LFXTAL002995BULK
LFXTAL002995BULK
    IQD
    DIP-2
    无源晶振 32.768kHz ±20ppm 12.5pF 50kΩ -40℃~+85℃
LFXTAL002995BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL002995Bulk Customer Part: Description Through-hole cylinder crystal in a press-sealed metal can -3X8 Leaded crystal in a press sealed metal can 3 x 8mm Model WATCH-3X8 Model Issue number 13 Frequency Parameters Frequency 32.7680kHz Frequency Tolerance Tolerance Condition Overtone Order Ageing ±20.00ppm @ 25°C Fundamental ±5ppm max per year @ 25°C Electrical Parameters Outline (mm) 12.50pF 2.5pF typ Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 1.0µW max 50.00kΩ max Environmental Parameters Drop: 75cm drop (3 times) onto hard wooden board Operable Temperature Range: -40 to 85°C Storage Temperature Range: -40 to 85°C Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency Stability Characteristics Packaging Details Pack Style: Bulk Pack Size: 1,000 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 5 Aug 21 8:55 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Quartz Crystal Specification Part No. + Packaging: LFXTAL002995Bulk Customer Part: Typical Frequency Stability Characteristics Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 5 Aug 21 8:55 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFXTAL002995BULK
PDF文档中包含了以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光耦器件,用于隔离输入和输出电路,提高系统的抗干扰能力。
3. 引脚分配:共有6个引脚,分别为Anode、Cathode、Collector、Emitter、Gate1和Gate2。
4. 参数特性:工作电压范围为3V-15V,最大功耗为150mW,隔离电压为5kV。
5. 功能详解:EL817具有高隔离性、低功耗和快速响应的特点,适用于数字信号传输。
6. 应用信息:主要用于工业控制系统、医疗设备和通信设备等领域。
7. 封装信息:采用DIP-6封装方式,尺寸为9.1mm x 3.6mm。
LFXTAL002995BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL002995BULK”相匹配的价格&库存,您可以联系我们找货
