C2E-38.4000-8-1015-X-R3
    AKER(安碁)
    SMD2520_4P
    无源晶振 70Ω 8pF ±10ppm -40℃~+85℃ 38.4MHz SMD2520_4P
C2E-38.4000-8-1015-X-R3 数据手册
RoHS Compliant Pb - Lead Free Ltr Revisions Date Electrical Specifications: Frequency Range Mode of Oscillation Fundamental Standard Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Operating Temperature Range Standard Extended Storage Temperature Range Aging per Year Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 12.000 to 60.000 12.000 to 60.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15 ±10* -10 to +70 -40 to +85 -55 to +125 ±3 7 to 32 and Series Resonance 3.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz PPM Max (Note 1) PPM Max (Note 1) ºC PPM Max pF Ohms uW Typ M Ohms Frequency Range and ESR Values: Frequency Range in MHz 12.000 14.000 16.000 20.000 24.000 25.000 45.000 to to to to to to to ESR Ohm Max Mode of Operation 200 150 Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental Fundamental 13.999 15.999 19.999 23.999 24.999 44.999 60.000 90 70 60 50 40 Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: May 1, 2013 Microprocessor Crystal Unit Low Profile 2.5 x 2.0 millimeter Surface Mount General Product Specification Part Number: C2E Series www.aker-usa.com Appr Mechanical Outline: 2.5 ± 0.15 2.0 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 0.65 Max. 0.9 1.65 #4 #3 0.575 0.9 #2 0.65 #1 1.225 1.0 0.7 #2:GND #4:GND Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: May 1, 2013 P/N: www.aker-usa.com C2E Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 3.4 Pin #1 A 8.0 3.5 B B 1.0 4.0 1.4 2.7 Dimensions millimeters. A-Aare SECTION Solder Reflow Characteristics: Page: 3/4 Date: May 1, 2013 P/N: www.aker-usa.com C2E Series How to build a Part Number: Series Package C 2E Frequency 12.000 to 60.000 Load Capacitance Standard Frequency Tolerance (Note 1) Optional Standard Frequency Stability (Note 1) Optional Standard Temperature Range Extended Packaging 7 10 12 16 18 20 32 S 30 25 20 15 10 50 30 25 20 15 10 See Notes X M R R3 - - - Parameter 2.5 x 2.0 mm MHz 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±30 PPM ±25 PPM ±20 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±20 PPM ±15 PPM ±10 PPM* -10 to +70 ºC -40 to +85 ºC 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: C2E-50.000-18-3050-R C2E- 2.0 x 2.5 mm SMD Seam Seal Crystal Unit 50.000 MHz Nominal Frequency 18 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability Fundamental Mode -10 to +70° C Temperature Range R: Tape and Reel Packaging Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. * ±10 PPM Temperature Stability is only available from -30 to +85° C. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. 4- Quantities less than 250pcs are shipped in tape. 5- Specification subject to change without notice. Page: 4/4 Date: May 1, 2013 P/N: www.aker-usa.com C2E Series
- 物料型号:C2E系列,2.5 x 2.0毫米表面贴装通用产品规格。 - 器件简介:这是一种低剖面微处理器晶体单元,具有金属盖和陶瓷基座。 - 引脚分配:文档中提到了#1和#2引脚,其中#2是接地引脚。 - 参数特性:包括频率范围12.000至60.000 MHz,负载电容7至32皮法拉和串联谐振,以及等效串联电阻(ESR)值。 - 功能详解:晶体单元在25°C时的标准频率容差和频率稳定性,以及在不同温度范围内的稳定性。 - 应用信息:适用于微处理器时钟应用。 - 封装信息:提供了详细的机械轮廓和尺寸,以及焊接再流特性。
C2E-38.4000-8-1015-X-R3 价格&库存
很抱歉,暂时无法提供与“C2E-38.4000-8-1015-X-R3”相匹配的价格&库存,您可以联系我们找货
