WTL9M60565VH
WTL9M60565VH
    WTL(维拓)
    HC49S
    无源晶振 18.432MHz ±30ppm 20pF -20℃~+70℃
WTL9M60565VH 数据手册
Quartz Crystal, Series WX7 Resistance Welded HC-49SMD 12.7×4.8×3.8 mm Feature Surface mount type crystal units. A great number of standard frequencies. Higher frequency available and lower equivalent series resistance. Lower cost and highly mass production capability. RoHS Compliant / Pb Free Electrical Specifications Item Specifications Frequency Range(MHZ) 3.2~6 6~8 8~16 Mode AT/Fundamental 16~54 Load Capacitance (CL) 8pF, 10pF, 12pF or Specify Frequency Tolerance( at 25°C ) ±10ppm ~ ±30ppm or specify Operating Temperature Range -20~+70°C or Specify Frequency Stability Over Operating Temperature Range 30~50 50~100 AT/3rd AT/3rd ±10ppm ~ ±30ppm or specify Equivalent Series Resistance (ESR) max. 150Ω 60Ω 50Ω Storage Temperature Range -55~+125°C Shunt Capacitance( C 0 ) 7.0 pF Max 30Ω Drive Level (Typical) 1 μW~500 μW (100μW typical) Aging @25 °C 1st Year (Max) ±3 ppm/year or ±5 ppm/year 80Ω 60Ω Dimension(mm) 4.35 ± 0.5 3.8 ± 0.5 3.8 ± 0.3 0.3 ± 0.1 11.4 ± 0.5 10.6 MAX 0.5 ± 0.2 Suggested Layout 2.0 4.8 MAX 0.5 ± 0.2 0.8 ± 0.2 1.0 MAX 4.5 MAX 4.88 MAX 5.5 4.5 MAX 4.0 5.5 12.7 ± 0.5 17 http://www.wtlcrystals.com Email:wtl@wtlcrystals.com Tel:86-755-82677582
WTL9M60565VH 价格&库存
很抱歉,暂时无法提供与“WTL9M60565VH”相匹配的价格&库存,您可以联系我们找货
