TFETALSANF-40.000000 数据手册
TF Type
20.4 x 12.8 mm Voltage Controlled Temperature
re
Compensated Crystal Oscillator
FEATURE
- Typical 20.4 x 12.8 x 7.8 mm.
- Hermetically Sealed 14 Pin DIP Package
- Double sealed metal case and high reliability
- VCTCXO available
TYPICAL APPLICATION
- Large-Scale equipment
- WLAN/WiMAX
- Military Communication Equipmet
RoHS Compliant
DIMENSION (mm)
SOLDER PAD LAYOUT (mm)
[ SIDE VIEW ]
7.8Max
[ BOTTOM VIEW ]
20.4 ± 0.4
8
14
Pin 1 Symbol
4.58 ± 0.2
7
0.8
1
0.45
12.2 ± 0.2
15.24 ± 0.15
Pad#
1
7
8
14
6.4 ± 0.5
[ TOP VIEW ]
7.62 ± 0.15
Function
Vcon / NC
GND
Output
VDD
12.8 ± 0.4
Recmmended soldering pattern
ELECTRICAL SPECIFICATION
Parameter
Supply Voltage Variation (VDD) ±5%
Frequency Range
Frequency Tolerance*
Frequency Stability
Vs Supply Voltage (±5%) change
Vs Load (±10%) change
Vs Aging (@1st year)
Supply Current 10 MHz Fo薹15 MHz
15 MHz Fo薹26 MHz
26 MHz Fo!!!52 MHz
Output Level
Supply Current 1.25 MHz Fo薹10 MHz
10 MHz Fo薹15 MHz
15 MHz Fo薹26 MHz
26 MHz Fo!!!52 MHz
Output Level
Output High (Logic"1")
Clipped Sine Wave
3.3 V
2.8 V
Min.
Max.
Min.
Max.
CMOS
3.3 V
2.8V
Min.
Max.
Min.
Max.
3.135
10
3.135
1.25
_
3.465
52
±2.0
_
_
_
_
_
_
2.66
10
_
_
_
_
_
_
±0.2
±0.2
±1.0
2.0
3.0
4.0
_
0.8
2.94
52
±2.0
_
±0.2
±0.2
±1.0
2.0
3.0
4.0
0.8
_
2.5
0.5
±5.0
100
_
_
-115
-135
-148
_
2
125
-55
-55
_
_
_
2.66
1.25
2.94
52
±2.0
_
_
_
_
±0.2
±0.2
±1.0
±0.2
±0.2
±1.0
2.5
_
_
-115
-135
-148
2
125
V
MHz
ppm
ppm
ppm
mA
Only for clipped sine wave
Vp-p
_
_
_
_
Output Low (Logic"0")
0.5
±5.0
100
3.465
52
±2.0
_
Only for CMOS
Duty
Control Voltage Range (VCTCXO)
Pulling Range (VCTCXO)
VC Input Impedance (VCTCXO)
Phase noise @ 13.0 MHz 100 Hz
1 kHz
10 kHz
Start Time
Storage Temp. Range
_
Unit
_
_
_
_
10
15
7
10
15
or 2.4
_
2.52
or 2.4
_
_
0.33
or 0.4
60
2.5
_
0.28
or 0.4
60
2.5
40
0.5
±5.0
100
_
_
_
40
0.5
±5.0
100
-115
-135
-148
-55
2
125
_
-55
_
_
-115
-135
-148
mA
V
V
ppm
kΩ
dBc/Hz
2
125
mSec
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
Frequency at 25°C, 1 hour after reflow.
FREQ. STABILITY vs. TEMP. RANGE
Output Logic
ppm
Temp. (°C)
-20 ~ +70
-40 ~ +85
Clipped sine wave
±0.5
±1.0
CMOS
±0.5
±1.0
ż: Available Χ:Conditional X: Not available
“ Pulling Range < 10 ppm available
Note: not all combination of options are available. Other specifications may be available upon request.
6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH
www.taitien.com
sales@taitien.com.tw
Rev(15)11/2019
101
TFETALSANF-40.000000 价格&库存
很抱歉,暂时无法提供与“TFETALSANF-40.000000”相匹配的价格&库存,您可以联系我们找货
