WTL3X60386VH
WTL3X60386VH
    WTL(维拓)
    SOJ-4
    无源晶振 -40℃~+85℃
WTL3X60386VH 数据手册
Tuning Fork Crystal, Series WX3 3.8 x 8.0 x 2.5 mm SMD Package Feature Wide frequency range Designed for automatic mounting and reflow soldering Higher frequency gullability and lower equivalent series resistance RoHS Compliant / Pb Free Electrical Specifications Item Specifications Frequency Range (KHz) 30~40 40~60 60~70 70~200 200~350 Load Capacitance (CL) 6~12.5pF,or specify Frequency Tolerance( at 25°C ) ±5ppm ~ ±100ppm Operating Temperature Range -10~+60°C, -20~+70°C, -40~+85°C or specify Turnover Temperature 25 ± 5°C Frequency Temperature Curve (-0.034±10%) x 10 /± -6 Equivalent Series Resistance (ESR) Max. 40kΩ 30kΩ Drive Level (Typical) 0.1µW Drive Level(Max) 1µW Shunt Capacitance ( C 0 ) 2.0pF Typ. 2 25kΩ 22kΩ Insulation Resistance More than 500Mohms at DC100V Storage Temperature Range -55°C~+125°C Aging @25 °C 1st Year (Max) ±3ppm/year, ±5 ppm/year, 20kΩ Dimension(mm) 7.9 ± 0.1 #1 #2 #4 #3 #1 #2 3.8Max #3 3.2±0.2 #4 SOLDER PATTERN 0.5 ± 0.1 0.9 0.9 1.9 0.5 ± 0.1 1.3 2.5±0.1 1.9 5.5 ± 0.5 1.3 http://www.wtlcrystals.com Email:wtl@wtlcrystals.com 4.2 Tel:86-755-82677582 1.3 32
WTL3X60386VH 价格&库存
很抱歉,暂时无法提供与“WTL3X60386VH”相匹配的价格&库存,您可以联系我们找货
