S53305T-24.000-R
S53305T-24.000-R
    AKER(安碁科技)
    SMD5032_4P
    有源晶振 24MHz 3.3V -20℃~+70℃ HCMOS
S53305T-24.000-R 数据手册
Revisions Ltr Date Appr RoHS Compliant Pb - Lead Free Electrical Specifications: Frequency Range 0.500~156.250 0.500~156.250 0.500~156.250 0.500~54.000 0.500~100.000 MHz Frequency Stability ±20 ~ ±100 ppm ±3 ppm Max. Aging per Year Operating Temperature Range Standard -10 ~ +70 Extended -40 ~ +85 -55 ~ +125 Storage Temperature Range 1.8 ± 5% 2.5 ± 5% 3.3 ± 10% 1.62 ~ 3.63 5.0 ± 10% 0.500 to 9.999MHz 5 6 7 7 10 10.000 to 19.999MHz 6 7 7 7 15 20.000 to 31.999MHz 6 8 12 12 25 32.000 to 49.999MHz 15 20 20 20 35 50.000 to 79.999MHz 15 20 25 25 50 80.000 to 99.999MHz 20 25 30 60 100.000 to 156.250MHz 25 30 40 80 Supply Voltage Input Current Output Voltage °C 90% VDD Min. Logic Low (Vol) 10% VDD Max. Standard 40 ~ 60 ( at 50% VDD) Tight 45 ~ 55 ( at 50% VDD) % 15 Output Load pF Max. 0.500 to 31.999MHz 5 5 10 10 10 32.000 to 49.999MHz 5 5 10 10 6 50.000 to 79.999MHz 4 4 8 8 80.000 to 99.999MHz 3 3 5 5 100.000 to 156.250MHz 3 3 4 4 5 1 Phase Jitter (12 KHz to 20 MHz) ps Max. RMS 10 Start Up Time ms Max. Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan All dimensions are millimeters. TCR Review: EG Appr: JL Page: 1/4 Date: July 1,2020 ns Max. Tri-State Enable-Disable Function CAD: mA Max. Logic High (Voh) Output Symmetry (Duty Cycle) Rise and Fall Time VDD HCMOS Output Clock Oscillator Low Profile 5.0 x 3.2 millimeter Surface Mount General Product Specification Part Number: www.aker-usa.com S5 Series Mechanical Outline and Solder Pad Layout: 5.0 ± 0.15 Ceramic Base 3.2 ± 0.15 #4 Metal Lid #3 AKER #1 #2 1.3 Max. 2.54 2.54 #2 #4 #3 1.4 1.0 1.20 2.20 #1 1.2 1.6 Pin Connection PIN No. #1 Enable/Disable Function PIN #1 Connection Enable/Disable #2 GND #3 Output #4 VDD PIN #3 HIGH or OPEN Operating LOW High Impedance Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : July 1,2020 www.aker-usa.com P/N: S5 Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION 5.4 AKER AKER AKER AKER A 5.5 Pin #1 12.0 B A B 1.5 8.0 1.4 3.6 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : July 1,2020 www.aker-usa.com P/N: S5 Series How to build a Part Number: Series Package S 5 Parameter 5.0 x 3.2 mm Supply Voltage 50 33 25 18 M +5.0 VDD ± 10% +3.3 VDD ± 10% +2.5 VDD ± 5% +1.8 VDD ± 5% +1.62 ~ +3.63 VDD Temperature Stability 10 05 025 020 ±100 ppm ±50 ppm ±25 ppm ±20 ppm See Notes T 40%~60% 45%~55% Duty Cycle Frequency 0.500~156.250 MHz - Temperature Range See Notes X -10 ~ +70 °C -40 ~ +85 °C - Packaging M R 250pcs Reel 1000pcs Reel Part Number Example: S53305T-50.000-X-R S5: 5.0 x 3.2 mm SMD Package 33: +3.3±10% VDD Supply Voltage 05: ±50 ppm Temperature Stability T: 45%~55% Tight Symmetry 50.000 MHz Nominal Frequency X: -40 ~ + 85°C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : July 1,2020 www.aker-usa.com P/N: S5 Series
S53305T-24.000-R
1. 物料型号:S5系列,例如S53305T-50.000-X-R。 2. 器件简介:HCMOS输出时钟振荡器,低轮廓5.0 x 3.2毫米表面贴装。 3. 引脚分配: - PIN #1:使能/禁用(Enable/Disable) - PIN #2:地(GND) - PIN #3:输出(Output) - PIN #4:电源电压(VDD) 4. 参数特性: - 频率范围:0.500~156.250 MHz - 频率稳定性:最高±100 ppm - 老化率:每年±3 ppm - 工作温度范围:标准-10~+70℃,扩展-40~+85℃ - 存储温度范围:-55~+125℃ - 供电电压:1.8±5%至5.0±10% VDD - 输入电流:最大值从5 mA至25 mA不等,取决于频率范围 - 输出电压:逻辑高(Voh)至少90% VDD,逻辑低(Vol)最大10% VDD - 输出对称性(占空比):40%~60%(标准),45%~55%(紧密) - 输出负载:最大15 pF - 上升和下降时间:最大值从3 ns至10 ns不等,取决于频率范围 - 相位抖动:12 kHz至20 MHz时最大1 ps RMS - 使能/禁用功能:三态 - 启动时间:最大10 ms 5. 功能详解:包括详细的电气规格和温度稳定性说明。 6. 应用信息:未在文档中明确列出,但根据器件类型,可能用于需要精确时钟信号的各种电子设备。 7. 封装信息:5.0 x 3.2毫米表面贴装封装,带有金属盖陶瓷基座,端封陶瓷-金属封装,焊盘为Ni/Au。
S53305T-24.000-R 价格&库存
很抱歉,暂时无法提供与“S53305T-24.000-R”相匹配的价格&库存,您可以联系我们找货
S53305T-24.000-R
