Crystal Clock Oscillator Specification
Part No. + Packaging: LFSPXO076034Reel
Customer Part:
Description
1.2V low voltage oscillator in a hermetically sealed 2.5 x 2.0mm
surface mount ceramic package.
Model
IQXO-691 2520-12
Model Issue number
2
Frequency Parameters
Frequency
25.0MHz
Frequency Stability
±50.00ppm
Operating Temperature Range
Ageing
-40.00 to 85.00°C
±3ppm max in 1st year @ 25°C
Electrical Parameters
Supply Voltage
Current Draw
1.2V ±5%
10.000mA
Output Details
Output Compatibility
Drive Capability
Rise and Fall Time
Duty Cycle
Output Voltage Levels:
Output Low (VoL): 10%Vs max
Output High (VoH): 90%Vs min
Start Up Time: 10ms max
Outline (mm)
CMOS
15pF max
7.0ns max
45/55%
Output Control
Standby Operation:
Logic ‘1’ (≥70% Vs) to pad 1 enables oscillator output.
Logic ‘0’ (≤30% Vs) to pad 1 disables oscillator output; when
disabled the oscillator output goes to the high impedance
state.
No connection to pad 1 enables oscillator output (internal
pull-up resistor).
Stand-by Current: 100μA max
Recommended Solder Pad Layout
Noise Parameters
RMS Phase Jitter (12kHz to 20MHz): 1ps max
Environmental Parameters
Storage Temperature Range: -55 to 125°C
Mechanical Shock: MIL-STD-883, Method 2002, Condition B.
Vibration: MIL-STD-883, Method 2007, Condition A.
Moisture Resistance: MIL-STD-883, Method 1004.
Thermal Cycling: MIL-STD-883, Method 1010, Condition B.
Solderability: MIL-STD-883, Method 2003.
Resistance to Soldering Heat: MIL-STD-202, Method 210,
Condition K.
Fine Leak Test: MIL-STD-883, Method 1014, Condition A.
Gross Leak Test: MIL-STD-883, Method 1014, Condition C.
Manufacturing Details
Note: Please connect a bypass capacitor of 0.1μF between
+Vs and circuit ground.
RoHS Terminations
Au
RoHS Reflow Temp
260°C max for 10secs max
Sales Office Contact Details:
UK: +44 (0)1460 270200
France: 0800 901 383
Germany: 0800 1808 443
USA: +1.760.318.2824
Printed on 3 Aug 21 16:50 using Part Data Sheet V1.0018
Email: info@iqdfrequencyproducts.com
Web: www.iqdfrequencyproducts.com
Page 1 of 2
Customer Part:
Compliance
RoHS Status (2015/863/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Compliant
Compliant
1
Packaging Details
Pack Style: Reel
Pack Size: 3,000
Tape & reel in accordance with EIA-481D
Alternative packing option available
Page 2 of 2
很抱歉,暂时无法提供与“LFSPXO076034REEL”相匹配的价格&库存,您可以联系我们找货
