase Noise, -40°C to 85°C Parameters Symbol Min. Typ. Max. Unit Condition Jitter T_phj – 0.31 0.48 ps F_nom = 100 MHz, Integration bandwidth = 12 kHz to 20 MHz RMS Period Jitter T_jitt_per – 1.0 1.8 ps F_nom = 100 MHz, population 10 k Peak Cycle-to-Cycle Jitter T_jitt_cc – 6.6 13.4 ps F_nom = 100 MHz, population 1 k, measured as absolute value 1 Hz offset – -61 -54 dBc/Hz 10 Hz offset – -89 -83 dBc/Hz 100 Hz offset – -107 -103 dBc/Hz 1 kHz offset – -128 -124 dBc/Hz 10 kHz offset – -133 -131 dBc/Hz 100 kHz offset – -133 -130 dBc/Hz 1 MHz offset – -150 -146 dBc/Hz 5 MHz offset – -157 -151 dBc/Hz 10 MHz offset – -157 -152 dBc/Hz 20 MHz offset – -159 -152 dBc/Hz – -91 -86 dBc Min. Typ. Max. Unit Condition RMS Phase Jitter (random) Phase Noise T_spur Spurious F_nom = 100 MHz TCXO and DCTCXO modes, and VCTCXO mode with ±6.25 ppm pull range F_nom = 100 MHz, 1 kHz to 40 MHz offsets Table 5. Jitter & Phase Noise, -40°C to 105°C Parameters Symbol Jitter T_phj – 0.31 0.50 ps F_nom = 100 MHz, Integration bandwidth = 12 kHz to 20 MHz RMS Period Jitter T_jitt_per – 1.0 1.8 ps F_nom = 100 MHz, population 10 k Peak Cycle-to-Cycle Jitter T_jitt_cc – 6.6 13.4 ps F_nom = 100 MHz, population 1 k, measured as absolute value 1 Hz offset – -61 -54 dBc/Hz 10 Hz offset – -89 -83 dBc/Hz 100 Hz offset – -107 -103 dBc/Hz 1 kHz offset – -128 -124 dBc/Hz 10 kHz offset – -133 -131 dBc/Hz 100 kHz offset – -133 -130 dBc/Hz 1 MHz offset – -150 -144 dBc/Hz 5 MHz offset – -157 -150 dBc/Hz 10 MHz offset – -157 -150 dBc/Hz 20 MHz offset – -159 -150 dBc/Hz – -91 -85 dBc RMS Phase Jitter (random) Phase Noise Spurious Rev 1.06 T_spur Page 6 of 33 F_nom = 100 MHz TCXO and DCTCXO modes, and VCTCXO mode with ±6.25 ppm pull range F_nom = 100 MHz, 1 kHz to 40 MHz offsets www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Table 6. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Test Conditions Storage Temperature Continuous Power Supply Voltage Range (Vdd) Human Body Model (HBM) ESD Protection JESD22-A114 Soldering Temperature (follow standard Pb-free soldering guidelines) Value Unit -65 to 125 °C -0.5 to 4 V 2000 V 260 °C 130 °C Input Voltage, Maximum Any input pin Vdd + 0.3 V Input Voltage, Minimum Any input pin -0.3 V Junction Temperature[4] Note: 4. Exceeding this temperature for an extended period of time may damage the device. Table 7. Thermal Considerations[5] Package JA[6] (°C/W) JC, Bottom (°C/W) Ceramic 5.0 mm x 3.2 mm 54 15 Note: 5. Measured in still air. Refer to JESD51 for θJA and θJC definitions. 6. Devices soldered on a JESD51 2s2p compliant board. Table 8. Maximum Operating Junction Temperature[7] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 70°C 80°C 85°C 95°C 105°C 115°C Note: 7. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 9. Environmental Compliance Value Unit Mechanical Shock Resistance Parameter MIL-STD-883F, Method 2002 30000 g Mechanical Vibration Resistance MIL-STD-883F, Method 2007 70 g Temperature Cycle JESD22, Method A104 – – Solderability MIL-STD-883F, Method 2003 – – Moisture Sensitivity Level MSL1 @260°C – – Rev 1.06 Test Conditions Page 7 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Device Configurations and Pin-outs Table 10. Device Configurations I2C Programmable Parameters Configuration Pin 1 Pin 5 TCXO OE/NC NC – – VCTCXO VC NC DCTCXO OE/NC A0/NC Frequency Pull Range, Frequency Pull Value, Output Enable control. Pin-out Top Views NC NC 9 VDD VC 1 2 8 NC NC NC 3 7 NC GND 4 6 CLK OE/NC 1 NC 10 5 SDA 9 VDD 2 8 NC 3 GND 4 10 5 OE / NC 1 NC SCL 7 NC 6 CLK 9 VDD 2 8 NC NC 3 7 NC GND 4 6 CLK 10 5 A0 / NC NC NC Figure 3. TCXO Figure 4. VCTCXO Figure 5. DCTCXO Table 11. Pin Description Pin 1 Symbol OE/NC [10]/VC I/O Internal Pull-up/Pull Down Resistor Function H[8]: specified frequency output L: output is high impedance. Only output driver is disabled. OE – Input 100 kΩ Pull-Up NC – No Connect – H or L or Open: No effect on output frequency or other device functions VC – Input – Control Voltage in VCTCXO Mode SCL – Input 200 kΩ Pull-Up I2C serial clock input. 