LFXTAL078426BULK
LFXTAL078426BULK
    IQD
    HC49S
    无源晶振 11.0592MHz ±30ppm 30pF 40Ω -10℃~+70℃
LFXTAL078426BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL078426Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/3.5H Model Issue number 15 Frequency Parameters Frequency 11.05920MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -10.00 to 70.00°C Overtone Order Ageing Fundamental ±5ppm typical per year @ 25°C Outline (mm) Electrical Parameters 30.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves for various angles of AT-cut crystals Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 12 Dec 21 21:14 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL078426BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL078426BULK”相匹配的价格&库存,您可以联系我们找货
