CTS2-32.768-12.5-20-R 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Date
Revisions
Electrical Specifications:
Nominal Frequency
Frequency Tolerance at 25º C
Aging per year
Turnover Temperature
Temperature Coefficient
Temperature Range
Temperature Range (Extended)
Temperature Range (Storage)
Equivalent Series Resistance
Standard
Optional
Standard
Load Capacitance
Shunt Capacitance
Motional Capacitance
Drive Level
Insulation Resistance
Quality Factor
Capacitance Ratio
Resistance to Shock
Optional
32.768
±20
±10
±3
25 ±5
-0.034 ± 0.008 PPM/
ºC²
-40 to +85
-40 to +125
-55 to +140
90
12.5
6.0
7.0
9.0
1.7
3.0
1.0
500 at at 100 Vdc ± 15 Vdc
70000
450
±5 PPM maximum offset from 75 cm drop
test in all axes on to a hard surface.
KHz
PPM
ºC
K Ohm Max
pF
pF Typ
fF Typ
uW Max
M Ohm Min
Typ
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Oct. 21, 2014
Microprocessor Crystal Unit
32.768 KHz (Time of Day)
2.0 x 1.2 millimeter Surface Mount
Ceramic Package
General Product Specification
Part Number:
CTS2 Series
www.aker-usa.com
Appr
Mechanical Outline:
Tolerances:
unless otherwise specified ± 0.1mm
2.0
0.53
0.53
TYP.
REF.
TYP.
max.0.60
0.06
1.2
0.06 REF.
Package is Ceramic-Metal.
Dimensions are millimeters.
PCB Solder Pad Layout:
0.7
0.8
1.5
0.8
Page:
2/4
Date: Oct. 21, 2014
P/N:
www.aker-usa.com
CTS2 Series
0.315
±0,05
0.254
±0,02
8 -0.1
+0.3
±0.1
±0.05
3.5
2 ±0.05
2.23
±0,05
4 ±0.1
1.75
Carrier Tape Dimensions:
1.43 ±0.05
4 ±0.1
0.061
0.83 ±0.05
Cover Tape
Direction of feed
All dimensions are in mm
Solder Reflow Characteristics:
Page:
3/4
Date: Oct. 21, 2014
P/N:
CTS2 Series
www.aker-usa.com
How to build a Part Number:
Series
Package
CTS
2
Frequency
32.768
Standard
Load Capacitance
Frequency Tolerance
12.5
6
7
9
Option
Standard
Optional
Temperature Range
See Notes
Part Number Example: Packaging
CTS2-32.768-9-20-R
CTS2: 2.0 x 1.2 mm SMD Crystal Unit
32.768 KHz Nominal Frequency
9 pF Load Capacitance
20: ±20 PPM Frequency Tolerance
-40 to +85° C Temperature Range
R: Tape and Reel Packaging
R
Parameter
2.0 x 1.2 mm SMD
KHz
12.5 pF
6 pF
7 pF
9 pF
±20 PPM
±10 PPM
-40 to +85 ºC
-40 to +125 ºC
Tape and Reel
Frequency vs. Temperature Characteristics:
To calculate the frequency stability the parabolic
curvature constant (K) is needed.
For calculating the stability at 45 ° C?
1- Change in temperature (T) is (45-25) = +20 ° C
2
2- Change in frequency is (-0.034 x (° C) ) =
2
(-0.035 x (20) = -13.6 PPM
Notes:
1- Standard Temperature Range does not need to be included in Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains 3000 pieces.
3- Specification subject to change without notice.
Page:
4/4
Date: Oct. 21, 2014
P/N:
www.aker-usa.com
CTS2 Series
CTS2-32.768-12.5-20-R 价格&库存
很抱歉,暂时无法提供与“CTS2-32.768-12.5-20-R”相匹配的价格&库存,您可以联系我们找货
