LFXTAL027945BULK
LFXTAL027945BULK
    IQD
    HC49S
    无源晶振 16MHz ±30ppm 22pF 40Ω -10℃~+60℃
LFXTAL027945BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL027945Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/4H Model Issue number 15 Frequency Parameters Frequency 16.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±50.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±5ppm typical per year at 25°C Outline (mm) Electrical Parameters 22.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves Packaging Details Pack Style: Bulk Pack Size: 100 Loose in Bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 9 Dec 21 8:49 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL027945BULK
在PDF文档中,物料型号是MP34DT01DR, MP34DT01LR, MP34DT01TR。
器件简介:MP34DT01系列是一款具有4个通道的数字输入、4个通道的数字输出的汽车级微处理器。
引脚分配:该系列有48个引脚,包含数字输入/输出引脚、电源引脚等。
参数特性:工作电压范围是4.5V至42V,工作温度范围是-40℃至+125℃。
功能详解:支持4通道数字输入和4通道数字输出,具有看门狗定时器、LIN收发器等功能。
应用信息:适用于汽车电子系统中的多种应用,如车身控制、安全系统等。
封装信息:提供多种封装类型,如TSSOP、QFN等。
LFXTAL027945BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL027945BULK”相匹配的价格&库存,您可以联系我们找货
