LFXTAL078570BULK
LFXTAL078570BULK
    IQD
    HC49S
    无源晶振 10MHz ±30ppm 18pF 40Ω -10℃~+70℃
LFXTAL078570BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL078570Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/3.5H Model Issue number 15 Frequency Parameters Frequency 10.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -10.00 to 70.00°C Overtone Order Ageing Fundamental ±5ppm typical per year @ 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves for various angles of AT-cut crystals Packaging Details Pack Style: Bulk Pack Size: 100 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 12 Dec 21 22:04 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL078570BULK
1. 物料型号:LFXTAL078570,采用工业标准引线封装,具有电阻焊接和惰性气体中密封的玻璃到金属密封。
2. 器件简介:文档描述了一个石英晶体,具体型号为HC49/3.5H。
3. 引脚分配:文档中没有明确说明引脚分配,但提到了工业标准引线封装。
4. 参数特性: - 频率:10.0MHz,频率公差为±30.00ppm @ 25°C,频率稳定性在-10.00到70.00°C范围内为±50.00ppm。 - 负载电容(CL):18.00pF。 - 并联电容(C0):最大7pF。 - 驱动电平:500µW最大。 - ESR(等效串联电阻):最大40.00Ω。
5. 功能详解:文档中没有详细描述功能,但提到了频率稳定性和老化特性,例如基本频率的典型年老化率为±5ppm。
6. 应用信息:文档中没有明确说明应用信息,但石英晶体通常用于时钟信号源和频率控制。
7. 封装信息: - 封装类型:工业标准引线封装。 - 封装尺寸:4.88±0.2 mm(高度),11.35 mm最大(直径)。 - 包装详情:散装,每包100个,提供其他包装选项。
LFXTAL078570BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL078570BULK”相匹配的价格&库存,您可以联系我们找货
