S5A3305-100.000-L-X-R
    AKER(安碁科技)
    SMD5032_6P
    有源晶振 100.000000 MHz 3.3V -40℃~+85℃ LVDS
S5A3305-100.000-L-X-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Appr Date Revisions Electrical Specifications: 77.000 to 160.000 ±100 ±50 ±25 ±3 0 to +70 -40 to +85 -55 to +125 Frequency Range Frequency Stability over Temperature Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage 77.000 to 100.000 MHz 101.000 to 160.000 MHz Logic High (Voh) Logic Low (Vol) Input Current Output Voltage Differential Output Voltage (Vod) Offset Voltage (Vos) Output Symmetry Output Type Output Load (Between Q ansd QN) PPM Max ºC 3.3 ± 5% 60 65 1.6 0.9 247 to 454 1.125 to 1.375 45 to 55 LVDS - Complimentary Output 100 77.000 to 100.000 MHz 101.000 to 160.000 MHz Rise and Fall Time 2.5 ± 5% 60 65 1.6 0.9 MHz 1 0.5 1 0.5 Tri-State INH - Pin 1 High - Pin 1 Low - Pin 1 1.75 0.75 Enable-Disable Function Enable High Input Voltage Enable Low Input Voltage Phase Jitter (12 KHz to 20 MHz) Q Pin 4 - QN Pin 5 Operating High Impedance 2.31 0.99 1 4 77.000 to 159.900 MHz 160.000 to 625.000 MHz Vdd mA Max Vdd Min Vdd Max mV V % - : ns Max Vdd Min Vdd Max ps RMS Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Sept. 13, 2007 Clock Oscillator LVDS - Complimentary Output 3.2 x 5.0 millimeter Surface Mount - 6 Pad General Product Specification Part Number: S5A Series www.aker-usa.com Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. PCB Solder Pad Layout: Pad Connection: Top View Page: 2/4 Date: Sept. 13, 2007 P/N: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd S5A Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Sept. 13, 2007 P/N: www.aker-usa.com S5A Series How to build a Part Number: Series Package S 5A Parameter 5.0 x 3.2 mm - 6 Pad Supply Voltage 25 33 +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM - Frequency 77.000 to 160.000 MHz - Output Load L LVDS - Temperature Range See Notes X 0 to +70 ºC -40 to +85 ºC - Packaging R Tape and Reel Part Number Example: S5A3310-155.520-L-X-R S5A: 3.2 x 5.0 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 10: ±100 PPM Temperature Stability 155.520 MHz Nominal Frequency L: LVDS - Complimentary Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: Sept. 13, 2007 P/N: www.aker-usa.com S5A Series
1. 物料型号:S5A系列,具体型号示例为S5A3310-155.520-L-X-R,表示3.2 x 5.0毫米的SMD封装,6个焊盘,+3.3V供电电压,±100 PPM的温度稳定性,155.520 MHz的标称频率,LVDS互补输出,扩展温度范围-40到+85°C,以及胶带和卷轴包装。
2. 器件简介:文档没有提供器件简介,但根据上下文,S5A系列是一个时钟振荡器,具有LVDS互补输出。
3. 引脚分配:引脚1为INH(使能/禁用),引脚2为NC(无连接),引脚3为GND(地),引脚4为Output - Q(输出),引脚5为Comp. Output - QN(互补输出),引脚6为Vdd(供电电压)。
4. 参数特性: - 频率范围:77.000至160.000 MHz - 频率稳定性:±100 PPM最大值 - 老化每年:±3 PPM - 工作温度范围:标准0至+70°C,扩展-40至+85°C - 存储温度范围:-55至+125°C - 供电电压:2.5±5%至3.3±5% Vdd - 输入电流:在77.000至100.000 MHz为60 mA最大,在101.000至160.000 MHz为65 mA最大 - 输出电压:逻辑高(Voh)为1.6 Vdd最小,逻辑低(Vol)为0.9 Vdd最大 - 差分输出电压(Vod):247至454 mV - 偏移电压(Vos):1.125至1.375 V - 输出对称性:45至55%
5. 功能详解: - 使能/禁用功能:INH引脚1高电平使能,低电平高阻抗。 - 使能高输入电压:1.75至2.31 Vdd最小。 - 使能低输入电压:0.75至0.99 Vdd最大。 - 相位抖动:在77.000至159.900 MHz为1 ps RMS。
6. 应用信息:文档没有明确提供应用信息,但时钟振荡器通常用于为电子设备提供稳定的时钟信号。
7. 封装信息:封装为密封陶瓷金属,尺寸为3.2 x 5.0毫米,表面贴装,6个焊盘。
8. 焊接特性:回流焊接最高温度260℃,不超过10秒,预热区温度150℃,持续时间120+20秒,再流区温度230℃,持续时间50+20秒。
S5A3305-100.000-L-X-R 价格&库存
很抱歉,暂时无法提供与“S5A3305-100.000-L-X-R”相匹配的价格&库存,您可以联系我们找货
