C3E-12.000-12-50100-X1-M
    AKER(安碁科技)
    SMD3225_4P
    无源晶振 12MHz 100Ω 12pF ±50ppm -40℃~+125℃ SMD3225_4P
C3E-12.000-12-50100-X1-M 数据手册
Ltr RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Date Revisions Appr Electrical Specifications: Frequency Range Fundamental Mode of Oscillation Thrid Overtone Frequency Tolerance at 25°C Frequency Stability over Temperature Range Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 10.000 to 150.000 10.000 to 54.000 54.000 to 150.000 ±50 ±100 -40 to +125 -55 to +125 ±3 7 to 32 and Series Resonance 3.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz PPM Max ºC PPM Max/Year pF Ohms uW Typ M Ohms Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation Frequency Range in MHz ESR Ohm Max Mode of Operation 10.000 to 11.999 150 Fundamental 54.000 to 99.999 150 3rd Overtone 12.000 to 15.999 80 Fundamental 100.000 to 124.999 100 3rd Overtone 16.000 to 19.999 60 Fundamental 125.000 to 150.000 80 3rd Overtone 20.000 to 24.999 50 Fundamental 25.000 to 53.999 40 Fundamental 54.000 to 64.000 30 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Dec. 9, 2013 Microprocessor Crystal Unit Automotive Temperature Range Low Profile 3.2 x 2.5 millimeter Surface Mount General Product Specification Part Number: C3E X1 Series www.aker-usa.com Mechanical Outline: 3.2 ± 0.15 Metal Lid #3 #4 2.5 ± 0.15 Ceramic Base AKER #2 #1 0.75 Max. 2.2 1.2 #2 #4 #3 1.2 0.8 1.7 0.7 #1 0.9 #2:GND #4:GND 1.4 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: Dec. 9, 2013 P/N: C3E X1 Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Dec. 9, 2013 P/N: C3E X1 Series www.aker-usa.com How to build a Part Number: Series Package C 3E Frequency Load Capacitance Frequency Tolerance Frequency Stability Mode of Oscillation Temperature Range Packaging 10.000 to 150.000 7 10 12 16 18 20 32 S 50 100 See Notes 3 X1 M R R3 Parameter 3.2 x 2.5 mm MHz 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±50 PPM ±100 PPM Fundamental Third Overtone -40 to +125 ºC 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: C3E-25.000-18-50100-X1-R C3E- 2.5 x 3.2 mm SMD Seam Seal Crystal Unit 25.000 MHz Nominal Frequency 18 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability X1: -40 to +125° C Temperature Range R: Tape and Reel Packaging - 1000pcs Notes:. 1- Product is shipped in Tape and Reel configuration. 2- Quantities less than 250pcs are shipped in tape. 3- Specification subject to change without notice. 4- Fundamental mode does not need to be included in Part Number description. Page: 4/4 Date: Dec. 9, 2013 P/N: www.aker-usa.com C3E X1 Series
- 物料型号:C3E X1 Series - 器件简介:该系列是用于汽车温度范围的低轮廓表面安装晶体单元,尺寸为3.2 x 2.5毫米。 - 引脚分配:文档中提到了GND(#2和#4)的引脚分配,但未提供完整的引脚图。 - 参数特性: - 频率范围:10.000至150.000 MHz - 工作模式:基频和三次谐波 - 频率容差:±50 PPM最大 - 频率稳定性:±100 - 工作温度范围:-40至+125°C - 存储温度范围:-55至+125°C - 老化:±3 PPM/年最大 - 负载电容:7至32皮法拉和串联谐振 - 等效串联电阻(ESR):见ESR表 - 驱动级别:典型100微瓦 - 绝缘电阻:在100 Vdc ±15Vdc下为500兆欧姆 - 功能详解:文档详细描述了晶体单元的电气规格和频率范围,以及ESR值。 - 应用信息:适用于汽车温度范围的微处理器。 - 封装信息:3.2 x 2.5毫米表面安装,密封陶瓷金属封装。
C3E-12.000-12-50100-X1-M 价格&库存
很抱歉,暂时无法提供与“C3E-12.000-12-50100-X1-M”相匹配的价格&库存,您可以联系我们找货
