SXT1148BB48-48.000MT 数据手册
Ceramic SMT 4 Pad Crystal
SXT114 Series
1.6mm x 1.2mm
Features
Applications
• ±10ppm/±10ppm (Tolerance/Stability)
Available
• Bluetooth
• Ultra-Miniature Package
• High Density Applications
• Wireless LAN
• AT-Cut Fundamental
• Tape and Reel
Part Numbering Guide
SXT 11 4 12 A A 48 - 20.000M
SUNTSU CRYSTAL
FREQUENCY
MHz
1.6mm x 1.2mm
4 PAD
OPERATING TEMPERATURE RANGE**
07 : 0°C - +70°C
LOAD CAPACITANCE
FREQUENCY STABILITY
16 : -10°C - +60°C
FREQUENCY TOLERANCE
S : Series
A : ±50ppm
A : ±50ppm
17 : -10°C - +70°C
COMPLIANT
8 - 12 : 8pF - 12pF
B : ±30ppm
B : ±30ppm
27 : -20°C - +70°C
C : ±25ppm
C : ±25ppm
38 : -30°C - +85°C
D : ±20ppm
D : ±20ppm
48 : -40°C - +85°C
E : ±15ppm
E : ±15ppm
Cage Code: 4GUT4
F : ±10ppm*
F : ±10ppm
To customize your parameters contact a Suntsu representative.
* For frequency stability option F contact a Suntsu representative. ** For operating temperatures of -55-125°C a Suntsu representative.
Electrical Parameters
Units
Minimum
Frequency Range
MHz
24
54
AT-Cut Fundamental.
Frequency Tolerance at +25ºC
ppm
-10
+10
See part numbering guide for options.
Frequency Stability vs. Op Temp
ppm
-10
+10
Frequency Stability vs. Aging
ppm
-2
+2
First year @ +25ºC.
Operating Temperature
°C
-40
+85
Storage Temperature
°C
-40
+95
Load Capacitance
pF
8
12
Shunt Capacitance
pF
Drive Level
µW
Insulation Resistance
ESR - 24.000MHz
MΩ
Typical
Maximum
Remarks
3
10
100
500
@ 100VDC ± 15V.
29.999MHz
Ω
150
AT-Cut Fundamental
ESR - 30.000MHz ~ 54.000MHz
Ω
100
AT-Cut Fundamental
Outline Drawing & Recommended Landed Pattern
All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale.
www.suntsu.com
Specifications are subject
to change without notice.
Suntsu Electronics, Inc.
142 TECHNOLOGY DR., SUITE 150
IRVINE, CA 92618
Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXT114 Series
1.6mm x 1.2mm
Environmental Specifications
Mechanical Specifications
Temperature Cycling
MIL-STD-883, Method 1010, Condition B
Mechanical Shock
MIL-STD-202, Method 213, Condition B
Fine Leak Test
MIL-STD-883, Method 1014, Condition A
Vibration
MIL-STD-883, Method 2007, Condition A
Gross Leak Test
MIL-STD-883, Method 1014, Condition C
Resistance to Soldering Heat
MIL-STD-202, Method 210, Condition K
Moisture Resistance
MIL-STD-883, Method 1004
Resistance to Solvents
MIL-STD-202, Method 215
Moisture Sensitivity
J-STD-020, MSL 1
Solderability
MIL-STD-883, Method 2003
Reflow Profile & Part Marking
Tp (Time At 260°C. 20-40 Sec)
260
Rup (Ramp Up, 3°C/Sec Max)
217
Temperature (°C)
200
TI (Time Above 217°C.
60-150Sec)
150
Rdn (Ramp Down,
6°C/Sec Max)
Ts (Preheat Time.
60-180Sec)
T 25°C to Peak (480Sec Max)
Time (sec)
Tape And Reel Dimensions
3,000pcs / Reel
www.suntsu.com
IRVINE, CA 92618
SXT1148BB48-48.000MT 价格&库存
很抱歉,暂时无法提供与“SXT1148BB48-48.000MT”相匹配的价格&库存,您可以联系我们找货
