CTS3-32.768-7-20-CT
CTS3-32.768-7-20-CT
    AKER(安碁科技)
    SMD3215_2P
    无源晶振 7pF ±20ppm -40℃~+85℃ 65Ω SMD3215_2P 32.768KHz
CTS3-32.768-7-20-CT 数据手册
RoHS Compliant Pb - Lead Free AEC Q200 Ltr Date Revisions Electrical Specifications: Nominal Frequency Frequency Tolerance at 25º C Aging per year Turnover Temperature Temperature Coefficient Temperature Range Temperature Range (Extended) Temperature Range (Storage) Equivalent Series Resistance Load Capacitance Shunt Capacitance Motional Capacitance Drive Level Insulation Resistance Quality Factor Capacitance Ratio Resistance to Shock 32.768 ±20 Standard ±10 Optional ±3 25 ±5 -0.034 ± 0.008 PPM/  ºC² -40 to +85 -40 to +125 -55 to +140 70 Standard 12.5 6.0 Optional 7.0 9.0 1.7 3.0 1.0 500 at at 100 Vdc ± 15 Vdc 70000 450 ±5 PPM maximum offset from 75 cm drop test in all axes on to a hard surface. KHz PPM ºC K Ohm Max pF pF Typ fF Typ uW Max M Ohm Min Typ Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Oct. 21, 2018 Microprocessor Crystal Unit 32.768 KHz (Time of Day) 3.2 x 1.5 millimeter Surface Mount Ceramic Package General Product Specification Part Number: CTS3 Series www.aker-usa.com - Appr Mechanical Outline: Tolerances: unless otherwise specified ± 0.1mm 3.2 0.75 TYP. R EF. TYP. REF. max.0.65 0.08 1.5 0.08 0.75 Package is Ceramic-Metal. Dimensions are millimeters. PCB Solder Pad Layout: 1.5 1.0 1.8 1.0 Page: 2/4 Date: Oct. 21, 2018 P/N: www.aker-usa.com CTS3 Series ±0.1 ±0.05 0.315 ±0.05 1.75 2 ±0.05 ±0.1 5.5 4 0.254 ±0.015 12 +0.3 -0.1 3.43 ±0.05 Carrier Tape Dimensions: 4 ±0.1 1.73 ±0.05 0.061 Cover Tape Direction of feed 0.83 ±0.05 All dimensions are in mm Solder Reflow Characteristics: tP TP Critical Zone TL to TP Temperature Ramp-up TL tL Tsmax Tsmin Ramp-down ts Preheat 25 Page: t 25°C to Peak 3/4 Time Date: Oct. 21, 2018 P/N: CTS3 Series www.aker-usa.com How to build a Part Number: Series Package Frequency CTS 3 32.768 12.5 6 7 9 Standard Load Capacitance Option Frequency Tolerance Temperature Range Temperature Range (Extended) 20 See Notes X Packaging R - Parameter 3.2 x 1.5 mm SMD KHz - 12.5 pF 6 pF 7 pF 9 pF - ±20 PPM -40 to +85 ºC -40 to +125 ºC Tape and Reel Part Number Example: CTS3-32.768-9-20-R CTS3- 3.2 x 1.5 mm SMD Crystal Unit 32.768 KHz Nominal Frequency 9 pF Load Capacitance 20: ±20 PPM Frequency Tolerance -40 to +85° C Temperature Range R: Tape and Reel Packaging Frequency vs. Temperature Characteristics: To calculate the frequency stability the parabolic curvature constant (K) is needed. For calculating the stability at 45 ° C? 1- Change in temperature (T) is (45-25) = +20 ° C 2 2- Change in frequency is (-0.034 x (° C) ) = 2 (-0.035 x (20) = -13.6 PPM Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces. 3- Specification subject to change without notice. Page: 4/4 Date: Oct. 21, 2018 P/N: www.aker-usa.com CTS3 Series
CTS3-32.768-7-20-CT 价格&库存
很抱歉,暂时无法提供与“CTS3-32.768-7-20-CT”相匹配的价格&库存,您可以联系我们找货
