LFXTAL003327BULK
LFXTAL003327BULK
    IQD
    HC-49U
    无源晶振 11MHz ±20ppm 30pF 35Ω -10℃~+60℃
LFXTAL003327BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL003327Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Standard 2 leg HC49 package Model Model Issue number HC49 15 Frequency Parameters Frequency 11.0MHz Frequency Tolerance Frequency Stability ±20.00ppm ±30.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±3ppm typical per year Outline (mm) Electrical Parameters 30.00pF 7pF max Load Capacitance Shunt Capacitance Drive Level ESR 1mW max 35.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 12 Dec 21 13:12 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL003327BULK
- 物料型号:LFXTAL003327 - 封装类型:HC49,标准2腿HC49封装 - 频率参数: - 频率:11.0MHz,频率容差为±20.00ppm,频率稳定性为±30.00ppm - 工作温度范围:-10.00至60.00°C - 谐波阶数:基础 - 老化率:典型每年±3ppm - 外形尺寸(mm):10.2 x 6.31 x 7.00 - 电气参数: - 负载电容:30.00pF,最大7pF - 并联电容:未提供具体数值 - 驱动水平:ESR未提供具体数值 - 环境参数: - 冲击:981m/s²,6ms,每个相互垂直的平面上3次 - 振动:10Hz-60Hz,0.75mm振幅,60Hz-500Hz,98.1m/s²,30分钟,每个相互垂直的平面上 - 存储温度范围:-55至125°C - RoHS状态:符合2015/863/EU - REACh状态:符合 - MSL等级:不适用 - 包装详情:散装,每包100个,有其他包装选项可用 - 销售办公室联系方式:提供了英国、法国、德国、美国的联系电话和电子邮件地址 - 网页:www.iqdfrequencyproducts.com
LFXTAL003327BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL003327BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL003327BULK
  • 1+16.280531+2.10632
  • 5+11.013815+1.42493
  • 25+7.2493825+0.93790
  • 100+5.73836100+0.74241
  • 500+4.35836500+0.56387
LFXTAL003327BULK
    • 25+6.02962
    • 50+5.90465
    库存:298
    LFXTAL003327BULK
    • 1+15.11983
    • 5+10.22801
    • 25+6.73164
    • 100+5.32781
    • 500+4.04497
