LFTVXO070186REEL
LFTVXO070186REEL
    IQD
    SMD-6
    有源晶振 19.2MHz 1.8V SMD-6
LFTVXO070186REEL 数据手册
TCVCXO Specification Part No. + Packaging: LFTVXO070186Reel Customer Part: Description The IQXT-260-17 employs an analogue ASIC for the oscillator and a high-order temperature compensation circuit in a 2.5 x 2.0mm size package. Model IQXT-260-17 Model Issue number 2 Frequency Parameters Frequency 19.20MHz Frequency Tolerance Tolerance Condition Frequency Stability ±1.00ppm @ 25°C ±2°C ±0.50ppm Operating Temperature Range -30.00 to 85.00°C Ageing ±0.7ppm max over 1yr @ 25°C Frequency Stability: TA varied over operating temperature range, measurement referenced to frequency observed with Fref=(Fmax+Fmin)/2, Vs=1.8V, VC=0.9V and load=10kΩ//10pF. Frequency Slope (minimum of one frequency reading every 2°C and VC=0.9V): -10°C to 60°C: 0.05ppm/°C max Frequency Drift (calculated from frequency slope with temperature varied at a maximum of 1.92°C/min (0.032°C/s) over -10°C to 60°C): 1.6ppb/sec max Frequency Slope (minimum of one frequency reading every 2°C and VC=0.9V): -30°C to 85°C: 0.1ppm/°C max Frequency Drift (calculated from frequency slope with temperature varied at a maximum of 0.96°C/min (0.016°C/s) over -30°C to 85°C): 1.6ppb/sec max Note: Frequency Drift rate is calculated from the equation ppb/s=°C/s x ppb/°C. Small Thermal Cycle Frequency Slope (measured at 0.5°C intervals over any 5°C heating and 5°C cooling cycle, at a minimum rate of 1°C/minute within the operating temperature range): 50ppb/°C max (Note: Discard the first 0.5°C interval of each heating and cooling cycle.) Small Thermal Cycle Hysteresis (difference in frequency measurements over any 5°C heating and 5°C cooling cycle, at a minimum rate of 1°C/minute within the operating temperature range): 50ppb pk-pk max Supply Voltage Variation (±5% change @ 25°C): ±0.1ppm max Load Variation (±10% change @ 25°C): ±0.2ppm max Reflow Variation (after two consecutive reflows as per profile shown and 1hr recovery @ 25°C): ±1ppm max Note: Parts should be shielded from drafts causing unexpected thermal gradients. Temperature changes due to ambient air currents can lead to short term frequency drift. Outline (mm) Pb-Free Reflow Electrical Parameters 1.8V ±5% Supply Voltage Current Draw 1.500mA Supply Current (@ TA=25°C, Vs max and load=10kΩ//10pF): 1.5mA max Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 21:54 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 TCVCXO Specification Part No. + Packaging: LFTVXO070186Reel Customer Part: Frequency Adjustment Pulling ±15.6ppm to ±24.0ppm Control Voltage 0.9V ±0.6V Input Impedance 500kΩ Input Impedance: Measured between control voltage and GND pins. Linearity (deviation from a straight line curve fit): 20% max Output Details Clipped Sine Output Compatibility Drive Capability 10kΩ//10pF ±10% Output Voltage Level (@ TA=25°C, Vs min and load=10kΩ//10pF): 0.8V pk-pk min Start Up Time (frequency within ±0.5ppm of steady state frequency): 0.5ms max Output: DC coupled Note: AC-coupled output requires an external capacitor, ≥1nF recommended. Noise Parameters Phase Noise @ 25°C (max): -86dBc/Hz @ 10Hz -110dBc/Hz @ 100Hz -137dBc/Hz @ 1kHz -143dBc/Hz @ 10kHz -150dBc/Hz @ 100kHz Harmonics: -5dBc max Environmental Parameters Storage Temperature Range: -40 to 85°C Shock: MIL-STD-202 M213: Half sine wave acceleration of 3000G peak amplitude, duration 0.3ms, velocity 12.3ft/s. Vibration: JESD22-B103-B: 10G peak acceleration for 20mins, 12 cycles in each of the 3 orientations, tested from 10-2000Hz. Moisture Resistance: MIL-STD-202 M106g: 1000hrs @ 85°C, 85% RH, biased. Thermal Cycling: JESD22 Method JA-104C: 1000 temperature cycles, where each cycle consists of a 25mins soak time @ -40°C followed by a 25mins soak time @ 85°C, with a 60secs maximum transition time between temperatures, air to air transition. Note: Frequency shift ≤1ppm after environmental conditions. Manufacturing Details Maximum Process Temperature: 260°C (40secs max) Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 21:54 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFTVXO070186REEL 价格&库存
很抱歉,暂时无法提供与“LFTVXO070186REEL”相匹配的价格&库存,您可以联系我们找货
LFTVXO070186REEL
  • 3000+16.846473000+2.18999
