SVC75C3A16B2-125.000M 数据手册
Ceramic SMT 6 Pad CMOS VCXO
SVC75C Series
7.5mm x 5.0mm
Features
Applications
• ±20ppm (Frequency Stability) Available
• Digital TV
• Miniature Package
• DVD, STB
• CMOS
• PCMIA, XDSL
• Fundamental or PLL (Phase Lock Loop) Available
• Broadband Access
• Tape and Reel
• Base Stations
Part Numbering Guide
SVC 75 C 3 A 48 A 2 - 27.000M
SUNTSU VCXO
7.0mm x 5.0mm
CMOS
SUPPLY VOLTAGE
2 : 2.5V±5%
3 : 3.3V±5%
5 : 5.0V±5%
FREQUENCY STABILITY
A : ±50ppm
B : ±30ppm
C : ±25ppm
Cage Code: 4GUT4
D : ±20ppm
To customize your parameters contact a Suntsu representative.
*E : ±15ppm
* For frequency stability option E contact a Suntsu representative.
COMPLIANT
Electrical Parameters
Units
Minimum
Frequency Range
MHz
1
300
Frequency Stability (Includes Initial
Tolerance at 25°C, Frequency
Stability over Operating
Temperature, Output Load Change,
Supply Voltage Change and First
Year Aging at 25°C.)
ppm
-20
+20
See part numbering guide for options.
Operating Temperature
°C
-40
+85
Storage Temperature
°C
-55
+125
Only available with AT-Cut Fundamental.
Supply Voltage (VDD) 2.5V Option
V
2.375
2.5
2.625
Available with AT-Cut Fundamental and PLL.
Supply Voltage (VDD) 3.5V Option
V
3.135
3.3
3.465
V
4.750
5.0
5.250
Supply Voltage (VDD) 5.0V Option
Typical
OPERATING
TEMPERATURE RANGE
07 : 0°C - +70°C
16 : -10°C - +60°C
17 : -10°C - +70°C
27 : -20°C - +70°C
38 : -30°C - +85°C
48 : -40°C - +85°C
Maximum
FREQUENCY
MHz
TRI-STATE
(ENABLE/DISABLE)
Blank: No Connection
PULLABILITY
2 : Pin 2
A : ±150ppm
5: Pin 5
B : ±100ppm
C : ±80ppm
D : ±50ppm
Current (IDD) 2.5V Option
mA
25
Current (IDD) 3.5V Option
mA
25
Current (IDD) 5.0V Option
mA
V
0.2
2.3
Current Voltage (VC) 3.5V Option
V
0.3
3.0
Pullability
V
0.5
ppm
±50
Linearity
Output Load (CMOS)
pF
Output Logic HIGH Level (VOH)
V
25mA max (AT-Cut Fund) & 50mA max (PLL).
30
Current Voltage (VC) 2.5V Option
Current Voltage (Vc) 5.0V Option
Remarks
4.5
±100
±150
10
15
0.9*VDD
Output Logic LOW Level (VOL)
V
Rise (TR) And Fall (TF) Time
ns
Symmetry (Duty Cycle)
45
Tri-State Input Voltage Enable
V
0.7*VDD
Tri-State Input Voltage Disable
V
0.3*VDD
Start-Up Time
ms
10
Phase Jitter (12KHz ~ 20MHz)
ps
1
AT-CUT Fundamental
ps
5
www.suntsu.com
Specifications are subject
to change without notice.
0.1*VDD
5
50
55
No Connection
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
SVC75C Series
7.5mm x 5.0mm
Outline Drawing & Land Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
Test Circuit (CMOS)
Waveform (CMOS)
Typical Phase Noise Performance (Measured By Agilent E5052A)
Frequency - 27.000MHz
www.suntsu.com
Frequency - 74.250MHz
IRVINE, CA 92618
SVC75C Series
7.5mm x 5.0mm
Typical Jitter Performance (Measured By Agilent E5052A)
Reflow Profile
Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
1,000pcs/Reel
www.suntsu.com
IRVINE, CA 92618
SVC75C Series
7.5mm x 5.0mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Moisture Resistance
MIL-STD-883, Method 1004
Solderability
MIL-STD-883, Method 2003
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
www.suntsu.com
IRVINE, CA 92618
SVC75C3A16B2-125.000M 价格&库存
很抱歉,暂时无法提供与“SVC75C3A16B2-125.000M”相匹配的价格&库存,您可以联系我们找货
