Revisions
Ltr
Date
Appr
RoHS Compliant
Pb - Lead Free
Electrical Specifications:
Frequency Range
0.500~156.250 0.500~156.250 0.500~156.250 0.500~40.000 0.500~100.000
MHz
Frequency Stability
±20 ~ ±100
ppm
±3
ppm Max.
Aging per Year
Operating Temperature Range
Standard
-10 ~ +70
Extended
-40 ~ +85
-55 ~ +125
Storage Temperature Range
1.8 ± 5%
Supply Voltage
Input Current
Output Voltage
°C
2.5 ± 5%
3.3 ± 10%
1.62 ~ 3.63
5.0 ± 10%
0.500 to 9.999MHz
5
6
7
7
10
10.000 to 19.999MHz
6
7
7
7
15
20.000 to 31.999MHz
6
8
12
12
25
32.000 to 49.999MHz
15
50.000 to 79.999MHz
15
50
80.000 to 99.999MHz
30
60
100.000 to 156.250MHz
25
30
40
80
VDD
mA Max.
Logic High (Voh)
90%
VDD Min.
Logic Low (Vol)
10%
VDD Max.
Output Symmetry (Duty Cycle)
Standard
40 ~ 60 ( at 50% VDD)
Tight
45 ~ 55 ( at 50% VDD)
15
Output Load
pF Max.
30
Rise and Fall Time
0.500 to 31.999MHz
5
5
10
10
10
32.000 to 49.999MHz
5
5
10
10
6
50.000 to 79.999MHz
4
4
8
5
80.000 to 99.999MHz
3
3
5
5
3
3
4
4
1
Phase Jitter (12 KHz to 20 MHz)
ps Max. RMS
Tri-State
Enable-Disable Function
10
Start Up Time
ms Max.
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change,
output load change, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan
All dimensions are millimeters.
CAD:
TCR
Review:
EG
Appr:
JL
Page:
1/4
Date: July 1,2020
ns Max.
HCMOS Output Clock Oscillator
Low Profile
5.0 x 7.0 millimeter Surface Mount
General Product Specification
Part Number:
www.aker-usa.com
S7 Series
Mechanical Outline and Solder Pad Layout:
7.0 ± 0.15
5.0 ± 0.15
#4
Ceramic Base
Metal Lid
#3
AKER
#1
#2
1.4 Max.
5.08
5.08
#4
#3
2.0
1.1
4.20
#2
2.60
#1
1.4
1.8
Pin Connection
PIN No.
#1
Enable/Disable Function
PIN #1
Connection
Enable/Disable
#2
GND
#3
Output
#4
VDD
PIN #3
HIGH or OPEN
Operating
LOW
High Impedance
Package is Seam Sealed Ceramic-Metal.
Terminator Pads are Ni/Au.
Dimensions are millimeters.
Page: 2/4
Date : July 1,2020
www.aker-usa.com
P/N: S7 Series
+0.1
1.5 -0.0
2.0 ± 0.1
1.75 ± 0.1
Carrier Tape Dimensions:
4.0 ± 0.1
0.3 ± 0.05
5° (max)
A
B
8.0 ± 0.1
Ko:2.0
Ao:5.4
5° (max)
A-A SECTION
Solder Reflow Characteristics:
Page: 3/4
B-B SECTION
AKER
+0.1
1.7 -0.0
AKER
AKER
AKER
A
Bo:7.9
Pin #1
16.0 ± 0.3
7.5 ± 0.1
B
Date : July 1,2020
www.aker-usa.com
P/N: S7 Series
How to build a Part Number:
Series
Package
S
7
Parameter
5.0 x 7.0 mm
Supply Voltage
50
33
25
18
M
+5.0 VDD ± 10%
+3.3 VDD ± 10%
+2.5 VDD ± 5%
+1.8 VDD ± 5%
+1.62 ~ +3.63 VDD
Temperature Stability
10
05
025
020
±100 ppm
±50 ppm
±25 ppm
±20 ppm
See Notes
T
40%~60%
45%~55%
Duty Cycle
Frequency
0.500~156.250
MHz
Temperature Range
See Notes
X
-10 ~ +70 °C
-40 ~ +85 °C
Output Load
15
30
pF Max
Packaging
M
R
250pcs Reel
1000pcs Reel
Part Number Example:
S73305T-50.000-X-15-R
S7: 5.0 x 7.0 mm SMD Package
33: +3.3±10% VDD Supply Voltage
05: ±50 ppm Temperature Stability
T: 45%~55% Tight Symmetry
50.000 MHz Nominal Frequency
X: -40 ~ + 85°C Extended Temperature Range
15: 15 pF Max Output Load
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape only.
4- Specification subject to change without notice.
Page: 4/4
Date : July 1,2020
www.aker-usa.com
P/N: S7 Series
S733025T-8.192-15-R 价格&库存
很抱歉,暂时无法提供与“S733025T-8.192-15-R”相匹配的价格&库存,您可以联系我们找货
