LFXTAL063075REEL
LFXTAL063075REEL
    IQD
    HC-49S/SMD
    无源晶振 17.2032MHz ±30ppm 22pF 40Ω -40℃~+85℃
LFXTAL063075REEL 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL063075Reel Customer Part: Description Industry standard SMD crystal Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Lead wires are mounted onto a plastic former to create a gull wing mount Model HC49/4HSMX Model Issue number 17 Frequency Parameters Frequency 17.20320MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±2°C ±50.00ppm Operating Temperature Range -40.00 to 85.00°C Overtone Order Ageing Fundamental ±5ppm typ per year @ 25°C Outline (mm) Electrical Parameters 22.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Storage Temperature Range: -55 to 125°C RoHS Terminations RoHS Reflow Temp 260°C max for 10s max Typical Frequency vs Temperature Curves Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 31 Aug 21 18:16 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL063075REEL 价格&库存
很抱歉,暂时无法提供与“LFXTAL063075REEL”相匹配的价格&库存,您可以联系我们找货