2 SCL / NC [10] 3 NC[10] No Connect – H or L or Open: No effect on output frequency or other device functions 4 GND Power – Connect to ground No Connect H or L or Open: No effect on output frequency or other device functions Device I2C address when the address selection mode is via the A0 pin. This pin is NC when the I2C device address is specified in the ordering code. A0 Logic Level I2C Address 0 1100010 1 1101010 A0 – Input 100 kΩ Pull-Up NC – No Connect – H or L or Open: No effect on output frequency or other device functions . Output – LVCMOS 7 NC[10] No Connect – H or L or Open: No effect on output frequency or other device functions 8 NC[10] No Connect – H or L or Open: No effect on output frequency or other device functions 9 VDD Power – Connect to power supply[9] SDA – Input/Output 200 kΩ Pull Up 10 SDA / NC [10] NC – No Connect – 5 A0 / NC [10] 6 CLK I2C Serial Data. H or L or Open: No effect on output frequency or other device functions. Notes: 8. In OE mode for noisy environments, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. 9. A 0.1 μF capacitor in parallel with a 10 μF capacitor are required between VDD and GND. The 0.1 μF capacitor is recommended to place close to the device, and place the 10 μF capacitor less than 2 inches away. 10. All NC pins can be left floating and do not need to be soldered down. Rev 1.06 Page 8 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Test Circuit Diagrams for LVCMOS Outputs VDD 9 + 8 7 VDD 6 10 10µF 1 5 2 3 9 + 0.1µF Power Supply - Test Point CLK (including probe and fixture capacitance) 4 8 7 6 2 3 4 Test Point 0.1µF Power Supply 15pF CLK 10 5 10µF - 1 15pF (including probe and fixture capacitance) Control Voltage Vdd OE Function VC Function Figure 7. LVCMOS Test Circuit (VC Function) Figure 6. LVCMOS Test Circuit (OE Function) VDD 9 + 8 7 6 2 3 4 0.1µF Power Supply 10 10µF - Test Point CLK 5 1 15pF (including probe and fixture capacitance) Any state or floating NC Function Figure 8. LVCMOS Test Circuit (NC Function) VDD 9 + 8 7 6 A0/NC 0.1µF Power Supply - Test Point CLK 10 10µF SDA 1 [11] Any state or floating NC Function 5 2 3 4 15pF (including probe and fixture capacitance) SCL Figure 9. LVCMOS Test Circuit (I2C Control), DCTCXO mode for AC and DC Measurements Note: 11. SDA is open-drain and may require pull-up resistor if not present in I2C test setup. Rev 1.06 Page 9 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Waveforms tr tf 90 % Vdd 50 % Vdd 10 % Vdd High Pulse (TH) Low Pulse (TL) Period Figure 10. LVCMOS Waveform Diagram[12] Note: 12. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd T_start Vdd Pin Voltage OE Voltage CLK Output CLK Output HZ HZ T_start: Time to start from power-off T_oe: Time to re-enable the clock output Figure 11. Startup Timing Rev 1.06 T_oe Figure 12. OE Enable Timing (OE Mode Only) Page 10 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Typical Performance Plots 2.5 V 55 2.8 V 3.0 V 3.3 V 2.5 V Current consumption (mA) 53 Duty cycle (%) 2.8 V 51 49 47 45 3.3 V 56 54 52 50 48 46 44 42 40 70 90 110 130 150 170 190 210 70 90 110 Frequency (MHz) 2.5 V 2.8 V 130 150 170 190 210 Frequency (MHz) Figure 13. Duty Cycle (LVCMOS) 3.0 V Figure 14. IDD DCTCXO (LVCMOS) 3.3 V 2.5 V 2.8 V 3.0 V 3.3 V 60 Current consumption (mA) 58 Current consumption (mA) 3.0 V 58 56 54 52 50 48 46 44 42 40 58 56 54 52 50 48 46 70 90 110 130 150 170 190 210 70 90 110 Frequency (MHz) Figure 15. IDD TCXO (LVCMOS) 2.5 V 500 2.8 V 130 150 170 190 210 Frequency (MHz) Figure 16. IDD VCTCXO (LVCMOS) 3.0 V 2.5 V 3.3 V 3.3 V Period Jitter (ps RMS) Phase Jitter (fs RMS) 1.90 400 300 200 100 1.70 1.50 1.30 1.10 0.90 0.70 0.50 0 70 90 110 130 150 170 190 70 210 90 Frequency (MHz) 2.8 V 3.0 V Frequency deviation (ppm) Phase Jitter (fs RMS) 400 300 200 100 0 120 170 220 Frequency (MHz) 170 190 210 6.25 5 3.75 2.5 1.25 0 -1.25 -2.5 -3.75 -5 -6.25 -6.25 -5 -3.75 -2.5 -1.25 0 1.25 2.5 3.75 5 6.25 DCTCXO pull (ppm) Figure 19. RMS Phase Jitter, VCTCXO (LVCMOS) Rev 1.06 150 Figure 18. RMS Period Jitter (LVCMOS) 3.3 V 500 70 130 Frequency (MHz) Figure 17. RMS Phase Jitter, DCTCXO, TCXO (LVCMOS) 2.5 V 110 Figure 20. DCTCXO frequency pull characteristic Page 11 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Architecture Overview Functional Overview Based on SiTime’s innovative Elite Platform™, the SiT5157 delivers exceptional dynamic performance, i.e. resilience to environmental stressors such as shock, vibration, and fast temperature