LFTCXO063715BULK
LFTCXO063715BULK
    IQD
    SMD-8
    有源晶振 19.2MHz 3.3V SMD-8
LFTCXO063715BULK 数据手册
TCXO Specification Part No. + Packaging: LFTCXO063715Bulk Customer Part: Description Temperature compensated crystal oscillator (TCXO) 8 pad version Model Model Issue number IQXT-200-2-B 1 Frequency Parameters Frequency 19.20MHz Frequency Tolerance Tolerance Condition Frequency Stability ±0.50ppm @ 25°C & 3.3V ±0.28ppm Operating Temperature Range Ageing -20.00 to 70.00°C ±0.02ppm max per day, ±1.0ppm max per year Frequency Tolerance (measurement referenced to frequency observed with TA=25°C, Vs=3.3V and within 30 days after ex-works): ±0.5ppm Frequency Stability: TA varied over temperature, measurement referenced to frequency observed with TA=25°C, Vs=3.3V, load=10kΩ//10pF and temperature variable speed less than 2°C per minute. Ageing: TA=25°C, Vs=3.3V and after 1hr of operation. Supply Voltage Variation (measurement referenced to frequency observed with TA=25°C, Vs varied from 3.13V to 3.47V and load=10kΩ//10pF): ±0.1ppm max Load Variation (5% load change measurement referenced to frequency observed with TA=25°C, Vs=3.3V and load=10kΩ//10pF): ±0.1ppm max Short Term Stability (@ 25°C after 10mins power on): 5E-10/s typ @ 10MHz Outline (mm) Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 10.000mA Current: TA=25°C, Vs=3.3V and load=10kΩ//10pF Output Details Output Compatibility Drive Capability Output Level: 0.8V pk-pk min Clipped Sine 10kΩ//10pF Noise Parameters Phase Noise (@ 10MHz typ): -90dBc/Hz @ 10Hz -115dBc/Hz @ 100Hz -135dBc/Hz @ 1kHz -145dBc/Hz @ 10kHz -148dBc/Hz @ 100kHz -150dBc/Hz @ 1MHz Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 14:23 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 TCXO Specification Part No. + Packaging: LFTCXO063715Bulk Customer Part: Environmental Parameters Storage Temperature Range: -55 to 105°C ESD Level: HBM, Class 2: 2000V to 4000V, JEDEC JS-001-2010 Machine Model, Class B: 200V to 400V, JEDEC JS-001-2010 Shock: IEC 60068-2-27, Test Ea: 100G acceleration for 6ms, sinewave, in 3 mutually perpendicular planes Vibration: IEC 60068-2-6, Test Fc: 10Hz-2000Hz, 0.75mm amplitude, 10G acceleration, 30mins per cycle, in 3 mutually perpendicular planes, test duration 2hrs Manufacturing Details Moisture Sensitivity Level: 2 Maximum Reflow Temperature: 260°C (30secs max) Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 2 Packaging Details Pack Style: Bulk Pack Size: 1 Loose in bulk pack Alternative packing option available Outline (mm) -A = 10 pad version Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 14:23 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFTCXO063715BULK 价格&库存
很抱歉,暂时无法提供与“LFTCXO063715BULK”相匹配的价格&库存,您可以联系我们找货
