LFTVXO076345REEL
LFTVXO076345REEL
    IQD
    SMD-6
    有源晶振 30.72MHz 3.3V SMD-6
LFTVXO076345REEL 数据手册
TCVCXO Specification Part No. + Packaging: LFTVXO076345Reel Customer Part: Description The IQXT-316-3 uses ASIC technology and is designed to meet the short and medium term stability requirements of packet network synchronisation for Small Cells. Model IQXT-316-3 Model Issue number 1 Outline (mm) Frequency Parameters Frequency 30.720MHz Frequency Tolerance Tolerance Condition Frequency Stability ±1.00ppm @ 25°C ±1°C & VC=1.5V ±0.25ppm Operating Temperature Range -5.00 to 85.00°C In‐service Short-term Frequency Stability (over any 24-hr timeslot @ fixed supply voltage and load): 50 to 70°C: ±80ppb max 15 to 85°C: ±100ppb max -5 to 85°C: ±250ppb max Ageing (@ 25°C): ±20ppb max/day ±200ppb max/month ±1ppm max/year ±2ppm max over 3yrs Temperature Rate of Change (maximum rate of change of temperature condition for guaranteed stability specifications): 1°C/min max Acceleration Sensitivity (gamma vector of all 3 axes from 30 to 1500Hz): Typically 2ppb/G max Supply Voltage Variation (±2% change @ 25°C, measurement referenced to frequency observed @ nominal Vs): ±10ppb typ Load Variation (±1pF change @ 25°C, measurement referenced to frequency observed @ nominal load): ±10ppb typ Reflow Variation (pre to post reflow ΔF, measured after 1hr recovery @ 25°C): ±1ppm max Note: The characteristics of the oscillator may be temporarily affected by the processes of assembly and soldering. The in-service short term frequency stability specification applies after 48hrs continuous operation and after the first excursion over the temperature range. Nominal conditions apply unless otherwise stated. Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 7.000mA Absolute Maximum Ratings: Supply Voltage (Vs): -0.5V to 7V Control Voltage (VC): -0.5V to 9V All other inputs: -0.5V to Vs+0.5V Power Dissipation: 100mW max Junction Temperature: 150°C max Note: Operating beyond these limits may result in change or permanent damage to the oscillator. Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:49 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 3 TCVCXO Specification Part No. + Packaging: LFTVXO076345Reel Customer Part: Frequency Adjustment Pulling ±7ppm min to ±12ppm max Control Voltage 1.5V ±1.0V Input Impedance 100kΩ min Linearity (deviation from straight line curve fit): 1% max Frequency Tuning Slope: Positive Modulation Bandwidth: 1Hz min Note: Pulling referenced to frequency @ VC=1.5V Output Details HCMOS Output Compatibility Drive Capability 15pF Rise and Fall Time 8.0ns max 45/55% Duty Cycle Output Voltage Levels: Output Low (VoL): 10%Vs max Output High (VoH): 90%Vs min Start Up Time (amplitude within 90% of specified output level): 15ms max Temperature Sensor Output (pad 3): Vtemp (@ 25°C): 1.76V typ Slope Option: -2.1mV/°C typ Resistive Load: 100kΩ min Capacitive Load: 30pF max Output Impedance (@ 25°C): 1kΩ typ Sensor Linearity: 1.5% typ Output Control Tri-State Mode: Logic '0' (20%Vs max) to pad 6 disables the oscillator output, the output goes to a high impedance state. Logic '1' (60%Vs min) or no connection to pad 6 enables the oscillator output. Note: The tri-state control (enable) input pad has an internal 100kΩ pull up resistor which allows it to be left unconnected if not used. When in tri-state mode, the output stage is disabled, but the oscillator and compensation circuit are still active (Current Consumption: 2mA typ). Output Enable Time: 100μs max Noise Parameters Phase Noise @ 25°C (typ): -65dBc/Hz @ 1Hz -95dBc/Hz @ 10Hz -125dBc/Hz @ 100Hz -143dBc/Hz @ 1kHz -149dBc/Hz @ 10kHz -152dBc/Hz @ 100kHz -155dBc/Hz @ 1MHz Phase Jitter (12kHz to 5MHz): 300fs RMS typ Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:49 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 3 TCVCXO Specification Part No. + Packaging: LFTVXO076345Reel Customer Part: Environmental Parameters Low Temperature Storage: IEC 60068-2-01, Test Ab: 1000hrs @ -55°C. High Temperature Storage: IEC 60068-2-02, Test Bb: 1000hrs @ 150°C. Mechanical Shock: JESD22-B104: 1500G, 0.5ms duration, 5 pulses in each of 6 directions. Vibration: JESD22-B103: 20G peak acceleration for 4hrs in each of the 3 orientations, tested from 60-2000Hz, 12hrs total. High Temperature Operating Life (HTOL): JESD22-A108: 1008hrs @ 125°C. Thermal Cycling: JESD22-A104: 500 temperature cycles, -55 to 125°C. Solderability: JESD22-B102, Method 1, Condition E: 260°C for 5secs (preconditioning: 150°C, 16hrs). Resistance to Soldering Heat: IPC/JEDEC J-STD-020: 3 reflow cycles (peak temperature 260°C). Humidity: JESD22-A101: After 1008hrs @ 85°C ±2°C, 85% RH non-condensing (preconditioning: 3 reflow cycles @ peak temperature 260°C). Ageing: MIL-PRF-55310: 1008hrs @ 85°C (preconditioning: 3 reflow cycles @ peak temperature 260°C). Manufacturing Details Maximum Process Temperature: 260°C (30secs max) RoHS Terminations RoHS Reflow Temp 260°C max for 30secs max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 1 Packaging Details Pack Style: Reel Pack Size: 500 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:49 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 3 of 3
LFTVXO076345REEL 价格&库存
很抱歉,暂时无法提供与“LFTVXO076345REEL”相匹配的价格&库存,您可以联系我们找货
