Our Performance Your Reputation
10MHz Low Noise OCXO
NJ-10M-6800 series
NJ-10M-6800 Series in 25.4x22mm SMD package
NJ-10M-6800 series is a 10.000 MHz high performance (VC)OCXO with
low phase noise(LPN). It has excellent temperature versus frequency stability with
many available options. The part comes in a small SMD package which makes it suitable
for reflow soldering during pick and place assembly
FEATURES
RoHS Compliant Standard
APPLICATIONS
Low Phase Noise
Instrument Reference
Small SMD Package
Microwave Communication
Tight Frequency Stability
Clock Reference for Microwave Signal Source
Low Power Consumption
Test & Measurement
Fast Warm-up Time
Telecom Systems
Electrical Frequency Tuning Input
Radar Systems
Reference Voltage Output
RoHS-Compliant (lead-free)
ELECTRICAL SPECIFICATIONS
Test conditions: VDC = +12 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified
1. OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
1.1.
Frequency (Fo)
1.2.
Initial Accuracy
Min.
Typ.
Max.
10.000000
Unit
Test Condition
MHz
@ +25 ±1°C
-0.1
+0.1
ppm
after turn on power 60 minutes
Vco=+5V
1.3.
Waveform
1.4.
Level
1.5.
Load
1.6.
1.7.
Sine wave
+8
+10
+12
dBm
Harmonics
-30
dBc
Spurious
-80
dBc
Ω
50
10Hz to 1MHz from carrier
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
Rev(3)07/2018
Page 1of 4
2. FREQUENCY STABILITY
Parameter
2.1.
Min.
Max.
Unit
±5, ±10, ±20, ±30, ±50, ±100
ppb
-20°C ~ +70°C
-40°C ~ +85°C
°C
Ambient
Typ.
Test Condition
referenced to 25°C
Refer to Table 1 : Ordering Information
Aging
Daily
-0.5
+0.5
ppb
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
-1
+1
ppb
±5% change
2.2.
2.3.
Voltage
2.4.
Short term
2.5.
Load
2.6.
Warm-up
-50
Option A
2.7.
Phase Noise (Max.)
ppb
root Allan variance for τ=1 sec
+1
ppb
±5% change
+50
ppb
in 5 minutes @ +25 ±1°C
0.002
-1
Option B
after 30 days of continuous operation.
referenced to 1 hour
Option C
-105
-110
-115
dBc/Hz
@ 1Hz
-135
-140
-142
dBc/Hz
@ 10Hz
-155
-155
-155
dBc/Hz
@ 100Hz
-165
-165
-165
dBc/Hz
@ 1KHz
-170
-170
-170
dBc/Hz
@ 10KHz
-170
-170
-170
dBc/Hz
@ 100KHz
-170
-170
-170
dBc/Hz
@ 1MHz
3. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Min.
3.1.
Tuning Range
±0.4*
3.2.
Control Voltage
0.5
3.3.
Slope
3.4.
Center Voltage
3.5.
Linearity
Typ.
Max.
Unit
ppm
+9.5
V
+10
Test Condition
Referenced to frequency at nominal Center Voltage
Positive
+5.0
-10
V
* Sufficient to adjust the oscillator to nominal frequency for 10 years. Some unit will have ±0.7ppm tuning range.
4. INPUT POWER (PIN = “+VDC”)
4.1.
Parameter
Min.
Typ.
Max.
Unit
Voltage
+11.4
+12
+12.6
V
Test Condition
Current
2.0
Steady State
4.2.
During Warm-Up
W
@ +25°C, operating -20°C ~ +70°C
2.3
@ +25°C, operating -40°C ~ +85°C
400
500
mA
Refer to Table 1 :
5. REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
Parameter
Min.
Typ.
Max.
Units
5.1.
Voltage
+9.25
+9.5
+9.75
V
5.2.
Source Resistance
5.3.
Load Impedance
100
10
Test Condition
Ohm
Kohm
Rev(3)07/2018
Page 2of 4
6. ENVIRONMENTAL
Parameter
Reference Std.
Test Condition
6.1.
Operable Temperature
-45°C to +90°C
6.2.
Storage Temperature
-50°C to +95°C
Note 1
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
95% RH @ +40°C,non-condensing,240 hours
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
temperature range in 2.1.
Table 1 : ORDERING INFORMATION
Ambient
Temp. (°°C )
-20°°C ~+70oC
Phase Noise Option
Option
A
B
C
±30 ppb
NJ-10M-6815
NJ-10M-6816
NJ-10M-6817
±20 ppb
NJ-10M-6825
NJ-10M-6826
NJ-10M-6827
±10 ppb
NJ-10M-6835
NJ-10M-6836
NJ-10M-6837
±5 ppb
NJ-10M-6845
NJ-10M-6846
NJ-10M-6847
±100 ppb
NJ-10M-6865
NJ-10M-6866
±50 ppb
NJ-10M-6875
NJ-10M-6876
±30 ppb
NJ-10M-6885
NJ-10M-6886
±20 ppb
NJ-10M-6895
NJ-10M-6896
-40oC~+85oC
Phase Noise Test Data
Rev(3)07/2018
Page 3of 4
OUTLINE DRAWING
Rev(3)07/2018
Page 4of 4
很抱歉,暂时无法提供与“NJ-10M-6851”相匹配的价格&库存,您可以联系我们找货