transients. Underpinning the Elite platform are SiTime’s unique DualMEMS™ temperature sensing architecture and TurboCompensation™ technologies. The SiT5157 is designed for maximum flexibility with an array of factory programmable options, enabling system designers to configure this precision device for optimal performance in a given application. DualMEMS is a noiseless temperature compensation scheme. It consists of two MEMS resonators fabricated on the same die substrate. The TempFlat™ MEMS resonator is designed with a flat frequency characteristic over temperature whereas the temperature sensing resonator is by design sensitive to temperature changes. The ratio of frequencies between these two resonators provides an accurate reading of the resonator temperature with 20 µK resolution. Frequency Stability The SiT5157 comes in three factory-trimmed stability grades. Table 12. Stability Grades vs. Ordering Codes Frequency Stability Over Temperature Ordering Code ±0.5 ppm K ±1.0 ppm A ±2.5 ppm D Output Frequency and Format By placing the two MEMS resonators on the same die, this temperature sensing scheme eliminates any thermal lag and gradients between resonator and temperature sensor, thereby overcoming an inherent weakness of legacy quartz TCXOs. The SiT5157 can be factory programmed for an output frequency without sacrificing lead time or incurring an upfront customization cost typically associated with customfrequency quartz TCXOs. The DualMEMS temperature sensor drives a state-of-theart CMOS temperature compensation circuit. The TurboCompensation design, with >100 Hz compensation bandwidth, achieves a dynamic frequency stability that is far superior to any quartz TCXO. The digital temperature compensation enables additional optimization of frequency stability and frequency slope over temperature within any chosen temperature range for a given system design. In addition to the non-pullable TCXO, the SiT5157 can also support output frequency tuning through either an analog control voltage (VCTCXO), or I2C interface (DCTCXO). The I2C interface enables 16 factory programmed pull-range options from ±6.25 ppm to ±3200 ppm. The pull range can also be reprogrammed via I2C to any supported pull-range value. The Elite platform also incorporates a high resolution, low noise frequency synthesizer along with the industry standard I2C bus. This unique combination enables system designers to digitally control the output frequency in steps as low as 5 ppt and over a wide range up to ±3200 ppm. Output Frequency Tuning Refer to Device Configuration section for details. For more information regarding the Elite platform and its benefits please visit: ◼ SiTime's breakthroughs section ◼ TechPaper: DualMEMS Temperature Sensing Technology ◼ TechPaper: DualMEMS Resonator TDC Rev 1.06 Page 12 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Device Configurations Pin 1 Configuration (OE, VC, or NC) Pin 1 of the SiT5157 can be factory programmed to support three modes: Output Enable (OE), Voltage Control (VC), or No Connect (NC). Table 13. Pin Configuration Options Pin 1 Configuration Operating Mode Output OE TCXO/DCTCXO Active or High-Z NC TCXO/DCTCXO Active VC VCTCXO Active The SiT5157 supports 3 device configurations – TCXO, VCTCXO, and DCTCXO. The TCXO and VCTCXO options are directly compatible with the quartz TCXO and VCTCXO. The DCTCXO configuration provides performance enhancement by eliminating VCTCXO’s sensitivity to control voltage noise with an I2C digital interface for frequency tuning. When pin 1 is configured as OE pin, the device output is guaranteed to operate in one of the following two states: ◼ Clock output with the frequency specified in the part number when Pin 1 is pulled to logic high ◼ Hi-Z mode with weak pull down when pin 1 is pulled to logic low. When pin 1 is configured as NC, the device is guaranteed to output the frequency specified in the part number at all times, regardless of the logic level on pin 1. In the VCTCXO configuration, the user can fine-tune the output frequency from the nominal frequency specified in the part number by varying the pin 1 voltage. The guaranteed allowable variation of the output frequency is specified as pull range. A VCTCXO part number must