C5S-16.000-10-50100-X1-CT
    AKER(安碁科技)
    SMD5032_4P
    无源晶振 16MHz 50Ω 10pF ±50ppm -40℃~+125℃ SMD5032_4P
C5S-16.000-10-50100-X1-CT 数据手册
RoHS Compliant Pb - Lead Free AEC-Q200 Qualified Ltr Date Revisions Appr Electrical Specifications: Frequency Range 8.000 to 133.000 MHz Fundamental 8.000 to 54.000 MHZ Third Overtone 40.000 to 133.000 ±50 PPM Max ±100 PPM Max -40 to +125 ºC -55 to +125 PPM Max/Year ±3 10 to 32 and Series Resonance pF 7.0 See ESR Table Ohm 100 uW Typ 500 at at 100 Vdc ± 15 Vdc M Ohm Mode of Oscillation Frequency Tolerance at 25°C Frequency Stability over Temperature Range Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance Frequency Range and ESR Values: Frequency Range in MHz 8.000 to 9.749 ESR Ohm Max Mode of Operation 70 Frequency Range in MHz Fundamental ESR Ohm Max Mode of Operation 40.000 to 79.999 100 3rd Overtone 9.750 to 9.999 60 Fundamental 80.000 to 99.999 80 3rd Overtone 10.000 to 11.999 45 Fundamental 100.000 to 133.000 60 3rd Overtone 12.000 to 15.999 35 Fundamental 16.000 to 19.999 30 Fundamental 20.000 to 49.999 25 Fundamental 50.000 to 54.000 20 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: May 1, 2017 Microprocessor Crystal Unit Automotive Temperature Range 5.0 x 3.2 millimeter Surface Mount General Product Specification Part Number: C5S X1 Series www.aker-usa.com Mechanical Outline: 5.0 ± 0.15 Ceramic Base 3.2 ± 0.15 #4 Metal Lid #3 AKER #1 #2 1.0 Max. 2.6 3.8 #2 #4 #3 1.4 0.9 1.4 2.3 #1 1.2 #2:GND #4:GND 1.6 Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: May 1, 2017 P/N: www.aker-usa.com C5S X1 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION 5.4 AKER AKER AKER AKER A 12.0 5.5 B A B 1.5 8.0 1.4 3.6 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: May 1, 2017 P/N: www.aker-usa.com C5S X1 Series How to build a Part Number: Series Package C 5S Frequency 8.000 to 133.000 Load Capacitance Frequency Tolerance Frequency Stability Mode of Oscillation 7 10 12 16 18 20 32 S See Notes 3 X1 Packaging M R - - 50 100 Temperature Range - - Parameter 5.0 x 3.2 mm MHz 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series ±50 PPM ±100 PPM Fundamental Third Overtone -40 to +125 ºC 250pcs Reel 1000pcs Reel Part Number Example: C5S-40.000-50100-X1-R C5S: 5.0 x 3.2 mm SMD Seam Sealed Package 40.000 MHz Nominal Frequency 18 pF Load Capacitance 50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability X1: -40 to +125º C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs reel Notes: 1- Fundamental mode does not need to be included in Part Number description. 2- Other Load Capacitances are availble other than those listed in Part Number table above. 3- Product is shipped in Tape and Reel configuration. 4- Quantities less than 250pcs are shipped in tape 5- Specification subject to change without notice Page: 4/4 Date: May 1, 2017 P/N: C5S X1 Series www.aker-usa.com
1. 物料型号:C5S X1系列 2. 器件简介:该系列晶体单元适用于汽车温度范围,采用5.0 x 3.2毫米的表面贴装封装,具有金属盖和陶瓷基座。 3. 引脚分配:文档中提到了四个引脚,其中#2和#4被标记为GND。 4. 参数特性: - 频率范围:8.000至133.000 MHz - 工作模式:基本模式8.000至54.000 MHz,三次谐波40.000至133.000 MHz - 频率容差:±50 PPM最大 - 温度范围内频率稳定性:±100 PPM最大 - 工作温度范围:-40至+125°C - 存储温度范围:-55至+125°C - 老化:±3 PPM最大/年 - 负载电容:10至32 pF和串联谐振 - 并联电容:7.0 pF - 等效串联电阻(ESR):见ESR表 - 驱动级别:典型100微瓦 - 绝缘电阻:在100Vdc±15Vdc下为500兆欧 5. 功能详解:文档提供了详细的频率范围和ESR值表,以及如何根据频率、负载电容、频率容差、频率稳定性、振荡模式和温度范围构建部件编号。 6. 应用信息:适用于汽车温度范围的微处理器晶体单元。 7. 封装信息:5.0 x 3.2毫米表面贴装密封陶瓷金属封装,提供卷带包装,250pcs或1000pcs卷。
C5S-16.000-10-50100-X1-CT 价格&库存
很抱歉,暂时无法提供与“C5S-16.000-10-50100-X1-CT”相匹配的价格&库存,您可以联系我们找货
