Our Performance Your Reputation
100MHz Ultra Low Noise/Low G-Sensitivity OCXO
NA-100M-6900 series
NA-100M-6900 Series in 25.4x25.4mm DIP package
NA-100M-6900 series is a 100.000 MHz high performance (VC)OCXO offering
Ultra Low Phase Noise(ULPN), low G sensitivity(LGS) and tight frequency stability
down to ±50ppb(-20ºC to +70ºC). The part comes in a small hermetically sealed
through hole package which makes it suitable for humid environmental conditions.
FEATURES
APPLICATIONS
RoHS Compliant Standard
Ultra Low Phase Noise & Low G-Sensitivity
Instrument Reference
Hermetically Sealed Package
Microwave Communication
Tight Frequency Stability
Clock Reference for Microwave Signal Source
Low Power Consumption
Test & Measurement
Fast Warm-up Time
Telecom Systems
Electrical Frequency Tuning Input
Radar Systems
Reference Voltage Output
Medical (MRT)
RoHS-Compliant (lead-free)
ELECTRICAL SPECIFICATIONS
Test conditions: VDC = +5 V; VCO = +5 V; at +25 ± 3°C unless otherwise identified
1. OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
Min.
Typ.
Max.
100.000000
Unit
1.1.
Frequency (Fo)
1.2.
Initial Accuracy
1.3.
Waveform
1.4.
Level
1.5.
Load
1.6.
Harmonics
-30
dBc
1.7.
Spurious
-100
dBc
Test Condition
MHz
@ +25 ±1°C
-0.3
+0.3
ppm
after turn on power 30 minutes
Vco=+5V
Sine wave
+15
dBm
Ω
50
+/-10%
http://www.taitien.com E-Mail: sales@taitien.com.tw
Specifications subject to change without notice
Rev(1)12/2015
Page 1of 4
2. FREQUENCY STABILITY
Parameter
2.1.
Min.
Ambient
Typ.
Max.
Unit
±50, ±100
±200, ±500
ppb
-20oC ~ +70oC
-40oC ~ +85oC
°C
Test Condition
referenced to 25°C
Aging
after 30 days of continuous operation
Daily
-5
+5
ppb
Yearly
-200
+200
ppb
2.2.
-2
+2
ppm
2.3.
Voltage
15 Years
-5
+5
ppb
±5% change
2.4.
Load
-5
2.5.
Short term
2.6.
Warm-up
2.7.
G-Sensitivity
(each axis)
2.8.
Refer to Table 1 : Ordering Information
-50
+5
ppb
±10% change
0.05
ppb
root Allan variance for τ=1 sec
+50
ppb
in 5 minutes @ +25 ±1°C
1
ppb/g
Option A
Option B
-100
-105
dBc/Hz
@ 10Hz
-130
-135
dBc/Hz
@ 100Hz
-157
-162
dBc/Hz
@ 1KHz
-180
-180
dBc/Hz
@ 10KHz
-185
-185
dBc/Hz
@ 100KHz
-185
-185
dBc/Hz
@ 1MHz
Phase Noise (Max.)
referenced to 1 hour
3. ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
Min.
3.1.
Tuning Range
±2.5
3.2.
Control Voltage
Slope
3.4.
Center Voltage
3.5.
Linearity
Typ.
Max.
Unit
ppm
+10.0
Test Condition
Referenced to frequency at nominal Center Voltage
V
Positive
+5
-10
V
+10
4. INPUT POWER (PIN = “+VDC”)
4.1.
Parameter
Min.
Typ.
Max.
Unit
Voltage
+4.75
+5
+5.25
V
Steady State
2.1
W
During Warm-Up
950
mA
Test Condition
Current
4.2.
@ +25°C
Rev(1)12/2015
Page 2of 4
5. ENVIRONMENTAL
Parameter
Reference Std.
Test Condition
5.1.
Operable Temperature
-40°C to +85°C
5.2.
Storage Temperature
-55°C to +105°C
Note 1
5.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
95% RH @ +40°C,non-condensing,240 hours
5.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
5.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1 : Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
temperature range in 2.1.
Table 1 : ORDERING INFORMATION
Ambient
Option
Phase Noise Option
A
B
±100 ppb
NA-100M-6900
NA-100M-6901
±50 ppb
NA-100M-6910
NA-100M-6911
±500 ppb
NA-100M-6920
NA-100M-6921
±200 ppb
NA-100M-6930
NA-100M-6931
Temp. (°°C )
-20°°C ~+70oC
-40oC~+85oC
Other specifications may be available upon request.
Phase Noise Test Data
Rev(1)12/2015
Page 3of 4
OUTLINE DRAWING
Rev(1)12/2015
Page 4of 4
很抱歉,暂时无法提供与“NA-100M-6911”相匹配的价格&库存,您可以联系我们找货