contain a valid pullrange ordering code. Figure 21. Block Diagram – TCXO TCXO Configuration The TCXO generates a fixed frequency output, as shown in Figure 21. The frequency is specified by the user in the frequency field of the device ordering code and then factory programmed. Other factory programmable options include supply voltage, and pin 1 functionality (OE or NC). Refer to the Ordering Information section at the end of the datasheet for a list of all ordering options. Rev 1.06 Page 13 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO VCTCXO Configuration A VCTCXO, shown in Figure 22, is a frequency control device whose output frequency is an approximately linear function of control voltage applied to the voltage control pin. VCTCXOs have a number of use cases including the VCO portion of a jitter attenuation/jitter cleaner PLL Loop. The SiT5157 achieves a 10x better pull range linearity of 250 nsec FM+ (1 MHz) >0 nsec FM (400 KHz) >0 nsec SM (100 KHz) >0 nsec FM+ > 450 nsec FM (400 KHz) > 900 nsec SM (100 KHz) > 3450 nsec tHOLD tVD:AWK tVD:DAT Rev 1.06 NA (s-awk + s-data)/(m-awk/s-data) Page 27 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Table 21. Pin Selectable I2C Address Control [17] I2C Device Address Modes A0 Pin 5 There are two I2C address modes: I2C Address 0 1100010 1 1101010 Notes: 17. Table 21 is only valid for the DCTCXO device option which supports I2C control and A0 Device Address Control Pin. Table 20. Factory Programmed I2C Address Control [16] I2C Address Ordering Code Device I2C Address 0 1100000 1 1100001 2 1100010 3 1100011 4 1100100 5 1100101 6 1100110 7 1100111 8 1101000 9 1101001 A 1101010 B 1101011 C 1101100 D 1101101 E 1101110 F 1101111 Notes: 16. Table 20 is only valid for the DCTCXO device option which supports I2C Control. Rev 1.06 Page 28 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Schematic Example Figure 35. DCTCXO schematic example Rev 1.06 Page 29 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Dimensions and Patterns Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) Rev 1.06 Page 30 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Manufacturing Guidelines Layout Guidelines ◼ ◼ ◼ The SiT5157 uses internal regulators to minimize the impact of power supply noise. For further reduction of noise, it is essential to use two bypass capacitors (0.1 μF and 10 μF). Place the 0.1 uF capacitor as close to the VDD pin as possible, typically within 1 mm to 2 mm. Place the 10 uF capacitor within 2 inches of the device VDD and VSS pins. It is also recommended to connect all NC pins to the ground plane and place multiple vias under the GND pin for maximum heat dissipation. The SiT5157 Super-TCXOs are precision timing devices. Proper PCB solder and cleaning processes must be followed to ensure best performance and long-term reliability. ◼ No Ultrasonic or Megasonic Cleaning: Do not subject the SiT5157 to an ultrasonic or megasonic cleaning environment. Otherwise, permanent damage or long-term reliability issues to the device may result. ◼ No external cover. Unlike legacy quartz TCXOs, the SiT5157 is engineered to operate reliably, without performance degradation in the presence of ambient disturbers such as airflow and sudden temperature changes. Therefore, the use of an external cover typically required by quartz TCXOs is not needed. ◼ Reflow profile: For mounting these devices to the PCB, IPC/JEDEC J-STD-020 compliant reflow profile must be used. Device performance is not guaranteed if soldered manually or with a non-compliant reflow profile. ◼ PCB cleaning: After the surface mount (SMT)/reflow process, solder flux residues may be present on the PCB and around the pads of the device. Excess residual solder flux may lead to problems such as pad corrosion, elevated leakage currents, increased frequency aging, or other performance degradation. For optimal device performance and long-term reliability, thorough cleaning to remove all the residual flux and drying of the PCB is required as shortly after the reflow process as possible. Water soluble flux is recommended. In addition, it is highly recommended to avoid the use of any “no clean” flux. However, if the reflow process necessitates the use of “no clean” flux, then utmost care