SXO22C3B171-20.000M
SXO22C3B171-20.000M
    SUNTSU
    SMD2520_4P
    有源晶振 20.000000MHz -30~+30ppm 3.3V -10℃~+70℃ CMOS
SXO22C3B171-20.000M 数据手册
Ceramic SMT 4 Pad CMOS Oscillator SXO22C Series 2.5mm x 2.0mm Features Applications • ±20ppm (Frequency Stability) Available • Micro Processors • Ceramic Package • SONET/SDH/DWDM • CMOS • Storage Area/Networking • Tape and Reel • Digital Video • Base Stations • Part Numbering Guide SXO 22 C 3 A 48 1 - 27.000M FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) BLANK : No Connection 1: Pin 1 SUNTSU OSC 2.5mm x 2.0mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% FREQUENCY STABILITY A : ±50ppm B : ±30ppm Cage Code : 4GUT4 C : ±25ppm To customize your parameters, contact a Suntsu representative. *D : ±20ppm * For Frequency stability option D, contact a Suntsu representative. CO M P L I A N T Electrical Parameters Units Minimum Frequency Range KHz 32.768 Frequency Range Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First MHz 1 110 ppm -20 +20 See part numbering guide for options Operating Temperature °C -40 +85 See part numbering guide for options Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.135 3.3 3.465 1.8V 2.5V 3.3V Frequency Range Current (IDD) Maximum Remarks 32.768KHz mA 3 4 5 Maximum Value 1.0000MHz - 15.999MHz 16.000MHz - 39.999MHz 40.000MHz - 59.999MHz 60.000MHz - 110.000MHz mA mA mA mA 3 5 10 15 5 7 13 20 7 10 15 35 Maximum Value Maximum Value Maximum Value Maximum Value Output Load (CMOS) pF Output Logic Levels High (VOH) Output Logic Levels Low (VOL) Rise (TR) and Fall (TF) Time Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C V 15 0.9*VDD V 0.1*VDD 32.768KHz ns 200 1.0000MHz - 15.999MHz 16.000MHz - 39.999MHz 40.000MHz - 59.999MHz ns ns ns ns 10 8 6 4 60.000MHz - 110.000MHz Symmetry (Duty Cycle) % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO22C Series 2.5mm x 2.0mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 20.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 27.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO22C Series 2.5mm x 2.0mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 20.000MHz Frequency - 27.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 3,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO22C Series 2.5mm x 2.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
SXO22C3B171-20.000M 价格&库存
很抱歉,暂时无法提供与“SXO22C3B171-20.000M”相匹配的价格&库存,您可以联系我们找货
