QVMQF57633-2.0A-51.000
    MERCURY(玛居礼)
    SMD-6
    有源晶振 3.3V SMD-6 51MHz
QVMQF57633-2.0A-51.000 数据手册
QMQF576 Series Temperature Compensated Crystal Oscillators (TCXOs) QVMQF576 Series TCXOs with Voltage Control Function (VCTCXOs) MERCURY Since 1973 QMQF576 and QVMQF576 are QuikXO™ (quick-turn delivery) versions of the MQF576 (a TCXO) and VMQF576 (a VCTCXO) series, respectively. QuikXO™ products, either standard or custom frequencies are produced and shipped from California USA in 3 to 5 days and available at Mercury eCommerce. They are 7.0x5.0x2.5 mm SMD, the supply voltage can be either 2.5 V or 3.3 V and output logics include differential LVEPCL or LVDS (up to 1.5 GHz). The 0.8 ~ 1.6 ps typical phase jitter and lower current consumption (43 mA typical for LVPECL 622.080 MHz at 3.3 V) compared to competitions make the series ideal for multimedia, Ethernet, and networking applications. Relevant Categories: ■ For lower cost with regular lead time, please refer to the non- QuikXO™equivalent the MQF576 and the VMQF576 series ■ For lower phase noise and phase jitter (0.6 p. sec. typical), please refer to the MQN576 and VMQN576 series. ■ For smaller footprint, 3.2 x 2.5 x 1.6 mm 6-pad SMD, with the same electrical performance, please refer to the MQF326, and the VMQF326 series. General Specifications: at Ta=+25°C Output Logic Type LVPECL (code “P”) LVDS (code “D”) TCXO Models QMQF576P25 QMQF576P33 QMQF576D25 QMQF576D33 VCTCXO Models QVMQF576P25 QVMQF576P33 QVMQF576D25 QVMQF576D33 Frequency Range Supply Voltage (VDD) Current Consumption (mA; typical) Load; typical 10 ~ 1500 MHz 10 ~ 1500 MHz +2.5 V ±5% +3.3 V ±5% +2.5 V ±5% +3.3 V ±5% Code “25” Code “33” Code “25” Code “33” 18 MHz: 28 156 MHz: 30 622 MHz: 33 1289 MHz: 37 1500 MHz: 43 18 MHz: 35 156 MHz: 38 622 MHz: 43 1289 MHz: 51 1500 MHz: 52 11 MHz: 19 190 MHz: 23 390 MHz: 24 1289 MHz: 31 1500 MHz: 34 11 MHz: 22 155.5 MHz: 26 250 MHz: 28 1080 MHz: 32 1500 MHz: 35 50 Ω into Vcc - 2.0 V or Thevenin equivalent 100 Ω across the outputs Output “High” Voltage; (VOH) VDD-1.03 V min.; VDD-0.6 V max. 1.4 V typical; 1.6 V max. Output “Low” Voltage; VOL VDD-1.85 V min.; VDD-1.6 V max 1.1 V typical; 0.9 V min. Rise Time (Tr) / Fall Time (Tf) 0.2 nS Typ.; 0.5 nS max. (20% ↔ 80% waveform ) MERCURY 0.2 nS Typ.; 0.4 nS max. (20% ↔ 80% waveform ) www.mercury-crystal.com Taiwan: TEL (886)-2-2406-2779, e-mail: sales-tw@mercury-crystal.com U.S.A.: TEL (1)-909-466-0427, e-mail: sales-us@MercuryUnited.com MERCURY Page 1 of 6 April 22, 2021 Version: a3 Additional Output AC Characteristics for LVDS output (LVDS only) Operating Temperature Frequency Stability vs Differential Output Voltage (VOD): 175 mV min.; 350 mV typical VOD Magnitude Change (ΔVOD): 50 mV max. Offset Voltage (Vos): 1.25 V typical Vos Magnitude Change (ΔVos): 50 mV max. ±2.0 ppm over -40 to +85°C. Spec. code: “2.0A”. ±2.5 ppm over -30 to +85°C. Spec. code: “2.5B”. Custom specification: The code is replaced with a control number assigned by Mercury Voltage Change ±0.2 ppm max. for a ±5% input voltage change Load Change ±0.2 ppm max. for a ±10% load condition change Aging at Ta =+25°C ±2 ppm max. first-year; ±10 ppm max. over 10 years Reflow ±1.0 ppm max., one reflow and measured 24 hours