C1E-30.000-8-3050-X1-R 数据手册
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Ltr
Revisions
Appr
Date
Electrical Specifications:
Frequency Range
16.000 to 54.000
Mode of Oscillation
Fundamental
16.000 to 54.000
Frequency Tolerance at 25°C
±50
Frequency Stability over Temperature Range
±100
Operating Temperature Range
-40 to +125
Storage Temperature Range
-55 to +125
Aging
±3
Load Capacitance
7 to 32 and Series Resonance
Shunt Capacitance
3.0
Equivalent Series Resistance (ESR)
See ESR Table
Drive Level
100
Insulation Resistance
500 at at 100 Vdc ± 15 Vdc
MHz
PPM Max
ºC
PPM Max/Year
Frequency Range and ESR Values:
Frequency Range in MHz
ESR Ohm Max
Mode of Operation
16.000 to 19.199
200
Fundamental
19.200 to 25.999
100
Fundamental
26.000 to 35.999
80
Fundamental
36.000 to 54.000
60
Fundamental
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: May 1, 2016
Microprocessor Crystal Unit
Automotive Temperature Range
Low Profile
2.0 x 1.6 millimeter Surface Mount
General Product Specification
Part Number:
C1E X1 Series
www.aker-usa.com
pF
Ohms
uW Typ
M Ohms
Mechanical Outline:
2.0 ± 0.15
1.6 ± 0.15
#4
Ceramic Base
#3
Metal Lid
AKER
#1
#2
0.5 Max.
1.28
0.7
#2
#4
#3
0.78
0.48
0.5
0.98
#1
0.88
0.58
#2:GND #4:GND
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: May 1, 2016
P/N:
C1E X1 Series
www.aker-usa.com
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
2.3
8.0
AKER
AKER
AKER
AKER
AKER
A
AKER
AKER
AKER
A
3.5
B
B
1.0
4.0
0.65
1.9
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: May 1, 2016
P/N:
C1E X1 Series
www.aker-usa.com
How to build a Part Number:
Series
Package
Frequency
C
1E
16.000 to 54.000
7
10
12
16
18
Load Capacitance
Frequency Tolerance (Note 1)
Frequency Stability (Note 1)
50
100
Temperature Range
X1
M
R
R3
Packaging
Parameter
2.0 x 1.6 mm Seam Seal
MHz
7 pF
10 pF
12 pF
16 pF
18 pF
20 pF
32 pF
±50 PPM
±100 PPM
-40 to +125 ºC
250pcs / Reel
1000pcs / Reel
3000pcs / Reel
Part Number Example:
C1E-50.000-10-50100-X1-R
C1E- 1.6 x 2.0 mm SMD Seam Seal Crystal Unit
50.000 MHz Nominal Frequency
10 pF Load Capacitance
50100: ±50 PPM Frequency Tolerance and ±100 PPM Frequency Stability
Fundamental Mode
-40 to +125° C Temperature Range
R: Tape and Reel Packaging - 1000pcs
Notes:
1- Frequency Tolerance and Stability options are limited due to physical size.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped on tape only.
4- Specification subject to change without notice.
Page:
4/4
Date: May 1, 2016
P/N:
www.aker-usa.com
C1E X1 Series
C1E-30.000-8-3050-X1-R 价格&库存
很抱歉,暂时无法提供与“C1E-30.000-8-3050-X1-R”相匹配的价格&库存,您可以联系我们找货
