SXO32C3B171-8.000M
SXO32C3B171-8.000M
    SUNTSU
    SMD3225_4P
    有源晶振 8.000000MHz ±30ppm 3.3V -10℃~+70℃ CMOS
SXO32C3B171-8.000M 数据手册
Ceramic SMD 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Features Applications • ±20ppm (Frequency Stability) Available • Micro Processors • Ceramic Package • SONET/SDH/DWDM • CMOS • Storage Area/Networking • Tape and Reel • Digital Video • Base Stations • Part Numbering Guide SXO 32 C 3 A 48 1 X - 30.000M SUNTSU OSC 3.2mm x 2.5mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. ** For operating temperatures up to -55-125°C contact a Suntsu representative. Electrical Parameters Units Minimum Frequency Range KHz 32.768 Frequency Range MHz 1 133 ppm -20 +20 See part numbering guide for options See part numbering guide for options Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) Operating Temperature Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C FREQUENCY MHz LOAD BLANK : 15pF X : 30pF TRI-STATE Y : 50pF (ENABLE/DISABLE) BLANK : No Connection 1 : Pin 1 Maximum °C -40 +85 Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.135 3.3 3.465 1.8V 2.5V 3.3V Frequency Range Current (IDD) 32.768KHz mA 3 5 5 1.0000MHz - 29.999MHz mA 4 8 10 Maximum Value 30.000MHz - 74.999MHz mA 6 15 17 Maximum Value 75.000MHz - 133.000MHz mA 12 20 25 Maximum Value 15 See part numbering guide for options Output Load (CMOS) pF Maximum Value Output Logic Levels High (VOH) V Output Logic Levels Low (VOL) V 0.1*VDD 32.768KHz ns 200 1.0000MHz - 29.999MHz ns 10 30.000MHz - 74.999MHz ns 8 75.000MHz - 133.000MHz ns Rise (TR) and Fall (TF) Time Remarks Symmetry (Duty Cycle) 0.9*VDD 5 % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMD 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Tri-State or NC Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 27.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 30.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMD 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 27.000MHz Frequency - 30.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMD 4 Pad CMOS Oscillator SXO32C Series 3.2mm x 2.5mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO32C3B171-8.000M
物料型号:SXO32C系列 器件简介:3.2mm x 2.5mm尺寸的陶瓷SMD CMOS振荡器,适用于微处理器、SONET/SDH/DWDM、存储区域/网络、数字视频、基站等应用。 引脚分配:1-三态或无连接,2-地,3-输出,4-Vop 参数特性: - 频率范围:32.768KHz至133MHz - 频率稳定性:±20ppm至±50ppm,具体取决于选项 - 工作温度范围:-40°C至+85°C,有不同选项 - 存储温度:-55°C至+125°C - 供电电压:1.8V、2.5V、3.3V选项 - 输出负载:15pF至50pF,具体取决于选项 功能详解:提供CMOS使能/禁用功能,具有三态功能,支持RoHS标准。 应用信息:适用于多种电子设备,包括微处理器、网络设备、数字视频设备等。 封装信息:3.2mm x 2.5mm的可用陶瓷封装,提供CMOS胶带和卷轴。
SXO32C3B171-8.000M 价格&库存
很抱歉,暂时无法提供与“SXO32C3B171-8.000M”相匹配的价格&库存,您可以联系我们找货