afterward. ±1.0 ppm typical; ±2.0 ppm. max. at +25°C±2°C. Duty Cycle 50% ±5%. At 50% VDD. Current with Output Disabled 18 mA typical Start-up Time 5 m. sec. max. Output Enable Time 200 ns max. Single Side-band Phase Noise (dBc/Hz; typical) Offset Initial Calibration Tolerance (Initial Frequency Accuracy) Output Disable Time 50 ns max. Frequency (MHz) 25 49.152 50 100 156.250 600 1030 1080 1270 1450 Supply Voltage Output Logic 10 Hz 100 Hz 1 kHz 10 kHz 100 kHz 1 MHz 5 MHz 10 MHz 20 MHz 3.3 P 3.3 D 3.3 D 3.3 D 3.3 P 3.3 P 3.3 P 3.3 D 3.3 D 3.3 D -61 -106 -125 -132 -133 -151 -153 – – -85 -108 -121 -126 -127 -146 -154 -157 -160 -80 -103 -117 -124 -127 -145 -148 -150 -152 -73 -96 -109 -119 -120 -138 -143 -145 -144 -63 -91 -109 -115 -116 -137 -147 -150 -155 -59 -81 -96 -102 -104 -125 -132 -136 -139 -53 -75 -93 -94 -97 -119 -129 -133 – -49 -81 -93 -98 -99 -120 -128 -133 -142 -49 -78 -91 -94 -97 -117 -128 -133 -142 -52 -78 -89 -92 -94 -118 -129 -133 – 1.0 1.0 1.1 1.3 1.1 1.1 1.4 1.1 1.2 1.4 Integrated Phase Jitter, RMS 12 kHz to 20 MHz; picosecond Control Voltage Function on Pad 1 (VCTCXOs only) Control Voltage (Vcontrol) Frequency Pulling Range Vcontol center and range: +1.5 V ± 1.0 V. For both 2.5 VDD and 3.3 VDD High pull: +8 ppm min. for Vcontol from 1.5 V to +2.5V Low pull: - 8 ppm min. for Vcontol from 0.5 V to +1.5V Linearity ±5% typical. ±10% max. Transfer Function Positive Transfer Input Impedance 500 KΩ min. Bandwidth 10 kHz min. Measured at -3 dB. Output Enable (OE) Control Output Enable Time Output Disable Time MERCURY Tri-State function on Pad 2 70% of VDD (min.) to enable output. CMOS level. Do not leave this pin floating. If no connection is desired, please contact Mercury. 30% of VDD (max.) to disable the output. Output is high impedance. 200 n. sec. max. 50 n. sec. max. Page 2 of 6 April 22, 2021 Version: a3 Absolute Maximum Rating: Input Voltage Output Voltage Positive Supply Voltage -0.5 V to VDD+0.5 V -0.5 V to VDD+0.5 V 4.2 V Human Body Model (HBM): Exceeds 2000 V. Class 2 per MIL-STD-1686C Machine Model (MM): Exceeds 120 V. Class M2 per MIL-STD-1686C. Note: Power, ground, and outputs are 200 V. Charged-Device Model (CDM): Exceeds 2000 V. Class C6 per MIL-STD-1686C Electrostatic Discharge (ESD) Environmental Performance Specifications Moisture Sensitivity Level RoHS compliant, Pb (lead) free per EU Directive 2002/95/EC 6/6 (2002/95/EC) and WEEE (2002/96/EC). Free of halide, cadmium, hexavalent chromium, lead, mercury, PBB’s, and PBDE’s. Level 2 per IPC/JEDEC J-STD-020D.1 Storage temperature range -55 to +125°C Humidity 85% RH, 85°C, 48 hours Fine Leak / Gross Leak MIL-Std-883, method 1014, condition A / MIL-Std-883, method 1014, condition C Solderability MIL-STD-202F method 208E Reflow 260°C for 10 sec. 2X. Vibration MIL-STD-202F method 204, 35G, 50 to 2000 Hz Shock MIL-STD-202F method 213B, test condition. E, 1000GG ½ sine wave Resistance to Solvent MIL-STD-202, method 215 Temperature Cycling MIL-STD-883, method 1010 Gold (0.3 um to 1.0 um) over nickel (1.27 um to 8.89 um) Green Requirement Pad Surface Finish Part Number Format and Examples: Example 1: QVMQF576D33-2.0A-622.080; Example 3: QMQF576P33-xxxxx-155.520 QVMQF QMQF QMQF 576 576 576 D P P Product Series “QMQF”: TCXO “QVMQF”: VCTCXO Package Code Output Logic “576”: 3.2x2.5 “P”: LVPECL mm 6-pad SMD “D”: LVDS MERCURY Page 3 of 6 Example 2: QMQF576P25-2.5B-148.500; 33 25 33 Supply Voltage “33” for 3.3V “25” for 2.5V 2.0A 2.5B xxxxx - - “2.5B”: The freq. stability is ±2.5 ppm over -30 to +85°C “2.0A”: The freq. stability is ±2.0 ppm over -40 to +85°C “xxxxx”: Custom frequency stability. A control number assigned by Mercury. April 22, 2021 - 622.080 148.500 155.520 The nominal Frequency in MHz. 3 places or more after the decimal. Version: a3 Output OE Function on pad 2 Note: Do not leave this pad floating. If “no-connection” is desired, please contact Mercury. VDD Pad 2 OE Function VIH VIL Disable Time Enable Time High Impedance Phase Noise Plot of QMQF576P33-156.250 MHz, VDD=+3.3V, LVPECL MERCURY Page 4 of 6 April 22, 2021 Version: a3 Package Dimensions and Recommended Solder Pad Layout Pad 1 Pad 2 Pad 3 Pad 4 Pad 5 Pad 6 Test Circuits and Output Waveforms unit: (mm) TCXO: No Connection; VCTCXO: Control Voltage ♦ 70% of VDD (min.) to enable the outputs. CMOS level. Do not leave this pad floating. If “no-connection” is desired, please contact Mercury. ♦ 30% of VDD (max.) to disable the output. Output is high impedance. Ground Output: LVPECL or LVDS Complementary LVPECL or LVDS output Supply Voltage 𝑇1 Duty cycle=(𝑇2) ∗ 100%. Measured at 50% VDD LVPECL MERCURY Page 5 of 6 April 22, 2021 Version: a3 LVDS Recommended Solder Reflow Profile (per IPC/JEDEC J-STD-020D.1) Tp Tsmax Te m pe rat ur e TL Max. Ramp Up Rate=3°C/s Max. Ramp Down Rate=6°C/s tp Tc-5°C User Tp≤Tc tL Preheat Area Tc Tsmin Tc-5°C User tp ts 25 Time 25°C to Peak Time Profile Feature Sn-Pb Eutectic Assembly Pb-free Assembly Preheat/Soak - Temperature min. (Ts min.) - Temperature max. (Ts max.) - Time (ts) (Ts min. to Ts max.) 100⁰C 150⁰C 60 to 120 seconds 150⁰C 200⁰C 60 to 180 seconds Ramp-up rate (TL to Tp) 3⁰C / sec. max. 3⁰C / sec. max. Liquidous temperature (TL ) Time (tL) maintained above TL Peak package body temperature (Tp) 183⁰C 60 to 150 seconds 235⁰C 217⁰C 60 to 150 seconds 260⁰C Time (Tp) within 5⁰C of the classification temperature Tc 10 to 30 seconds 20 to 40 seconds Ramp-down rate (Tp to TL) 6⁰C / second max. 6⁰C / second max. Time 25⁰C to peak temperature 6 minutes max. 8 minutes max. All temperatures refer to the topside of the package, measured on the package body surface. MERCURY Page 6 of 6 April 22, 2021 Version: a3
物料型号: - QMQF576系列TCXOs - QVMQF576系列VCTCXOs
器件简介: - 这些是QuikXO™版本的MQF576和VMQF576系列,分别提供快速交货。 - 产品尺寸为7.0x5.0x2.5 mm SMD,供电电压为2.5V或3.3V。 - 输出逻辑包括差分LVEPCL或LVDS,频率高达1.5 GHz。
引脚分配: - Pad 1: TCXO无连接;VCTCXO控制电压 - Pad 2: 输出使能控制 - Pad 3: 地 - Pad 4: 输出:LVEPCL或LVDS - Pad 5: 互补LVEPCL或LVDS输出 - Pad 6: 供电电压
参数特性: - 频率范围:10 ~ 1500 MHz - 供电电压:+2.5V±5% 或 +3.3V±5% - 典型电流消耗:18 MHz时为28mA至622 MHz时为43mA - 典型相位抖动:0.8 ~ 1.6 ps - 频率稳定性:-40至+85°C下±2.0 ppm
功能详解: - 包括差分输出电压、偏移电压、上升时间/下降时间等详细电气特性。 - VCTOs提供控制电压功能,允许频率牵引。 - 三态功能,通过Pad 2控制输出使能。
应用信息: - 适用于多媒体、以太网和网络应用。
封装信息: - 推荐焊盘布局和尺寸图提供。
环境性能规格: - 符合RoHS标准,无铅,符合EU指令。 - 湿度敏感度等级2,存储温度范围-55至+125°C。
绝对最大额定值: - 输入电压、输出电压、正电源电压等。
测试电路和输出波形: - 提供了LVPECL和LVDS的测试电路图和波形示例。
推荐焊接回流曲线: - 根据IPC/JEDEC J-STD-020D.1标准提供。
QVMQF57633-2.0A-51.000 价格&库存
很抱歉,暂时无法提供与“QVMQF57633-2.0A-51.000”相匹配的价格&库存,您可以联系我们找货
