LFXTAL003231BULK
LFXTAL003231BULK
    IQD
    HC-49U
    无源晶振 16MHz ±20ppm 30pF 35Ω -10℃~+60℃
LFXTAL003231BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL003231Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Standard 2 leg HC49 package Model Model Issue number HC49 15 Frequency Parameters Frequency 16.0MHz Frequency Tolerance Frequency Stability ±20.00ppm ±30.00ppm Operating Temperature Range -10.00 to 60.00°C Overtone Order Ageing Fundamental ±3ppm typical per year Outline (mm) Electrical Parameters 30.00pF 7pF max Load Capacitance Shunt Capacitance Drive Level ESR 1mW max 35.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 12 Dec 21 12:02 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL003231BULK
物料型号:LFXTAL003231 封装类型:Industry standard leaded package 器件简介:HC49型号的石英晶体,采用惰性气氛下电阻焊接、密封的玻璃至金属密封工艺。 引脚分配:文档中未明确提供引脚分配信息。 参数特性: - 频率:16.0MHz ±20.00ppm - 频率容差:±30.00ppm - 负载电容:30.00pF - 谐振电容:最大7pF - 驱动水平:最大1mW - ESR:最大35.00Ω 功能详解:文档中未提供详细的功能详解应用信息:文档中未提供应用信息封装信息:标准2腿HC49封装,尺寸为10.2mm x 6.31mm x 7mm。 环境参数:包括冲击和振动测试标准。 存储温度范围:-55至125°C RoHS和REACh合规性:符合2015/863/EU和REACh标准。 MSL等级:JDEC-STD-033标准。 包装详情:散装,每包100个,有其他包装选项。 销售办公室联系方式:提供了英国、法国、德国、美国的联系电话和电子邮件。
LFXTAL003231BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL003231BULK”相匹配的价格&库存,您可以联系我们找货
