SWS1129D16-32.768KT
SWS1129D16-32.768KT
    SUNTSU
    SMD1610_2P
    无源晶振 32.768kHz ±20ppm 9pF 90kΩ -40℃~+85℃
SWS1129D16-32.768KT 数据手册
Ceramic SMT 2 Pad Watch Crystal SWS112 Series 1.6mm x 1.0mm Features Applications • ±20ppm (Tolerance) Available • Real Time Clock • Ultra-Miniature Package • Measurement instruments • Tape and Reel • Wireless Applications Part Numbering Guide SWS 11 2 12 D 48 - 32.768K FREQUENCY kHz SUNTSU WATCH SMT CRYSTAL 1.6mm x 1.0mm 2 PAD LOAD CAPACITANCE 12 : 12.5pF 9 : 9.0pF COMPLIANT OPERATING TEMPERATURE RANGE 16 : -10°C - +60°C 48 : -40°C - +85°C FREQUENCY TOLERANCE D : ±20ppm Cage Code: 4GUT4 To customize your parameters contact a Suntsu representative. Electrical Parameters Units Frequency Range kHz Frequency Tolerance at +25ºC ppm Frequency Stability vs. Aging ppm Frequency Coefficient (ß) ppm/T Minimum Typical Maximum Remarks 32.768 2 -20 +20 -3 +3 -0.040 Operating Temperature °C -40 Turnover Temperature °C +20 Storage Temperature °C -55 Load Capacitance pF Shunt Capacitance pF Drive Level µW Insulation Resistance MΩ Equivalent Series Resistance kΩ -0.030 -0.020 +85 +25 First year @ +25ºC. See part numbering guide for options. +30 +125 12.5 See part numbering guide for options. 1.4 0.5 500 @ 100VDC ± 15V. 90 Outline Drawing & Recommended Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 2 Pad Watch Crystal SWS112 Series 1.6mm x 1.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K Moisture Resistance MIL-STD-883, Method 1004 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Solderability MIL-STD-883, Method 2003 Reflow Profile & Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs / Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SWS1129D16-32.768KT 价格&库存
很抱歉,暂时无法提供与“SWS1129D16-32.768KT”相匹配的价格&库存,您可以联系我们找货
