PYEUCJJANF-76.800000 数据手册
PY-U Type Crystal Oscillator
FASTXO 2.5 x 2.0 mm SMD XO Frequency
up to 200MHz
Actual Size
FEATURE
- Typical 2.5 x 2.0 x 0.81 mm ceramic SMD package
- Operation supply voltage: 1.8V, 2.5V and 3.3V
- FASTXO series, Fast delivery at any frequency
- Tri-State Enable/Disable
- Frequency Stability ±20ppm over -40oC to 105oC
- Pb-free/RoHS compliant
RoHS Compliant
TYPICAL APPLICATION
- Computer Peripherals
- Set-top Box , HDTV
- DSC, PDA
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
0.1µF
1.625±0.10
#4
2.00±0.20
#1
#2
#2
[ SIDE VIEW ]
Pin#
1
2
3
4
0.81±0.15
0.29
#1
0.675±0.10
1.225
#3
#3
1.225±0.10
#4
[ BOTTOM VIEW ]
0.80
2.50±0.20
0.57±0.10
[ TOP VIEW ]
0.675
1.625
Function
Tri-State
GND
Output
VDD
0.90
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Supply Voltage Variation
Frequency Range
Supply Current (@15pf Loading)
Output Level
Transition Time
2.5V
1.8V
Unit
Min.
Max.
Min.
Max.
Min.
Max.
VDD-5%
VDD+5%
VDD-5%
VDD+5%
VDD-5%
VDD+5%
V
1
200
1
200
1
125
MHz
mA
35
30
Output High
90%VDD
90%VDD
90%VDD
V
Output Low
10%VDD
10%VDD
10%VDD
V
nSec
Rise Time / Fall Time
Duty Cycle
Startup Time
2
2
3
45
55
45
55
45
55
8
8
8
mSec
Output Enable
0.7 x VDD
0.7 x VDD
0.7 x VDD
V
Output Disable
0.3 x VDD
0.3 x VDD
0.3 x VDD
V
Stand by Current (@PD Mode)
400
400
400
uA
Stand by Current (@OE Mode)
mA
2
2
2
pSec
ppm
Tri-State
Output Loading
15
RMS Phase Jitter (12KHz to 20MHz)
Aging (@ 25oC, First Year)
Storage Temp. Range
15
15
pf
3
3
3
-50
+125
-50
+125
-50
+125
o
C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
+ Transition times are measured between 10% and 90% of VDD, with an output load of 15pF.
FREQ. STABILITY vs. TEMP. RANGE
Temp.
(°C)
ppm
±15
-20~+70
-40~+85
-40~+105
50
*O: Available △: Conditional X: Not available
*Inclusive of calibration @ 25 oC ,operating temperature rrange,input
Voltage variation,load variation,aging (1st year),shock,and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(8) 05/2021
41
PYEUCJJANF-76.800000 价格&库存
很抱歉,暂时无法提供与“PYEUCJJANF-76.800000”相匹配的价格&库存,您可以联系我们找货
