LFXTAL012504REEL
LFXTAL012504REEL
    IQD
    HC-49S/SMD
    无源晶振 24MHz ±30ppm 16pF 40Ω -10℃~+60℃
LFXTAL012504REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL012504Reel Customer Part: Description Industry standard SMD crystal Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Lead wires are mounted onto a plastic former to create a gull wing mount Model HC49/4HSMX Model Issue number 17 Frequency Parameters Frequency 24.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm typ per year @ 25°C Outline (mm) Electrical Parameters 16.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C RoHS Terminations RoHS Reflow Temp 260°C max for 10s max Typical Frequency vs Temperature Curves Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 1 Sep 21 8:56 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL012504REEL
1. 物料型号:LFXTAL012504Reel,客户部件号未提供。 2. 器件简介:这是一个工业标准SMD晶体,采用电阻焊接,惰性气体中密封,玻璃金属封接引线,HC49/4HSMX型号。 3. 引脚分配:文档中未明确提供引脚分配信息。 4. 参数特性: - 频率:24.0MHz - 频率容差:±30.00ppm - 环境参数容差:±50.00ppm - 工作温度范围:-10.00到60.00°C - 基频:基础 - 老化:±5ppm典型每年在25°C - 外形尺寸:11.4+0.2mm x 16.00mm 5. 功能详解:文档中未提供详细的功能解释。 6. 应用信息:文档中未提供应用信息。 7. 封装信息: - 封装类型:SMD - 封装细节:引线安装在塑料基板上,形成海鸥翼安装 - 负载电容(CL):7pF最大 - 并联电容(C0):16.00pF - 驱动水平:最大500µW - ESR:最大40.00Ω - 尺寸:10.3mm最大 - 抗冲击:981m/s², 6ms, 在三个互相垂直的平面上各3次 - 抗振动:10Hz-60Hz, 0.75mm振幅, 60Hz-500Hz, 98.1m/s², 30分钟在三个互相垂直的平面上 - 存储温度范围:-55至125°C - RoHS状态:符合2015/863/EU - 回流温度:最大260°C,10秒最大 - MSL等级:不适用 - 包装细节:卷装,符合EIA-481-D标准,包装大小:1,000 8. 销售办公室联系方式:提供了英国、法国、德国、美国的销售办公室联系电话和电子邮件地址。
LFXTAL012504REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL012504REEL”相匹配的价格&库存,您可以联系我们找货
LFXTAL012504REEL
    • 1+4.96800
    • 200+1.98720
    • 500+1.92240
    • 1000+1.89000
