LFXTAL024944BULK
LFXTAL024944BULK
    IQD
    HC49S
    无源晶振 16MHz ±30ppm 18pF 40Ω -20℃~+70℃
LFXTAL024944BULK 数据手册
Quartz Crystal Specification Part No. + Packaging: LFXTAL024944Bulk Customer Part: Description Industry standard leaded package Resistance welded, hermetically sealed in an inert atmosphere, glass to metal seals on leads Model HC49/4H Model Issue number 15 Frequency Parameters Frequency 16.0MHz Frequency Tolerance Tolerance Condition Frequency Stability ±30.00ppm @ 25°C ±50.00ppm Operating Temperature Range -20.00 to 70.00°C Overtone Order Ageing Fundamental ±5ppm typical per year at 25°C Outline (mm) Electrical Parameters 18.00pF 7pF max Load Capacitance (CL) Shunt Capacitance (C0) Drive Level ESR 500µW max 40.00Ω max Environmental Parameters Storage Temperature Range: -55 to 125°C Shock: 981m/s², 6ms, 3 times in each of 3 mutually perpendicular planes Vibration: 10Hz-60Hz, 0.75mm amplitude, 60Hz-500Hz, 98.1m/s², 30mins in 3 mutually perpendicular planes Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Typical Frequency vs Temperature Curves Packaging Details Pack Style: Bulk Pack Size: 100 Loose in Bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 25 Nov 21 20:07 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 1
LFXTAL024944BULK 价格&库存
很抱歉,暂时无法提供与“LFXTAL024944BULK”相匹配的价格&库存,您可以联系我们找货
LFXTAL024944BULK
    LF XTAL024944BULK
    • 31+4.3925131+0.56857
    • 100+3.63711100+0.47079
    • 300+3.60053300+0.46605
    • 500+3.41221500+0.44168
    • 1000+2.461961000+0.31868
    • 2500+2.304592500+0.29831
    • 5000+2.218615000+0.28718
    库存:8556
    LFXTAL024944BULK
      LF XTAL024944BULK
      • 1+4.859771+0.62905
      • 10+4.4176910+0.57183
      • 25+4.3172125+0.55882
      • 100+3.57476100+0.46272
      • 300+3.53880300+0.45806
      • 500+3.35372500+0.43411
      • 1000+2.419761000+0.31322
      • 2500+2.265092500+0.29320
      • 5000+2.180575000+0.28226
      库存:8558
