NJ-100M-6807
NJ-100M-6807
    TAITIEN(泰艺)
    SMD-6
    有源晶振 12V 100MHz SMD-6
NJ-100M-6807 数据手册
Our Performance Your Reputation 100MHz Low Noise OCXO NJ-100M-6800 Series 6800 Series in 25.4x22mm SMD package NJ-100-6800 series is a 100.000 MHz high performance (VC)OCXO offering low phase noise(LPN) and tight frequency stability down to ±50ppb(-20ºC to +70ºC). The part comes in a small SMD package which makes it suitable for reflow soldering during pick and place assembly FEATURES APPLICATIONS RoHS Compliant Standard Low Phase Noise Instrument Reference Small SMD Package Microwave Communication Tight Frequency Stability Clock Reference for Microwave Signal Source Low Power Consumption Test & Measurement Fast Warm-up Time Telecom Systems Electrical Frequency Tuning Input Radar Systems Reference Voltage Output Satellite Communication RoHS-Compliant (lead-free) ELECTRICAL SPECIFICATIONS Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified 1. OUTPUT (PIN = “R.F. OUTPUT”) Parameter Min. Typ. Max. 100.000000 Unit 1.1. Frequency (Fo) 1.2. Initial Accuracy 1.3. Waveform 1.4. Level 1.5. Load 1.6. Harmonics -30 dBc 1.7. Spurious -100 dBc Test Condition MHz @ +25 ±1°C -0.3 +0.3 ppm after turn on power 60 minutes Vco=+5V Sine wave +10 dBm Ω 50 http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Rev(4)05/2017 Page 1of 4 Our Performance Your Reputation 2. FREQUENCY STABILITY Parameter 2.1. Min. Ambient Typ. Max. Unit ±20, ±50, ±100 ppb -20oC ~ +70oC -40oC ~ +85oC °C Test Condition Refer to Table 1 : Ordering Information referenced to 25°C Aging Daily -5 +5 ppb Yearly -500 +500 ppb -2 +2 ppm -5 +5 ppb ±5% change 0.05 ppb root Allan variance for τ=1 sec +5 ppb ±10% change +50 ppb in 5 minutes @ +25 ±1°C 2.2. 10 Years 2.3. Voltage 2.4. Short term 2.5. Load 2.6. Warm-up -5 -50 Option A 2.7. Phase Noise (Max.) Option B Option C after 30 days referenced to 1 hour Refer to Table 1 : Ordering Information -93 -97 -100 dBc/Hz @ 10Hz -125 -130 -135 dBc/Hz @ 100Hz -154 -157 -160 dBc/Hz @ 1KHz -173 -173 -170 dBc/Hz @ 10KHz -177 -175 -172 dBc/Hz @ 100KHz -180 -178 -175 dBc/Hz @ 1MHz 3. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter 3.1. Tuning Range 3.2. Control Voltage 3.3. Slope 3.4. Center Voltage 3.5. Linearity Min. Typ. Max. Unit -3 ppm VCO @ Min. Voltage ppm VCO @ Max. Voltage +3 0 +10.0 V +10 % Test Condition Referenced to frequency at nominal Center Voltage Positive +5 -10 V 4. INPUT POWER (PIN = “+VDC”) 4.1. Parameter Min. Typ. Max. Unit Voltage +11.4 +12 +12.6 V Steady State 2.1 W During Warm-Up 380 mA Test Condition Current 4.2. 5. REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE") 5.1. Parameter Min. Typ. Max. Units Voltage +9.5 +10 +10.5 V http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Test Condition Rev(4)05/2017 Page 2of 4 Our Performance Your Reputation 6. ENVIRONMENTAL Parameter Reference Std. Test Condition 6.1. Operating Temperature -40°C to +85°C 6.2. Storage Temperature -55°C to +105°C Note 1 6.3. Humidity MIL-STD-202, Method 103 Test Condition A 95% RH @ +40°C,non-condensing,240 hours 6.4. Vibration (non-operating) MIL-STD-202, Method 201 0.06” Total p-p, 10 to 55 Hz 6.5. Shock (non-operating) MIL-STD-202, Method 213, Test Condition J 30g, 11ms, half-sine Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the temperature range in 2.1. Table 1 : ORDERING INFORMATION Ambient Option A B C ±100 ppb NJ-100M-6805 NJ-100M-6806 NJ-100M-6807 ±50 ppb NJ-100M-6815 NJ-100M-6816 NJ-100M-6817 ±20 ppb NJ-100M-6835 NJ-100M-6836 NJ-100M-6837 ±100 ppb NJ-100M-6825 NJ-100M-6826 NJ-100M-6827 Temp. (°°C ) -20°°C ~+70oC -40oC~+85oC Phase Noise Option Phase Noise Test Data http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Rev(4)05/2017 Page 3of 4 OUTLINE DRAWING http://www.taitien.com E-Mail: sales@taitien.com.tw Specifications subject to change without notice Our Performance Your Reputation Rev(4)05/2017 Page 4of 4
NJ-100M-6807 价格&库存
很抱歉,暂时无法提供与“NJ-100M-6807”相匹配的价格&库存,您可以联系我们找货
