C16-37.400-10-1015-X-CT 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Revisions
Appr
Date
Electrical Specifications:
Frequency Range
Mode of Oscillation
Fundamental
Standard
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
24.000 to 48.000
24.000 to 48.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15*
-10 to +70
-40 to +85
-55 to +125
±3
6 to 32 and Series Resonance
3.0
See ESR Table
100
500 at 100 Vdc ± 15Vdc
MHz
PPM Max
(Note 1)
PPM Max
(Note 1)
ºC
PPM Max/Year
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
24.000 to 29.999
150
Fundamental
30.000 to 36.999
100
Fundamental
37.000 to 48.000
80
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Nov 25, 2018
Microprocessor Crystal Unit
Low Profile
1.2 x 1.6 millimeter Surface Mount
General Product Specification
Part Number:
C16 Series
www.aker-usa.com
pF
Ohm
uW Max
M Ohm
Mechanical Outline:
1.6 ± 0.15
Ceramic Base
1.2 ± 0.15
#4
Metal Lid
#3
AKER
#2
#1
0.4 Max.
1.05
0.5
#2
#4
#3
0.6
0.4
0.8
0.3
#1
0.5
#2:GND #4:NC
0.75
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: July 25, 2013
P/N:
www.aker-usa.com
C16 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Nov 25, 2018
P/N:
www.aker-usa.com
C16 Series
How to build a Part Number:
Series
Package
C
16
Frequency
24.000 to 48.000
Load Capacitance
Standard
Frequency Tolerance
(Note 1)
Option
Standard
Frequency Stability
(Note 1)
Option
Standard
Temperature Range
Extended
Packaging
6
10
12
16
18
30
25
10
50
30
25
See Notes
X
M
R
R3
Parameter
1.6 x 1.2 mm Seam Seal
MHz
6 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM*
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
C16-40.000-10-3030-R
C16- 1.6 x 2.0 mm SMD Seam Seal Crystal Unit
40.000 MHz Nominal Frequency
10 pF Load Capacitance
3030: ±30 PPM Frequency Tolerance and ±30 PPM Frequency Stability
Fundamental Mode
-20 to +70° C Temperature Range
R: Tape and Reel Packaging - 1000pcs
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration
4- Quantities less than 250pcs are shipped in tape only.
5- Specification subject to change without notice.
Page:
4/4
Date: Nov 25, 2018
P/N:
www.aker-usa.com
C16 Series
C16-37.400-10-1015-X-CT 价格&库存
很抱歉,暂时无法提供与“C16-37.400-10-1015-X-CT”相匹配的价格&库存,您可以联系我们找货
