QTT252
Temperature Compensated Crystal Oscillator
Fuel The Digital World
Features
Applications
Frequency range : 10MHz to 70MHz
SMD seam sealing ceramic package
Supply voltage : 1.8V ~ 3.3V
Clipped Sinewave output
Low power consumption
Voltage control function available
External dimensions (mm)
L : 2.5 x W : 2.0 x H : 0.8
RoHS compliant & Pb free
Mobile communications
GNSS
Smartphone, Mobile phone
Wearables
IoT devices
Portable radio communications
Electrical Characteristics
Item
Nominal Frequency Range (F0)
Frequency Tolerance (Ftol)
QTT252
Conditions
10MHz ~ 70MHz
±2.0 ppm Max.
Note [1]
±0.5ppm, ±2.0ppm
-30°C~+85°C, Note [2]
±1.0ppm
-40°C~+85°C, Note [2]
vs Temperature
Frequency Stability
vs Load
±0.2 ppm Max.
Load ±10%
vs Supply Voltage
±0.2 ppm Max.
VDD ±5%
Operating Temperature Range (T OTR)
Supply Voltage (VDD)
-30°C ~ +85°C
-40°C ~ +85°C
1.8V, 2.5V, 3.3V
Current Consumption (IDD)
2.0 mA Max.
Output Type
Clipped Sinewave
Output Load
10kΩ // 10pF
Output Level
Start-up Time
0.8 V(p-p) Min.
5 ms Max.
Note [3]
Auto Frequency Control (AFC) Range
±7ppm ~ ±16ppm
VCTCXO, optional, Note [4]
Phase Noise
-135 dBc/Hz Typ.
at 1kHz offset
Aging (Faging)
±1 ppm Max.
Storage Temperature Range (TSTR)
at 25°C, first year
-55°C ~ +125°C
Notes:
[1] Refer to nominal frequency after 2 times of reflow at 25°C.
[2] Refer to frequency at 25°C±2°C.
[3] Decoupling capacitor is required in external circuit.
[4] If supply voltage VDD = 3.3V or 2.5V, control voltage Vcon = 0.5*VDD ± 1.0V.
If supply voltage VDD = 1.8V, control voltage Vcon = 0.5*VDD ± 0.8V.
Rev. 1.05
Page 1
www.qstproducts.com
QTT252
Dimensions
Pin function
Function
Pin
TCXO
1
VCTCXO
GND or NC
AFC
2
GND
3
OUTPUT
4
VDD
Recommended pad layout
(Unit: mm)
Ordering Information
QTT252
26.000M B G
Frequency in Hz
T
Packaging Method
T
Please contact us for
available frequencies
Tape & Reel
Supply Voltage
B
C
D
Rev. 1.05
3.3 V
2.5 V
1.8 V
Frequency Stability (over Temp.)
N
S
G
V
I
± 2.0 ppm
± 2.0 ppm
± 0.5 ppm
± 0.5 ppm
± 1.0 ppm
Page 2
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
( -30°C ~ +85°C ),
( -40°C ~ +85°C ),
TCXO
VCTCXO
TCXO
VCTCXO
TCXO
www.qstproducts.com
QTT252
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C, 60 sec. Min., 200 sec. Max.
Peak temperature : 260°C, 10 sec. Min., 30 sec. Max.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.05
60 sec
Page 3
Time (sec)
www.qstproducts.com
很抱歉,暂时无法提供与“QTT252-16.369MBG-T”相匹配的价格&库存,您可以联系我们找货
