MCXO Specification
Part No. + Packaging: LFMCXO064078Bulk
Customer Part:
Description
Microcomputer Compensated Crystal Oscillator with voltage
control (MCXO)
8 pad package
Model
Model Issue number
IQMT-100-3-B
1
Frequency Parameters
Frequency
12.80MHz
Frequency Tolerance
Tolerance Condition
Frequency Stability
±0.50ppm
@ 25°C, 3.3V & VC=1.65V
±0.05ppm
Operating Temperature Range
Ageing
-40.00 to 85.00°C
±0.02ppm max per day,
±1.0ppm max per year
Frequency Tolerance (measurement referenced to frequency
observed with TA=25°C, Vs=3.3V, VC=1.65V and within 30
days after ex-works)
Frequency Stability: TA varied over temperature, measurement
referenced to frequency observed with Fref = (Fmax-Fmin)/2,
Vs=3.3V, VC=1.65V, load=15pF and temperature variable
speed less than 2°C per minute.
Ageing: TA=25°C, Vs=3.3V, VC=1.65V and after 1hr of
operation.
Supply Voltage Variation (measurement referenced to
frequency observed with TA=25°C, Vs varied from 3.13V to
3.47V, VC=1.65V and load=15pF): ±0.05ppm max
Load Variation (5% load change measurement referenced to
frequency observed with TA=25°C, Vs=3.3V, VC=1.65V and
load=15pF): ±0.1ppm max
Short Term Stability (@ 25°C after 10mins power on): 2E-10/s
typ @ 10MHz
Outline (mm)
Electrical Parameters
3.3V ±5%
Supply Voltage
Current Draw
10.000mA
Current: TA=25°C, Vs=3.3V, VC=1.65V and load=15pF
Frequency Adjustment
Pulling
±10ppm to ±15ppm
Control Voltage
1.65V ±1.65V
Linearity: ±10% max
Slope: Positive
Input Impedance: 100kΩ min
Output Details
HCMOS
Output Compatibility
Drive Capability
15pF
Rise and Fall Time
8.0ns max
45/55%
Duty Cycle
Output Low (@ Vs=3.3V, load=15pF): 0.4V max
Output High (@ Vs=3.3V, load=15pF): 2.4V min
Sales Office Contact Details:
UK: +44 (0)1460 270200
France: 0800 901 383
Germany: 0800 1808 443
USA: +1.760.318.2824
Printed on 4 Sep 21 23:52 using Part Data Sheet V1.0018
Email: info@iqdfrequencyproducts.com
Web: www.iqdfrequencyproducts.com
Page 1 of 2
MCXO Specification
Customer Part:
Noise Parameters
Phase Noise (@ 10MHz typ):
-90dBc/Hz @ 10Hz
-115dBc/Hz @ 100Hz
-135dBc/Hz @ 1kHz
-145dBc/Hz @ 10kHz
-148dBc/Hz @ 100kHz
-150dBc/Hz @ 1MHz
Environmental Parameters
Storage Temperature Range: -55 to 105°C
ESD Level:
HBM, Class 2: 2000V to 4000V, JEDEC JS-001-2010
Machine Model, Class B: 200V to 400V, JEDEC JS-001-2010
Shock: IEC 60068-2-27, Test Ea: 100G acceleration for 6ms,
half sinewave, in 3 mutually perpendicular planes
Vibration: IEC 60068-2-6, Test Fc: 10Hz-2000Hz, 0.75mm
amplitude, 10G acceleration, 30mins per cycle, in 3 mutually
perpendicular planes, test duration 2hrs
Manufacturing Details
Maximum Reflow Temperature: 260°C (30secs max)
Compliance
RoHS Status (2015/863/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Compliant
Compliant
2
Packaging Details
Pack Style: Bulk
Pack Size: 1
Loose in bulk pack
Alternative packing option available
Page 2 of 2
很抱歉,暂时无法提供与“LFMCXO064078BULK”相匹配的价格&库存,您可以联系我们找货
