C1E-27.000-10-1010-CT
    AKER(安碁科技)
    SMD2016_4P
    无源晶振 100Ω 27MHz 10pF ±10ppm -10℃~+70℃ SMD2016_4P
C1E-27.000-10-1010-CT 数据手册
RoHS Compliant Pb - Lead Free Ltr Revisions Appr Date Electrical Specifications: Frequency Range Mode of Oscillation Fundamental Standard Frequency Tolerance at 25°C Optional Standard Frequency Stability over Temperature Range Optional Standard Extended Operating Temperature Range Storage Temperature Range Aging Load Capacitance Shunt Capacitance Equivalent Series Resistance (ESR) Drive Level Insulation Resistance 16.000 to 54.000 16.000 to 54.000 ±30 ±25 ±20 ±15 ±10 ±50 ±30 ±25 ±20 ±15* -10 to +70 -40 to +85 -55 to +125 ±3 7 to 32 and Series Resonance 3.0 See ESR Table 100 500 at at 100 Vdc ± 15 Vdc MHz MHZ PPM Max (Note 1) PPM Max (Note 1) ºC PPM Max/Year Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 16.000 to 19.199 200 Fundamental 19.200 to 25.999 100 Fundamental 26.000 to 35.999 80 Fundamental 36.000 to 54.000 60 Fundamental Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: May 1, 2016 Microprocessor Crystal Unit Low Profile 2.0 x 1.6 millimeter Surface Mount General Product Specification Part Number: C1E Series www.aker-usa.com pF Ohm uW Max M Ohm Mechanical Outline: 2.0 ± 0.15 1.6 ± 0.15 #4 Ceramic Base #3 Metal Lid AKER #1 #2 0.5 Max. 1.28 0.7 #2 #4 #3 0.78 0.48 0.5 0.98 #1 0.88 0.58 #2:GND #4:GND Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: May 1, 2016 P/N: www.aker-usa.com C1E Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION 8.0 2.3 AKER AKER AKER AKER AKER A AKER AKER AKER A 3.5 B B 1.0 4.0 0.65 1.9 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: May 1, 2016 P/N: www.aker-usa.com C1E Series How to build a Part Number: Series Package C 1E Frequency 16.000 to 54.000 Load Capacitance Standard Frequency Tolerance (Note 1) Option Standard Frequency Stability (Note 1) Option Standard Temperature Range Extended Packaging 7 10 12 16 18 20 32 S - Parameter 1.6 x 2.0 mm Seam Seal MHz - 7 pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - 30 25 20 15 10 50 30 25 20 15 See Notes X M R R3 ±30 PPM ±25 PPM ±20 PPM ± 15 PPM ±10 PPM ±50 PPM ±30 PPM ±25 PPM ±20 PPM ±15 PPM* - -10 to +70 ºC -40 to +85 ºC - 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: C1E-50.000-10-3050-R3 C1E- 1.6 x 2.0 mm SMD Seam Seal Crystal Unit 50.000 MHz Nominal Frequency 10 pF Load Capacitance 3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability Fundamental Mode -10 to +70° C Temperature Range R3: Tape and Reel Packaging - 3000pcs Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. * ±15 PPM Temperature Stability is only available from -30 to +85° C. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. 4- Quantities less than 250 are shipped in tape only. 5- Specification subject to change without notice. Page: 4/4 Date: May 1, 2016 P/N: www.aker-usa.com C1E Series
物料型号:C1E Series
器件简介:Microprocessor Crystal Unit,低轮廓2.0 x 1.6毫米表面贴装。
引脚分配:#1和#2为引脚,#3和#4为地(GND)。
参数特性: - 频率范围:16.000至54.000 MHz - 工作模式:基频 - 频率容差:标准±30 PPM,可选±25、±20、±15、±10 PPM - 温度范围内的频率稳定性:标准±50 PPM,可选±30、±25、±20、±15 PPM - 工作温度范围:标准-10至+70°C,扩展-40至+85°C - 老化:±3 PPM/年 - 负载电容:7至32 pF及串联谐振 - 等效串联电阻(ESR):见ESR表 - 驱动水平:最大100 uW - 绝缘电阻:在100 Vdc±15Vdc时为500 MΩ
功能详解:文档提供了详细的电气规格和机械轮廓,以及如何构建部件编号的指南。
应用信息:适用于微处理器晶体单元。
封装信息:Seam Sealed Ceramic-Metal封装,尺寸为2.0 x 1.6毫米。
C1E-27.000-10-1010-CT 价格&库存
很抱歉,暂时无法提供与“C1E-27.000-10-1010-CT”相匹配的价格&库存,您可以联系我们找货
