LFXTAL072546REEL
LFXTAL072546REEL
    IQD
    SMD2016_4P
    无源晶振 48MHz ±15ppm 10pF 60Ω -40℃~+85℃
LFXTAL072546REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL072546Reel Customer Part: Description 2 x 1.6mm SMD crystal Ceramic package with a seam sealed metal lid, hermetically sealed Model IQXC-42 Model Issue number 1 Frequency Parameters Frequency 48.0MHz Frequency Tolerance Frequency Stability ±15.00ppm ±20.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±3ppm max per year @ 25°C Electrical Parameters Outline (mm) 10.00pF 3pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 100µW max 60.00Ω max Environmental Parameters Shock: IEC 60068-2-27: 1000G, 1ms, 3 times in each of 3 mutually perpendicular planes Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) Storage Temperature Range: –55 to 125°C Manufacturing Details RoHS Terminations RoHS Reflow Temp NiAu 260degC 10s Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 5 Sep 21 20:24 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL072546REEL
1. 物料型号:IQXC-42,封装为2 x 1.6mm SMD晶体。 2. 器件简介:该器件是一个陶瓷封装,带有密封金属盖,是密封的48.0MHz晶体振荡器。 3. 引脚分配:文档中提到了两个引脚,1号引脚为晶体(Crystal),2号引脚为地(GND)。 4. 参数特性: - 频率:48.0MHz - 频率容差:±15.00ppm或±20.00ppm - 频率稳定性:在-40.00至85.00°C的工作温度范围内 - 老化:每年在25°C下最多±3ppm - 电气参数:包括60.00Ω的最大等效串联电阻(ESR)和3pF的最大并联电容(C0) 5. 功能详解:文档中没有提供详细的功能解释,但晶体振荡器通常用于为电子设备提供稳定的时钟信号。 6. 应用信息:文档中没有明确提供应用信息,但晶体振荡器广泛应用于需要精确时钟信号的电子系统中。 7. 封装信息:封装细节包括符合EIA-481-D标准的带卷装,每卷1000个单位,还提供了替代的包装选项。
LFXTAL072546REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL072546REEL”相匹配的价格&库存,您可以联系我们找货
LFXTAL072546REEL
    • 1+7.46280
    • 200+2.98080
    • 500+2.88360
    • 1000+2.82960
