QT161S-48.000MAAQ-T
QT161S-48.000MAAQ-T
    QST(矽睿)
    SMD1612_4P
    无源晶振 48MHz ±30ppm 10pF 80Ω -20℃~+70℃
QT161S-48.000MAAQ-T 数据手册
QT161S MHz Crystal Fuel The Digital World Features ● ● ● ● ● Applications Frequency range : 24MHz to 66MHz Ultra compact and thin AuSn sealing, ceramic SMD package External dimensions (mm) L : 1.6 x W : 1.2 x H : 0.35 RoHS compliant & Pb free ● ● ● ● ● BT, BLE, W-LAN, NFC SiP modules Mobile phone, Wearables Internet of Things (IoT) Portable consumer products Electrical Characteristics Item QT161S Frequency Range F0 24MHz ~ 66MHz Frequency Tolerance Ftol ±30ppm, ±20ppm, ±10ppm Frequency Stability over Operating Temperature Range (refer to 25°C) Operating Temperature Range Fstab TOTR ±30 ppm ±20 ppm ±10 ppm ±10 ppm ±30 ppm ±20 ppm ±60 ppm -20°C ~ +70°C -40°C ~ +85°C -40°C ~ +125°C Shunt Capacitance C0 3pF Max. Drive Level DL 1 ~ 200μW (50μW Typ.) Load Capacitance CL 6pF, 8pF, 10pF, 12pF Aging Faging ±3 ppm Max. Storage Temperature Range TSTR -55°C ~ +125°C Conditions at 25°C -20°C ~ +70°C -30°C ~ +85°C -40°C ~ +85°C -40°C ~ +125°C at 25°C ± 3°C,first year Motional Resistance (ESR) Fundamental 24 ~ 30 MHz 30 ~ 66 MHz Rev. 1.05 100Ω Max. 80Ω Max. Page 1 www.qstproducts.com QT161S MHz Crystal Fuel The Digital World Dimensions (Unit: mm) Ordering Information QT161S - 27.000M A H E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Tape & Reel Load Capacitance Frequency Tolerance (at 25°C) A D E B V Q E ± 30 ppm ± 20 ppm ± 10 ppm 6 pF 8 pF 10 pF 12 pF Frequency Stability (over Temp.) A D E T H I K Rev. 1.05 ± 30 ppm ± 20 ppm ± 10 ppm ± 10 ppm ± 30 ppm ± 20 ppm ± 60 ppm ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -20°C ~ +70°C ) ( -30°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +125°C ) Page 2 www.qstproducts.com QT161S MHz Crystal Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.05 60 sec Page 3 Time (sec) www.qstproducts.com
QT161S-48.000MAAQ-T 价格&库存
很抱歉,暂时无法提供与“QT161S-48.000MAAQ-T”相匹配的价格&库存,您可以联系我们找货
