VLEUWLJTNF-122.880000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 3.3V 122.88MHz SMD-4
VLEUWLJTNF-122.880000 数据手册
High Frequency, Very Low Noise and Low g-Sensitivity VCXO VLEU-Type series 14 x 9mm SMD package FEATURE - VLEU-Type series is a high frequency high performance VCXO offering high frequency and very low phase noise/Low g-Sensitivity. The part comes in a small SMD package which makes it suitable for reflow soldering during pick and place assembly. - Low Phase Noise - Low g-Sensitivity - Small SMD Package - Low Power Consumption TYPICAL APPLICATION - Instrument - Microwave Communication - Test & Measurement - Telecom Systems - Satellite Communication DIMENSION (mm) [ BOTTOM VIEW ] 5.08 ± 0.10 6.00 ± 0.10 9.10 ± 0.15 #2 #2 5.08 ± 0.10 5.08 #1 2.54 1.524 3.60 ± 0.15 [ SIDE VIEW ] #4 5.5 #3 #3 1.55 ± 0.10 13.90 ± 0.10 #1 RoHS Compliant SOLDER PAD L AYOUT (mm) [ TOP VIEW ] #4 Actual Size Pin# 1 2 3 4 12.90 ± 0.20 Function Vcon 1.6 GND Output VDD ELECTRICAL SPECIFICATION OUTPUT (PIN = “R.F. OUTPUT”) Max. Unit Frequency (Fo) 50 125 MHz Frequency Stability (Overall) -25 +25 ppm Parameter Min. Typ. Operating Temperature -20oC ~ +70oC Range -40oC ~ +85oC Storage Temperature Range -45oC ~ +90oC Waveform o C o C CMOS Duty Cycle 45 Rise / Fall Time Level Test Condition Standard Frequency:100MHz, 122.88MHz, 125MHz Frequency stability includes frequency tolerance@25 oC and frequency stability vs. operating temperature range and voltage variance and 10 years aging. VOL VOH % 3 nSec 0.5 V 4.5 (20%VDD ~ 80%VDD) V Load 15 g-Sensitivity 1.5 Phase Noise (100MHz) (Max.) 55 pF ppb/g -80 dBc/Hz @ 10Hz -115 dBc/Hz @ 100Hz -140 dBc/Hz @ 1KHz -160 dBc/Hz @ 10KHz -168 dBc/Hz @ 100KHz -170 dBc/Hz @ 1MHz Note: not all combination of options are available. Other specifications may be available upon request. Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(6) 04/2021 83 ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”) Parameter Min. Pulling Range Typ. Max. ±25 Control Voltage +3.3 Slope Positive Center Voltage +1.65 VC Input Impedance V V -10 Modulation Bandwidth Test Condition ppm 0 Linearity Unit +10 % 1 KHz 100 Mohm INPUT POWER (PIN = “+VDC”) Parameter Voltage Min. Typ. Max. +3.135 +3.3 +3.465 V 30 mA Current Unit Test Condition At maximum supply voltage ENVIRONMENTAL Parameter Reference Std. Vibration Test DIN EN 60068-2-6 Thermal Shock DIN EN 60068-2-14 Mechanical Shock DIN EN 60068-2-27 Test Condition 10~55Hz, 0.75mm Peak; 55~2000Hz, 10g Peak. 10 Cycles; 3 axis; 1Oct./min. 30 min. @each temperature 10 cycles, Transfer
VLEUWLJTNF-122.880000 价格&库存
很抱歉,暂时无法提供与“VLEUWLJTNF-122.880000”相匹配的价格&库存,您可以联系我们找货
  • 1+375.155441+48.53637
  • 10+351.1491610+45.43052
库存:86
  • 100+286.88695100+37.11649
库存:86
