12.87150
12.87150
    GEYER
    SMD3215_2P
    无源晶振 32.768kHz ±20ppm 12.5pF 70kΩ -40℃~+85℃
12.87150 数据手册
Quartz Crystal SMD-version part no. 12.xxxxx model KX–327NHT frequency operating temperature frequency tolerance at +25°C temperature tolerance (parabolic coefficient) 32.768 kHz -40° ~ +85°C standard ±20 ppm available ±10 ppm (-0.035±10%)×10-6/℃2 turnover temperature storage temperature range load capacitance CL motional capacitance (C1) series resistance R1 aging at +25°C (first year) max. shunt capacitance Co +25°C ±5°C -55°C ~ +125°C standard 12.5 pF available 7 pF, 9 pF 0.0036 pF, typ. standard 70k Ohm max. available 50k Ohm max. available 20k Ohm typ., 40k Ohm max. ±3 ppm 1.3 pF (1.0 pF typ.) 1.0 µW max., 0.1µW typ 20000 3000 pcs. drive level quality factor (Q) min. contents of reel Dimensions (mm): Reflow soldering condition: Tape specification: Suggested soldering pad: reel diameter 180 mm GEYER Electronic GmbH. Lochhamer Schlag 5 82166 Gräfelfing/München Tel. +49 89 546868-0 quartz@geyer-electronic.de www.geyer-electronic.de Version 22.06.2021
12.87150 价格&库存
很抱歉,暂时无法提供与“12.87150”相匹配的价格&库存,您可以联系我们找货
  • 3000+3.727393000+0.48220
  • 6000+3.573376000+0.46227
  • 9000+3.486299000+0.45101
  • 15000+3.3796315000+0.43721
  • 21000+3.3112221000+0.42836
库存:9583
12.87150
  • 1+6.112881+0.79080
  • 10+5.2767710+0.68263
  • 25+4.9896525+0.64549
  • 50+4.7843250+0.61893
  • 100+4.58595100+0.59327
  • 250+4.33666250+0.56102
  • 500+4.15749500+0.53784
  • 1000+3.985371000+0.51557
库存:9583
12.87150
  • 3000+3.108803000+0.40217
  • 6000+2.376476000+0.30744
  • 9000+2.353349000+0.30444
  • 15000+2.3294115000+0.30135
  • 21000+2.3054821000+0.29825
库存:48000
12.87150
    • 1+8.07840
    • 200+3.22920
    • 500+3.12120
    • 1000+3.06720