should be taken to remove all residual flux between SiTime device and the PCB. Note that ultrasonic PCB cleaning should not be used with SiTime oscillators. ◼ For additional manufacturing guidelines and marking/ tape-reel instructions, refer to SiTime Manufacturing Notes. For additional layout recommendations, refer to the Best Design Layout Practices. Rev 1.06 Page 31 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Additional Information Table 22. Additional Information Document Description Download Link ECCN #: EAR99 Five character designation used on the commerce Control List (CCL) to identify dual use items for export control purposes. — HTS Classification Code: 8542.39.0000 A Harmonized Tariff Schedule (HTS) code developed by — the World Customs Organization to classify/define internationally traded goods. Evaluation Boards SiT6722EB Evaluation Board User Manual https://www.sitime.com/support/user-guides Demo Board SiT6702DB Demo Board User Manual https://www.sitime.com/support/user-guides Time Machine II MEMS oscillator programmer http://www.sitime.com/support/time-machine-oscillator-programmer Time Master Web-based Configurator Web tool to establish proper programming https://www.sitime.com/time-master-web-based-configurator Manufacturing Notes Tape & Reel dimension, reflow profile and other manufacturing related info https://www.sitime.com/support/resource-library?filter=531 Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques Layout recommendations http://www.sitime.com/support/application-notes Rev 1.06 Page 32 of 33 www.sitime.com SiT5157 60 MHz to 220 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO Revision History Table 23. Revision History Version Release Date 0.1 05/10/2016 First release, advanced information 0.15 08/04/2016 Replaced QFN package with SOIC-8 package Added 10 µF bypass cap requirement Updated test circuits to reflect both new bypass cap requirement and SOIC-8 package Update Table 1 (Electrical Characteristics) 0.16 09/12/2016 Updated test circuit diagrams 0.2 09/21/2016 Revised Table 1 (Electrical Characteristics) 0.51 08/20/2017 Changed to preliminary Added DCTCXO mode Added I2C information Added 5.0 mm x 3.2 mm package information Updated test circuits Updated Table 1 (Electrical Characteristics) Updated part ordering info Misc. corrections 0.52 11/27/2017 Updated the Thermal Characteristics table Added more on Manufacturing Guideline section 0.55 02/05/2018 Added View labels to Package Drawings Updated links and notes 0.60 03/01/2018 1.0 07/02/2018 1.01 1.02 07/06/2018 08/02/2018 1.03 12/04/2018 1.04 03/28/2020 1.05 1.06 05/29/2020 11/04/2021 Added 105°C support, updated Ordering Information Updated Electrical Characteristics tables. Added Typical Performance Plots. Improved readability. Fixed bad hyperlinks. Updated Mechanical Shock Resistance, Table 9 (Environmental Compliance). Various formatting updates. Revised phase noise specifications. Updated package outline drawing. Updated conditions for one day and one year aging specs. Formatting updates Fixed APR typo for 125 ppm pull range and 0.5 ppm stability, Table 15 Corrected typos in package drawing dimensions Added nominal value for LVCMOS output impedance Increased Mechanical Shock Resistance to 30000g Added “X” order code for 250u Tape and Reel Improved I2C bus frequency specification Updated Manufacturing Guidelines to recommend water soluble flux Corrected typos for write/read I2C polarity Clarified PCB cleaning instructions Added link to SiT6702DB Added ECCN and HTS codes Modified supply and load sensitivities Formatting changes Added note for Theta Ja Updated DCTCXO Delay and Settling Time table Removed frequency support from 200 to 208 MHz Added max and min input voltage to Absolute Maximum Limits table Updated output impedance typical spec Clarified Initial Tolerance specification condition Relabeled “First Pulse Accuracy” parameter to “Time to Rated Frequency Stability” for clarity Revised Parallel Data Format section description and figures Resolved a typographical error in the frequency range listing in the ordering code Rev 1.06 Change Summary Page 33 of 33 www.sitime.com
SIT5157AI-FK-28VT-100.000000 价格&库存
很抱歉,暂时无法提供与“SIT5157AI-FK-28VT-100.000000”相匹配的价格&库存,您可以联系我们找货
