8WE-27.000MCM-T
8WE-27.000MCM-T
    TXC(台晶)
    SMD-4
    有源晶振 27MHz 2.5V SMD-4
8WE-27.000MCM-T 数据手册
8WE Low EMI Oscillator Features Frequency range : 1MHz to 40MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Phase modulation clock function selectable for EMI reduction External dimensions (mm) L : 2.5 x W : 2.0 x H : 0.8 RoHS compliant & Pb free Applications Imaging & Display Devices HD Camera, DVR HD Surveillance Camera Computer Peripherals Consumer products Electrical Characteristics Item 8WE Frequency Range (F 0) 1MHz ~ 40MHz Frequency Stability (F stab) ±50 ppm Operating Temperature Range (T OTR) -40°C ~ +85°C -40°C ~ +105°C -40°C ~ +125°C Supply Voltage (VDD) 1.8V, 2.5V, 3.3V Current Consumption (IDD) Note [1] & [2] VDD ± 5% 10 mA Max. Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 80% VDD Min. Output Voltage Low (VOL) 20% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Duty Cycle Start-up Time 45% ~ 55% 1 ms Max. Phase Jitter, RMS Phase Modulation Clock Mode Conditions 1 ps Max. Enable Disable Aging (F aging) Storage Temperature Range (T STR) 20% ~ 80% of VDD Note [2] Integrated 12kHz~5MHz. 30% VDD Max. (Logic "0") 70% VDD Min. (Logic "1") Input to Pin1; Note [3] ±3 ppm Max. at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, variations over operating temperature, supply voltage, load and 1st year aging at 25°C. [2] Phase modulation clock mode is disabled. [3] Phase modulation clock mode will be enabled if Pin1 is Logic "0"; Phase modulation clock mode will be disabled if Pin1 is Logic "1" or open (Internal pull-high resistor). Rev. 1.01 Page 1 www.txccrystal.com 8WE Low EMI Oscillator Phase Modulation Mode Deviation [4] Deviaton range (%) Frequency (MHz) VDD 1.8V VDD 2.5V VDD 3.3V 20 24 25 27 ± 0.54 ± 0.62 ± 0.65 ± 0.70 ± 0.36 ± 0.42 ± 0.45 ± 0.54 ± 0.29 ± 0.34 ± 0.35 ± 0.40 Notes: [4] Contact us for available frequencies and deviation range. Dimensions (Unit: mm) (Suggested Layout) Ordering Information 8WE - 27.000M B E - T Packaging Method Frequency in Hz T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.01 Tape & Reel E J M 3.3 V 2.5 V 1.8 V Page 2 ± 50 ppm ( -40°C ~ +85°C ) ± 50 ppm ( -40°C ~ +105°C ) ± 50 ppm ( -40°C ~ +125°C ) www.txccrystal.com 8WE Low EMI Oscillator Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.txccrystal.com
8WE-27.000MCM-T
物料型号:8WE
器件简介:TXC 8WE是一款低电磁干扰(EMI)振荡器,适用于1MHz至40MHz的频率范围,采用SMD贴片密封陶瓷封装,符合RoHS标准,无铅。
引脚分配: 1. ENABLE CONTROL 2. GND 3. OUT 4. VDD
参数特性: - 工作频率范围:1MHz至40MHz - 频率稳定性:±50ppm(在-40°C至+85°C或-40°C至+105°C或-40°C至+125°C) - 工作温度范围:-40°C至+105°C - 供电电压:1.8V、2.5V、3.3V - 最大电流消耗:10mA - 输出类型:CMOS - 输出负载:15pF - 高电平输出电压:至少80% VDD - 低电平输出电压:最大20% VDD - 上升和下降时间:最大8ns - 占空比:45%至55% - 启动时间:最大1ms - 相位抖动(RMS):最大1ps - 相位调制功能:可选用以减少EMI
功能详解:该振荡器具备相位调制功能,可通过引脚1输入逻辑“0”或“1”来启用或禁用此功能,以进一步降低EMI。
应用信息:适用于成像和显示设备、高清摄像机、DVR、高清监控摄像机、计算机外设和消费电子产品。
封装信息:外部尺寸为长2.5mm x 宽2.0mm x 高0.8mm,建议布局和订购信息也提供在文档中。
8WE-27.000MCM-T 价格&库存
很抱歉,暂时无法提供与“8WE-27.000MCM-T”相匹配的价格&库存,您可以联系我们找货
