Our Performance Your Reputation
Oven Controlled Crystal Oscillator
NI-10 MHz-2500 series
2500 Series in 36.3x27.2mm DIP package
NI-10M-2500 series oscillators is designed for applications where space is at a premium
and good frequency stability is required. The oscillators can be used in many
communications applications. A choice of quartz resonators offers a variety of
performance versus cost options to fit most applications.
RoHS Compliant Standard
ELECTRICAL SPECIFICATIONS
1.
OUTPUT (PIN = “R.F. OUTPUT”)
Parameter
1.1.
Min.
Frequency
Typ.
Max.
10.000000
Unit
Test Condition
MHz
@ +25 ±1°C
1.2.
Initial Accuracy
-0.1
+0.1
ppm
after turn on power 15 ±1 minutes
≤ 90 days following date code
VCO Input at Center Voltage ±0.001V
1.3.
Waveform
1.4.
Level
1.5.
Load
1.6.
1.7.
2.
Sine wave
+6
+10
dBm
Harmonics
-30
dBc
Spurious
-60
dBc
Max.
Unit
Ω
50
FREQUENCY STABILITY
Parameter
2.1.
+8
Min.
Ambient
Aging
2.2.
Typ.
±3, ±5, ±10
ppb
-30 ~ +70
-40 ~ +85
°C
Test Condition
referenced to 25°C
Refer to Table 1 : Ordering Information
-0.5
+0.5
ppb
per day, at time of shipment
after 30 days
Daily
-0.5
+0.5
ppb
Yearly
-50
+50
ppb
10 Years
-0.3
+0.3
ppm
-0.5
+0.5
ppb
0.05
ppb/s
2.3.
Voltage
2.4.
Short term
±5% change
2.5.
Load
-0.5
+0.5
ppb
±5% change
2.6.
Warm-up
-10
+10
ppb
in 10 minutes @ +25 ±1°C
root Allan variance
referenced to 1 hour
Page 1of 3
Specifications subject to change without notice
Rev(1)06/2013
www.taitien.com
sales@taitien.com.tw
Parameter
2.7.
3.
Min.
Typ.
Phase Noise
Max.
Unit
-95
-90
dBc/Hz
@ 1Hz
-125
-120
dBc/Hz
@ 10Hz
-140
-135
dBc/Hz
@ 100Hz
-148
-145
dBc/Hz
@ 1KHz
-152
-150
dBc/Hz
@ 10KHz
ELECTRICAL FREQUENCY ADJUSTMENT (PIN = “VCO INPUT”)
Parameter
3.1.
Min.
Typ.
Tuning Range
Max.
Unit
-0.5
ppm
VCO @ Min. Voltage
ppm
VCO @ Max. Voltage
+0.5
3.2.
Control Voltage
3.3.
Slope
3.4.
Center Voltage
V
V
Test Condition
Linearity
-10
3.6.
Input Impedance
100
Optional, Refer to Table 1 : Ordering Information
+2.5
V
+2.0
V
+10
kΩ
INPUT POWER (PIN = “+VDC”)
Min.
Typ.
Max.
Unit
4.1.
Voltage
+4.75
+5.0
+5.25
V
4.2.
Current
800
mA
@ turn on
4.3.
Steady State
1.3
W
@ +25°C
Test Condition
REFERENCE VOLTAGE (PIN = "REFERENCE VOLTAGE")
(Optional Function. Refer to Table 1 : Ordering Information.)
5.1.
5.2.
6.
Note 1
Parameter
5.
Referenced to frequency at nominal
Center Voltage
Positive
3.5.
4.
Test Condition
Parameter
Min.
Typ.
Max.
Units
Voltage
+3.8
+4.0
+4.2
V
Load
9
Test Condition
Over temperature range in 2.1.
kΩ
ENVIRONMENTAL
Parameter
6.1.
Operating Temperature
6.2.
Storage Temperature
Reference Std.
-40°C to +85°C
Test Condition
Note 2
-55°C to +105°C
6.3.
Humidity
MIL-STD-202, Method 103
Test Condition A
6.4.
Vibration (non-operating)
MIL-STD-202, Method 201
0.06” Total p-p, 10 to 55 Hz
6.5.
Shock (non-operating)
MIL-STD-202, Method 213,
Test Condition J
30g, 11ms, half-sine
Note 1.
Note 2.
95% RH @ +40°C,non-condensing,240 hours
When not connected, VCO INPUT is internally held at this voltage.
Output maintained over this temperature range. Other requirements of this specification may not be met when operating outside the
Page 2of 3
Rev(1)06/2013
www.taitien.com
Table 1 : ORDERING INFORMATION
TAITIEN
Model No.
ppb
±3
±5
±10
NI-10M-2500
NI-10M-2503
NI-10M-2550
NI-10M-2553
NI-10M-2501
NI-10M-2504
NI-10M-2551
NI-10M-2554
NI-10M-2502
NI-10M-2505
NI-10M-2552
NI-10M-2555
Temp. (℃
-30~+70
-40~+85
-30~+70
-40~+85
Control
Voltage
Reference
Voltage
+2.5V
N/A
+2.0V
+4.0V
OUTLINE DRAWING
Page 3of 3
Rev(1)06/2013
www.taitien.com
很抱歉,暂时无法提供与“NI-10M-2552”相匹配的价格&库存,您可以联系我们找货
