C7S-12.000-10-1530-X-CT 数据手册
Ltr
RoHS Compliant
Pb - Lead Free
Appr
Date
Revisions
Electrical Specifications:
Frequency Range
Fundamental
Third Overtone
Standard
Mode of Oscillation
Frequency Tolerance at 25°C
Optional
Standard
Frequency Stability over
Temperature Range
Optional
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Aging
Load Capacitance
Shunt Capacitance
Equivalent Series Resistance (ESR)
Drive Level
Insulation Resistance
6.000 to 133.000
6.000 to 50.000
40.000 to 133.000
±30
±25
±20
±15
±10
±50
±30
±25
±20
±15
±10*
-10 to +70
-40 to +85
-55 to +125
±3
10 to 32 and Series Resonance
7.0
See ESR Table
100
500 at at 100 Vdc ± 15 Vdc
MHz
MHz
PPM Max
PPM Max
ºC
PPM Max/Year
pF
Ohms
uW Typ
M Ohms
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
ESR Ohm Max
Mode of Operation
6.000 to 7.999
70
Fundamental
40.000 to 79.999
70
3rd Overtone
8.000 to 9.999
40
Fundamental
80.000 to 133.000
60
3rd Overtone
10.000 to 14.999
35
Fundamental
15.000 to 39.999
30
Fundamental
40.000 to 50.000
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Dec 1, 2018
Microprocessor Crystal Unit
Low Profile
7.0 x 5.0 millimeter Surface Mount - 4 Pad
General Product Specification
Part Number:
C7S Series
www.aker-usa.com
Mechanical Outline:
Ceramic Base
Metal Lid
5.0 ± 0.15
7.0 ± 0.15
#4
#3
AKER
#2
#1
1.1 Max.
4.6
5.9
#4
#3
1.0
1.4
2.54
#2
2.54
#1
1.7
1.2
#2:GND #4:GND
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C7S Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C7S Series
How to build a Part Number:
Series
Package
C
7S
Frequency
6.000 to 133.000
10
12
16
18
S
Load Capacitance
Frequency Tolerance
Option
Standard
Frequency Stability
Option
Mode of Oscillation
See Notes
3
Standard
Temperature Range
Option
See Notes
X
M
R
Packaging
MHz
30
25
10
50
30
25
10
Standard
Parameter
5.0 x 7.0 mm 4 Pad
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
Series
±30 PPM
±25 PPM
±20 PPM
± 15 PPM
±10 PPM
±50 PPM
±30 PPM
±25 PPM
±20 PPM
±15 PPM
±10 PPM*
Fundamental
Third Overtone
-10 to +70 ºC
-40 to +85 ºC
250pcs Reel
1000pcs Reel
Part Number Example:
C7S-64.000-18-3050-3-R
C7S- 5 x 7 mm SMD Seam Seal Package - 4 pad
64.000 MHz Nominal Frequency
18 pF Load Capacitance
3050: ±30 PPM Frequency Tolerance and ±50 PPM Frequency Stability
Third Overtone Mode
-10 to +70° C Temperature Range
R: Tape and Reel Packaging - 1000pcs Reel
Notes:
1- Fundamental mode does not need to be included in Part Number description.
* ±10 PPM Temperature Stability is only available from -30 to +85° C.
2- Standard Temperature Range does not need to be included in Part Number description.
3- Product is shipped in Tape and Reel configuration
Page:
4/4
Date: Dec 1, 2018
P/N:
www.aker-usa.com
C7S Series
C7S-12.000-10-1530-X-CT 价格&库存
很抱歉,暂时无法提供与“C7S-12.000-10-1530-X-CT”相匹配的价格&库存,您可以联系我们找货
